Home » Archived » BIRT » Chart Axis script not working
Chart Axis script not working [message #900811] Wed, 08 August 2012 10:52 Go to next message
I am utilizing a script and a parameter to change the X axis on a chart that I am tasked with creating. It works beautifully in BIRT, but when I publish it to our EssentiaRX system, it gives this error message:
"TypeError: Cannot call method "getReportItem" of null (/report/method[@name="beforeFactory"]#5)."
Here is the script:
importPackage( Packages. org.eclipse.birt.chart.model);
importPackage (Packages.org.eclipse.birt.chart.model.attribute );
cht = reportContext.getDesignHandle().findElement("mychart1");
mychart = cht.getReportItem().getProperty( "chart.instance" );
xAxis =mychart.getAxes().get(0);
xSeriesDef = xAxis.getSeriesDefinitions().get(0);
xGrouping = xSeriesDef.getGrouping();
if (params["Period"].value == "Week"){
xGrouping.setGroupingUnit(GroupingUnitType.WEEKS_LITERAL);
else if (params["Period"].value == "Month"){
xGrouping.setGroupingUnit(GroupingUnitType.MONTHS_LITERAL);
else if (params["Period"].value == "Year"){
xGrouping.setGroupingUnit(GroupingUnitType.YEARS_LITERAL);
We are using BIRT 2.3.1 in Eclipse 3.4.1 as near as I can tell. Thanks for any assistance.
Re: Chart Axis script not working [message #900835 is a reply to message #900811] Wed, 08 August 2012 12:36 Go to previous messageGo to next message
Michael
What version of the designer did you test this in? Can you modify the
script like:
cht =
reportContext.getReportRunnable().designHandle.getDesignHandle().findElement("mychart1");
I do not remember when we added the reportContext.getDesignHandle()
direct call but your version may not have the call.
Jason
> Here is the script:
> for any assistance.
Re: Chart Axis script not working [message #900845 is a reply to message #900835] Wed, 08 August 2012 13:24 Go to previous messageGo to next message
Jason,
Thanks for the quick reply. Straight off of my screen: BIRT Report Designer, Version: 2.3.1.v20080630-7X7n7FECLqlyX1jw48bOyH4E0ha5, Build id: v20080922-1151.
I tried the code that you suggested and again, it worked fine in the designer, but when published into our EssentiaRX system, it gives the same error as before.
Perhaps I need to speak to those folks?
Mike
[Updated on: Wed, 08 August 2012 13:25] by Moderator
Re: Chart Axis script not working [message #900846 is a reply to message #900845] Wed, 08 August 2012 13:29 Go to previous messageGo to next message
Can you post the report?
On 8/8/2012 1:24 PM, Michael Harless wrote:
> Jason,
> Mike
Re: Chart Axis script not working [message #900848 is a reply to message #900846] Wed, 08 August 2012 13:32 Go to previous messageGo to next message
Sure, here it is:
Mike
Re: Chart Axis script not working [message #900850 is a reply to message #900846] Wed, 08 August 2012 13:32 Go to previous messageGo to next message
Also can you add this to the script?
importPackage( Packages.java.io );
out = new PrintWriter( new FileWriter( "c:/temp/chtevents.txt", true ) );
out.println( "Test " + cht);
out.close();
And post what is in chtevents.txt after running on the server.
Jason
>> Jason,
>> Mike
Re: Chart Axis script not working [message #900858 is a reply to message #900850] Wed, 08 August 2012 14:00 Go to previous messageGo to next message
Jason,
The Essentia system won't let me run that script. It doesn't know what c: is.
Re: Chart Axis script not working [message #900861 is a reply to message #900858] Wed, 08 August 2012 14:14 Go to previous messageGo to next message
Is this running on a unix box?
On 8/8/2012 2:00 PM, Michael Harless wrote:
> Jason,
> c: is.
Re: Chart Axis script not working [message #900864 is a reply to message #900861] Wed, 08 August 2012 14:19 Go to previous messageGo to next message
IBM Power 7. It's a evolutionary child of the old AS/400 systems.
Re: Chart Axis script not working [message #900867 is a reply to message #900864] Wed, 08 August 2012 14:23 Go to previous messageGo to next message
Ok add a data item to the top of the report and set its expression to
mycht; Then change your script to:
mycht = cht;
Make sure to not put a var keyword in front of it. Run the report and
see what is in the label.
Jason
Re: Chart Axis script not working [message #900871 is a reply to message #900867] Wed, 08 August 2012 14:39 Go to previous messageGo to next message
When I run it in BIRT:
org.eclipse.birt.report.model.api.ExtendedItemHandle@118efe2
When I run it in Essentia, nothing.
Re: Chart Axis script not working [message #900878 is a reply to message #900871] Wed, 08 August 2012 15:21 Go to previous messageGo to next message
I am not certain why this is happening but could you try adding:
importPackage(Packages.org.eclipse.birt.report.model.api) to the top of
the script and see if it makes a difference?
Jason
> mailto:org.eclipse.birt.report.model.api.ExtendedItemHandle@118efe2
Re: Chart Axis script not working [message #900880 is a reply to message #900878] Wed, 08 August 2012 15:33 Go to previous messageGo to next message
Jason,
It didn't help. I'm still getting the same error. I think that we need to send a copy of this to LWSI and see if they can help. Thanks so much.
Mike
Re: Chart Axis script not working [message #900896 is a reply to message #900880] Wed, 08 August 2012 17:14 Go to previous message
Sounds like a good idea. Let us know what you find out.
Jason
On 8/8/2012 3:33 PM, Michael Harless wrote:
> Jason,
> Mike
Previous Topic:CDT Custom build Option to be added in Projects Context Menu and run for Both MBS and Standard Make
Next Topic:Reg dynamic parameter
Current Time: Mon Oct 13 10:36:27 EDT 2025
Powered by FUDForum. Page generated in 0.07427 seconds
