Home » Modeling » M2T (model-to-text transformation) » [XPAND] Update of XPAND Content Assistant when changing Metamodel(OR: Best way to reference to a metamodel from an other plugin)
[XPAND] Update of XPAND Content Assistant when changing Metamodel [message #900673] Wed, 08 August 2012 02:40 Go to next message
Hello guy,
I have following situation:
- 1 Eclipse Plugin with the ecore metamodel.
- 1 Eclipse Plugin with MWE workflow and XPAND script for code generation using metamodel of other plugin.
To get Code Assistand of XPAND Editor working I added the folder of the metamodel to the java build path of the generator plugin (Project properties->java build path->libraries->add class folder).
This is basicly working, but when I do changes in the metamodel, XPAND code assistant does not get updated automatically. I have to readd the metamodel folder to the build path, that code assistant get updated with metamodel changes.
Is there a better whay ?
Kind regards,
Patrick
Re: [XPAND] Update of XPAND Content Assistant when changing Metamodel [message #900876 is a reply to message #900673] Wed, 08 August 2012 15:17 Go to previous messageGo to next message
which version do you use?
what about added a simple bundle dependency (manifest) from the gen plugin to the mm plugin?
~Christian
Re: [XPAND] Update of XPAND Content Assistant when changing Metamodel [message #901040 is a reply to message #900876] Thu, 09 August 2012 10:03 Go to previous messageGo to next message
When I just add the other plugin to the dependencies, I dont get any code assistant.
See picture for installed version.
index.php/fa/11093/0/
  • Attachment: version.png
    (Size: 79.90KB, Downloaded 614 times)
Re: [XPAND] Update of XPAND Content Assistant when changing Metamodel [message #901044 is a reply to message #901040] Thu, 09 August 2012 10:09 Go to previous messageGo to next message
Hi this is not the reps I am talking about I talk about the
meta-inf/manifest.MF file
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Re: [XPAND] Update of XPAND Content Assistant when changing Metamodel [message #901046 is a reply to message #901044] Thu, 09 August 2012 10:13 Go to previous messageGo to next message
Here is the Manifest file of my generator plugin:
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: com.ksb.devicedescription.cgenerator
Bundle-SymbolicName: com.ksb.devicedescription.cgenerator; singleton:=true
Bundle-Version: 1.0.0
Require-Bundle: org.eclipse.jdt.core;bundle-version="3.5.0",
 org.eclipse.xtend.profiler;resolution:=optional,
 org.apache.commons.logging,
 org.apache.log4j;resolution:=optional,
 com.ibm.icu;bundle-version="4.0.1",
 org.antlr.runtime;bundle-version="3.0.0",
 org.eclipse.core.runtime;bundle-version="3.5.0",
 org.eclipse.emf.mwe.utils;bundle-version="0.7.0",
 org.eclipse.emf.ecore.xmi;bundle-version="2.5.0",
 org.eclipse.jface.text;bundle-version="3.5.0",
 org.eclipse.xpand;bundle-version="0.7.0",
 org.eclipse.xtend;bundle-version="0.7.0",
 org.eclipse.xtend.typesystem.emf;bundle-version="0.7.0",
 org.eclipse.ui.console;bundle-version="3.5.100",
 org.eclipse.jface;bundle-version="3.8.0"
 devicedescription.model;bundle-version="1.0.0",
Bundle-RequiredExecutionEnvironment: JavaSE-1.6
Export-Package: com.ksb.devicedescription.cgenerator
Import-Package: devicedescription
Bundle-ClassPath: .
The ecore model is located in plugin: devicedescription.model
[Updated on: Thu, 09 August 2012 10:14] by Moderator
Re: [XPAND] Update of XPAND Content Assistant when changing Metamodel [message #901050 is a reply to message #901046] Thu, 09 August 2012 10:24 Go to previous messageGo to next message
And the score is really part of the exported packages of the model
plugin. Btw why don't you use the javabeans metamodel?
Re: [XPAND] Update of XPAND Content Assistant when changing Metamodel [message #901063 is a reply to message #901050] Thu, 09 August 2012 11:08 Go to previous message
Found the problem:
I have the ecore model path added in the generator plugin as class folder. But the ecore model path must be added as class folder to the plugin of the model, then auto update of code assistant is working.
I did not tried javabeans metamodel, since I always created my metamodels with ecore.
In short, main advantages of javabeans metamodel?
[Updated on: Thu, 09 August 2012 11:11] by Moderator
Previous Topic:[acceleo] Question on OCL cache and standalone + thread
Next Topic:Questions about generation code for Objective C and small games for iPhone
Current Time: Sat Jul 26 21:58:49 EDT 2025
Powered by FUDForum. Page generated in 0.04444 seconds
