Progress bar on splash problem [message #899856] |
Thu, 02 August 2012 11:57  |
My project has never had a progress bar or text on the splash screen, but since I've been using JUNO to develop, it's been added.
The weird thing is that if I check the two checkboxes to add the progress bar and message and input a position in the corresponding fileds, it doesn't change anything.
Unchecking the boxes still leaves the progress bar and message on top of my splash.
Is there something that I could do to get rid of them or to reposition them to the correct position, at least?
Thanks!
Re: Progress bar on splash problem [message #949708 is a reply to message #899856] |
Fri, 19 October 2012 03:59  |
Having the same Problem.
If I check "Add a progress bar" and "Add a progress message" I'm able to
modify posistion and size.
Once the checkboxes are unchecked, progress bar and message are
displayed on top of the splash.
I don't want progress bar and progress message top be displayed and
found a trick that works for me.
I check both checkboxes and set hight and weight of progress bar and
progress message to "0".
That's surely not the way it's meant to be done, but it does the trick.
> my splash.
> Thanks!
FUDForum. Page generated in 0.05917 seconds
