Home » Modeling » GMF (Graphical Modeling Framework) » Problem in generating Code
Problem in generating Code [message #900333] |
Mon, 06 August 2012 10:22  |
Hi Everyone,
Iam trying to generate code for simple GMF model mentioned in ttp://gmfsamples.tuxfamily.org/wiki/doku.php?id=gmf_tutorial1
Iam using eclipse juno (latest stable release - Eclipse Juno (4.2) Package)
When i try to generate diagram code iam getting following error
Problems while generating code
Exception (Boolean expected (was: org.eclipse.ocl.ecore.internal.OCLStandardLibraryImpl$1)!:in CodeStyle, line 18) while generating code
Exception (Boolean expected (was: org.eclipse.ocl.ecore.internal.OCLStandardLibraryImpl$1)!:in CodeStyle, line 77) while generating code
Exception (Boolean expected (was: org.eclipse.ocl.ecore.internal.OCLStandardLibraryImpl$1)!:in CodeStyle, line 83) while generating code
Exception (Boolean expected (was: org.eclipse.ocl.ecore.internal.OCLStandardLibraryImpl$1)!:in CodeStyle, line 19) while generating code
Exception (Boolean expected (was: org.eclipse.ocl.ecore.internal.OCLStandardLibraryImpl$1)!:in CodeStyle, line 49) while generating code
Exception (Boolean expected (was: org.eclipse.ocl.ecore.internal.OCLStandardLibraryImpl$1)!:in xpt::plugin::manifest, line 78) while generating code
Your help is appreciated
Sarath
Attachment: file.genmodel
(Size: 1.51KB, Downloaded 521 times)
Attachment: file.gmfgraph
(Size: 2.44KB, Downloaded 527 times)
Attachment: file.gmfmap
(Size: 2.41KB, Downloaded 472 times)
Attachment: file.gmftool
(Size: 1.52KB, Downloaded 738 times)
Attachment: file.gmfgen
(Size: 15.94KB, Downloaded 570 times)
[Updated on: Tue, 07 August 2012 08:06] by Moderator
Re: Problem in generating Code [message #1011833 is a reply to message #901020] |
Wed, 20 February 2013 05:34   |
A coworker and myself experienced this problem independently of each other. Problems like these are very frustrating, as it is nigh impossible to find proper documentation for these issues. At the current stage, it seems the state of the GMF documentation is quite poor. People interested in GMF still learn through the tutorials (which do a good job at introducing to GMF), but then you are on your own.
In my opinion, it would be helpful to have a central location for all documentation - API, Tutorials, Howtos, Explanation of GMFModel file properties (gmfmap, gmfgen, ...). At the moment, the wiki is in a very unorganized state. I don't know if this is due to the migration from an old wiki or what is the issue here - many dead links, empty pages and so on.
Hopefully I don't come across as overly negative here - I am truly thankful for GMF and its contributors, and it is a great tool - if you know what you are doing! But growing the userbase will be difficult if frustrations like this occur, where solutions are found only in newsgroups instead of comprehensive documentation/FAQs.
Stephan
Re: Problem in generating Code [message #1753131 is a reply to message #900333] |
Thu, 02 February 2017 02:04  |
Hi all,
I'm a newie on Eclipse specifically on GMF
I have generated the model, mapping, graphics and so, but now I get the error posted here. Where can I find help about how to fix it? I tried changing the compliance as showed on web but didn't work. Anybody could post the steps that I could follow please?
Current Time: Wed Jul 23 05:32:08 EDT 2025
Powered by FUDForum. Page generated in 0.05312 seconds
