Triggering generator using context menu in xtext [message #900826] |
Wed, 08 August 2012 11:50  |
I have changed the plugin.xml in ui package to disable the default triggering of xtend generator.
I have created "GenerationHandler" class in " org.xtext.example.mydsl.ui.handler" package.
My GenerationHandler class is:
package org.xtext.example.mydsl.ui.handler;
public class GenerationHandler extends AbstractHandler implements IHandler {
@Inject
private IGenerator generator;
@Inject
private Provider<EclipseResourceFileSystemAccess> fileAccessProvider;
@Inject
IResourceDescriptions resourceDescriptions;
@Inject
IResourceSetProvider resourceSetProvider;
public Object execute(ExecutionEvent event) throws ExecutionException {
ISelection selection = HandlerUtil.getCurrentSelection(event);
if (selection instanceof IStructuredSelection) {
IStructuredSelection structuredSelection = (IStructuredSelection) selection;
Object firstElement = structuredSelection.getFirstElement();
if (firstElement instanceof IFile) {
IFile file = (IFile) firstElement;
IProject project = file.getProject();
IFolder srcGenFolder = project.getFolder("src-gen");
if (!srcGenFolder.exists()) {
try {
srcGenFolder.create(true, true,
new NullProgressMonitor());
} catch (CoreException e) {
return null;
final EclipseResourceFileSystemAccess fsa = fileAccessProvider.get();
fsa.setOutputPath(srcGenFolder.getFullPath().toString());
URI uri = URI.createPlatformResourceURI(file.getFullPath().toString(), true);
ResourceSet rs = resourceSetProvider.get(project);
Resource r = rs.getResource(uri, true);
generator.doGenerate(r, fsa);
return null;
public boolean isEnabled() {
return true;
Problem:
I dont know which all packages to import, since it is asking many packages.
Can any one suggests which all packages to import please...?
Re: Triggering generator using context menu in xtext [message #900842 is a reply to message #900826] |
Wed, 08 August 2012 13:11  |
i dont know if i got your problem. never the less if you are asking about my blog post...
import org.eclipse.core.commands.AbstractHandler;
import org.eclipse.core.commands.ExecutionEvent;
import org.eclipse.core.commands.ExecutionException;
import org.eclipse.core.commands.IHandler;
import org.eclipse.core.resources.IFile;
import org.eclipse.core.resources.IFolder;
import org.eclipse.core.resources.IProject;
import org.eclipse.core.runtime.CoreException;
import org.eclipse.core.runtime.NullProgressMonitor;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.jface.viewers.ISelection;
import org.eclipse.jface.viewers.IStructuredSelection;
import org.eclipse.ui.handlers.HandlerUtil;
import org.eclipse.xtext.builder.EclipseResourceFileSystemAccess;
import org.eclipse.xtext.generator.IGenerator;
import org.eclipse.xtext.resource.IResourceDescriptions;
import org.eclipse.xtext.ui.resource.IResourceSetProvider;
import com.google.inject.Inject;
import com.google.inject.Provider;
~Christian
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext@itemis.de
FUDForum. Page generated in 0.04635 seconds
