Home » Archived » BIRT » params["myParam"] not accessible from beforeOpen???
params["myParam"] not accessible from beforeOpen??? [message #90073] Fri, 11 November 2005 06:30 Go to next message
I want to modify the SQL statement depending on what a user enters in the
report params.
I added following script in the beforeOpen event of the dataset:
queryText = "SELECT " + params["myParam"] + " from myTable";
so the user should be able to specify the columm of myTable he wants to see.
If I try to save this modifications, an error message pops up saying (see
attachment):
ReferenceError: "params" is not defined!
But IMHO the array params[] MUST be available from this event, because it is
a precondition to have all parameters ready BEFORE execution of the SQL
query, or not?
The same code works in the afterOpen event, but of course then the SQL query
was already executed and no more able to modify.
So how can I modify the SQL statement of a dataset considering report
params?
Thanks for any help!
Re: params["myParam"] not accessible from beforeOpen??? [message #90091 is a reply to message #90073] Fri, 11 November 2005 06:46 Go to previous messageGo to next message
forgot the attachment!
  • Attachment: error.jpg
    (Size: 37.61KB, Downloaded 107 times)
Re: params["myParam"] not accessible from beforeOpen??? [message #90121 is a reply to message #90091] Fri, 11 November 2005 09:20 Go to previous messageGo to next message
Originally posted by: akravets.kligerweiss.com
I get the same error when I use params array...
Re: params["myParam"] not accessible from beforeOpen??? [message #90226 is a reply to message #90073] Fri, 11 November 2005 11:43 Go to previous messageGo to next message
Mr. Burns,
This is a known bug.
109522
I experienced a similar problem. It would fail in the designer, but the
report would still run.
Jason Weathersby
BIRT PMC
"Mr. Burns" <Mr._Burns@web.de> wrote in message
news:dl1vd8$utt$1@news.eclipse.org...
> Hello,
> report params.
> see.
> attachment):
> is a precondition to have all parameters ready BEFORE execution of the SQL
> query, or not?
> query was already executed and no more able to modify.
> params?
Re: params["myParam"] not accessible from beforeOpen??? [message #94741 is a reply to message #90226] Mon, 28 November 2005 11:44 Go to previous message
Originally posted by: stuart.roe.ovic.co.uk
I appear to be having a similar problem in the beforeDrawAxisTitle function.
'Data Explorer' | 'Report Parameters' is listing an entry for 'XAttribute'
and my function currently reads:
function beforeDrawAxisTitle(Axis, Title)
Title.getCaption().setValue(params["XAttribute"]);
but the error log has 'org.eclipse.birt.chart.exception.ChartException:
$NO-RB$ ReferenceError: "params" is not defined.' entries! Is this the
same problem?
BTW: It isn't changing the chart's x-axis title when executed outside of
the designer in the viewer applet.
"Jason Weathersby" <jweathersby@actuate.com> wrote in message
news:dl2hn4$2rj$1@news.eclipse.org...
> Mr. Burns,
> 109522
> Jason Weathersby
> BIRT PMC
>> Hello,
>> report params.
>> see.
>> attachment):
>> SQL query, or not?
>> params?
Previous Topic:Non-category axes in Line charts, or lines in Scatter charts
Next Topic:Changing the axis label of a bar graph
Current Time: Tue Jul 22 02:46:39 EDT 2025
Powered by FUDForum. Page generated in 0.29013 seconds
