Home » Eclipse Projects » Eclipse 4 » Using a ListSelectionDialog in a E4 RCP Application
Using a ListSelectionDialog in a E4 RCP Application [message #901113] Thu, 09 August 2012 16:47 Go to next message
When I try to open a ListSelectionDialog in an E4 RCP application, I get an exception :
java.lang.IllegalStateException: Workbench has not been created yet.
at org.eclipse.ui.PlatformUI.getWorkbench(PlatformUI.java:92)
at org.eclipse.ui.dialogs.ListSelectionDialog.configureShell(ListSelectionDialog.java:156)
at org.eclipse.jface.window.Window.createShell(Window.java:502)
at org.eclipse.jface.window.Window.create(Window.java:430)
at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1089)
at org.eclipse.jface.window.Window.open(Window.java:790)
In fact, looking at the problem in debug, the Workbench.getInstance() used in PlatformUI.getWorkbench() returns null.
As far as I understand, the workbench instance is created in Workbench.createAndRunWorkbench, which is called by PlatformUI.createAndRunWorkbench, which is called by IDEApplication.start().
But when running an E4 RCP application (and not a plugin), IDEApplication is not used : E4Application is the one that is launched, and it does not create a Workbench instance (but a E4Workbench is instanciated).
So I don't know if this is a bug in E4 that makes the ListSelectionDialog (and all dialogs that don't override the Dialog.open method) unavailable, or if I should use it another way.
Can somebody help me about this ?
Thanks !
EDIT :
I made a mistake : the PlatformUI.getWorkbench() is just used by the ListSelectionDialog.configureShell() method, so the other dialogs are not impacted. To bypass the problem, I overrided the configureShell method to catch the exception, but it's not very nice :
new ListSelectionDialog(Display.getCurrent().getActiveShell(),
new String[] { "1", "2", "3" },
new ArrayContentProvider(),
new LabelProvider(),
"Please choose!") {
protected void configureShell(org.eclipse.swt.widgets.Shell shell) {
try {
super.configureShell(shell);
catch(IllegalStateException e) {}
}.open();
[Updated on: Thu, 09 August 2012 17:02] by Moderator
Re: Using a ListSelectionDialog in a E4 RCP Application [message #901131 is a reply to message #901113] Thu, 09 August 2012 18:50 Go to previous messageGo to next message
Pure E4 apps can't use anything in org.eclipse.ui.*.
Re: Using a ListSelectionDialog in a E4 RCP Application [message #901161 is a reply to message #901131] Fri, 10 August 2012 03:41 Go to previous messageGo to next message
Brian de Alwis wrote on Thu, 09 August 2012 18:50
Wah, this sounds a bit harsh, so many useful things in org.eclipse.ui.* that can't be used in E4 apps ! Sad
(by the way, my ugly try/catch seems to work well for the ListSelectionDialog, so as it is just an internal app I'll keep with this for now)
Re: Using a ListSelectionDialog in a E4 RCP Application [message #901171 is a reply to message #901161] Fri, 10 August 2012 04:14 Go to previous messageGo to next message
In e4 you do things through services and DI (org.eclipse.e4.ui.*), not singletons like 3.x.
I gave a quick look at your code and if the active shell is what you need, simply inject it like this:
@Inject
@Named(IServiceConstants.ACTIVE_SHELL)
private Shell shell;
Re: Using a ListSelectionDialog in a E4 RCP Application [message #901174 is a reply to message #901171] Fri, 10 August 2012 04:17 Go to previous messageGo to next message
The problem is the reachout to the help system!
Tom
Am 10.08.12 10:14, schrieb Sopot Cela:
> @Inject @Named(IServiceConstants.ACTIVE_SHELL)
Re: Using a ListSelectionDialog in a E4 RCP Application [message #901175 is a reply to message #901161] Fri, 10 August 2012 04:18 Go to previous messageGo to next message
You are welcome to help us refactoring the stuff found there. We would
have to split things into bundles, abstract away calls through services.
The ListSelectionDialog is a nice candidate, if you copy it to a project
which only depends SWT/JFace you'll immediately spot what needs to be
changed.
Tom
Am 10.08.12 09:41, schrieb Vince Cadmus:
> that can't be used in E4 apps ! :(
> this for now)
Re: Using a ListSelectionDialog in a E4 RCP Application [message #901311 is a reply to message #901161] Fri, 10 August 2012 13:22 Go to previous messageGo to next message
Vince Cadmus wrote on Fri, 10 August 2012 03:41
Sorry, should have added ", unfortunately" Wink
Brian.
Re: Using a ListSelectionDialog in a E4 RCP Application [message #902052 is a reply to message #901311] Wed, 15 August 2012 12:25 Go to previous messageGo to next message
I migrated ListSelectionDialog to JFace. Follow https://bugs.eclipse.org/bugs/show_bug.cgi?id=350251 to see if it gets accepted.
Re: Using a ListSelectionDialog in a E4 RCP Application [message #902277 is a reply to message #902052] Thu, 16 August 2012 14:02 Go to previous messageGo to next message
Thanks Lars ! By the way, the discussion on the target link is interesting (and could help me to participate to some refactoring one day, as for now I feel a bit newby to do it Wink )
(and by the way too, thanks also for your wonderful tutorials, Lars, it helps me - and lot of people I think - a lot ! Wink )
Re: Using a ListSelectionDialog in a E4 RCP Application [message #902281 is a reply to message #902277] Thu, 16 August 2012 14:09 Go to previous messageGo to next message
It's never too early to contribute.
Re: Using a ListSelectionDialog in a E4 RCP Application [message #902361 is a reply to message #902277] Fri, 17 August 2012 06:17 Go to previous message
Thanks Vince for the feedback. Would be great if you to migrate another ListDialog.
Previous Topic:PartSashContainer: Children
Next Topic:SplashScreen
Current Time: Mon Jul 21 01:19:54 EDT 2025
Powered by FUDForum. Page generated in 0.05526 seconds
