Home » Newcomers » Newcomers » Content assist for libraries
Content assist for libraries [message #900891] Wed, 08 August 2012 16:48 Go to next message
I'm trying to build a new application in eclipse which is using Jetty. I'd like to be able to use content assist (CTRL + space) so that I can view the javadoc info from the jetty classes. I tried to add a javadoc location to a few of the jar files I imported (http://download.eclipse.org/jetty/stable-7/apidocs/) but I'm not getting anything in the content assist window. Has anyone had any luck with this for other apis? I have it working fine for the JDK but only because I attached the src.zip
Re: Content assist for libraries [message #900935 is a reply to message #900891] Thu, 09 August 2012 03:15 Go to previous message
It should work. If it does not for you, then please file a bug with
exact steps (exact JAR[s], Javadoc you use, etc.) to reproduce the
problem against JDT Text.
Dani
Previous Topic:Debugger hangs the IDE up
Next Topic:More context for search results?
Current Time: Fri Jul 18 21:20:58 EDT 2025
Powered by FUDForum. Page generated in 0.05837 seconds
