Home » Archived » Buckminster » Procedure to create Fragment project and build using Buckminster
Procedure to create Fragment project and build using Buckminster [message #900710] Wed, 08 August 2012 05:11 Go to next message
I need to create a fragment project for org.eclipse.wst.html.ui to change the Editor options and layout. i have created the fragment project and i'm able to run as Eclipse application. But while creating the product its giving lot of errors.
I need to know how to build this fragmented project using buckminster.
Please help me to know the build procedure for eclipse fragmented projects.
I'm getting the following error while building:
ENTRY org.eclipse.equinox.p2.director 4 1 2012-08-08 12:35:34.644
!MESSAGE Cannot complete the install because one or more required items could not be found.
!SUBENTRY 1 org.eclipse.equinox.p2.director 4 0 2012-08-08 12:35:34.644
!MESSAGE Software being installed: test Product 1.0.0.1 (com.lge.eclipse.base.wb.product1 1.0.0.1)
!MESSAGE Missing requirement: HTML UI Source Editor 1.0.602.1 (org.eclipse.wst.html.ui 1.0.602.1) requires 'bundle org.eclipse.wst.sse.ui [1.2.0,1.4.0)' but it could not be found
!SUBENTRY 1 org.eclipse.equinox.p2.director 4 1 2012-08-08 12:35:34.754
!MESSAGE Cannot satisfy dependency:
!SUBENTRY 2 org.eclipse.equinox.p2.director 4 0 2012-08-08 12:35:34.754
!MESSAGE From: test Product 1.0.0.1 (com.test.eclipse.base.wb.product1 1.0.0.1)
!MESSAGE To: com.lge.eclipse.product.feature.feature.group [1.0.0.1]
!SUBENTRY 2 org.eclipse.equinox.p2.director 4 0 2012-08-08 12:35:34.863
!MESSAGE From: test Feature 1.0.0.1 (com.test.eclipse.product.feature.feature.group 1.0.0.1)
!MESSAGE To: org.eclipse.wst.html.ui [1.0.602.1]
[Updated on: Wed, 08 August 2012 05:43] by Moderator
Re: Procedure to create Fragment project and build using Buckminster [message #900726 is a reply to message #900710] Wed, 08 August 2012 06:10 Go to previous message
See my answer to http://www.eclipse.org/forums/index.php/m/784434/ which I think applies to your situation.
Matthew
Previous Topic:Target Platform in Buckminster
Next Topic:Unable to materialize components in Eclipse 3.7
Current Time: Wed Jul 23 10:48:56 EDT 2025
Powered by FUDForum. Page generated in 0.02827 seconds
