Home » Archived » BIRT » Access the value of a computed column of a dataset in a script
Access the value of a computed column of a dataset in a script [message #900740] Wed, 08 August 2012 07:11 Go to next message
I have added a data element to one of the column of the grid.In the onRender script of the data element , i want to access the value of a computed column of a particular datset.
I tried doing something like this:
temp=reportContext.getDesignHandle().findDataSet("Design Defects Not found in Design Phase").computedColumnsIterator().next();
this.setDisplayValue(temp);
But this script only fetches me the object, not the value.
Can you please help me on how to access the value of a computed data column from the script.
Thanks!
Rupal
Re: Access the value of a computed column of a dataset in a script [message #900818 is a reply to message #900740] Wed, 08 August 2012 11:33 Go to previous messageGo to next message
That iterator will only get you the design not the values. Is you data
item bound to a dataset or is the grid? In either case add the computed
column to the binding and just reference it like:
this.setDisplayValue(this.getRowData().getColumnValue("COMPUTEDCOLUMNBINDINGNAME"));
See attached example
Jason
On 8/8/2012 7:11 AM, Rupal Biyani wrote:
> Thanks!
> Rupal
Re: Access the value of a computed column of a dataset in a script [message #901148 is a reply to message #900818] Fri, 10 August 2012 01:26 Go to previous messageGo to next message
Jason Weathersby wrote on Wed, 08 August 2012 11:33
Jason
> Thanks!
> Rupal
Jason,
My requirement is as follows:
I need to display the values of various project metrics in a grid.
This project metric is a ratio,where the numerator and denominator comes from two different data sets.But since we can attach, only one datset to an element.I cannot calculate the ratio.
Right now i have made a invisible grid with many tables, that stores the values of these numerators and denominators and then in the final grid using OnRender script, i calculate the values.
I wanted to ask is there any other way through which we can do this?
I am attaching the file for your reference.
Re: Access the value of a computed column of a dataset in a script [message #901613 is a reply to message #901148] Mon, 13 August 2012 12:22 Go to previous messageGo to next message
Yes but first do the datasets return more than one row?
Jason
>> Jason
>>> Hi,
>>> Thanks!
>>> Rupal
> Jason,
Re: Access the value of a computed column of a dataset in a script [message #901616 is a reply to message #901613] Mon, 13 August 2012 12:27 Go to previous message
You can always bind one dataset to the grid and one to the data item and
then reference the outer one within the data expression. See attached.
Jason
> Jason
>>> Jason
>>>> Hi,
>>>> Thanks!
>>>> Rupal
>> Jason,
Previous Topic:Birt POJO's as DataSource?
Next Topic:Print Report --> Empty page
Current Time: Wed Jul 23 05:48:36 EDT 2025
Powered by FUDForum. Page generated in 0.08280 seconds
