Home » Modeling » EMF » Problem in the installed CDO Source(Cannot run "CDO Client" run configuration from CDO Source)
Problem in the installed CDO Source [message #900636] Tue, 07 August 2012 17:29 Go to next message
Hi all,
I successfully installed the CDO Source and I ran the "CDO Server" run Configuration. Now CDO Server is started.
Now, I want to run "CDOClient1" or "CDOClient2". But when I run any of these, I get the "Error Message Box" saying that,
"The application could not start. Would you like view the log?"
When I view the log file in an editor, I get the following error.
Error is given below:
!SESSION 2012-08-07 23:23:23.577 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_31
Framework arguments: -product org.eclipse.platform.ide
Command-line arguments: -product org.eclipse.platform.ide -data C:\Users\Uma\workspace\Thesis_Indigo_Workspace\New/../cdo.client1 -dev file:C:/Users/Uma/workspace/Thesis_Indigo_Workspace/New/.metadata/.plugins/org.eclipse.pde.core/CDOClient1/dev.properties -debug C:\Users\Uma\workspace\Thesis_Indigo_Workspace\New\.metadata\.plugins\org.eclipse.pde.core\CDOClient1/.options -os win32 -ws win32 -arch x86 -console
!ENTRY org.eclipse.osgi 4 0 2012-08-07 23:23:26.976
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: Application "org.eclipse.ui.ide.workbench" could not be found in the registry. The applications available are: org.eclipse.equinox.app.error, org.eclipse.ant.core.antRunner, org.eclipse.help.base.infocenterApplication, org.eclipse.help.base.helpApplication, org.eclipse.help.base.indexTool, org.eclipse.emf.cdo.server.app.
at org.eclipse.equinox.internal.app.EclipseAppContainer.startDefaultApp(EclipseAppContainer.java:248)
at org.eclipse.equinox.internal.app.MainApplicationLauncher.run(MainApplicationLauncher.java:29)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
[Updated on: Tue, 07 August 2012 17:31] by Moderator
Re: Problem in the installed CDO Source [message #900638 is a reply to message #900636] Tue, 07 August 2012 17:46 Go to previous messageGo to next message
I could launch "Example Client" Configuration. But in that instance, I cannot create a "Dawn Project". Only CDO is there!!
Re: Problem in the installed CDO Source [message #900678 is a reply to message #900636] Wed, 08 August 2012 03:11 Go to previous messageGo to next message
Am 07.08.2012 23:29, schrieb UmaShankar Subramani:
> Hi all,
> Now, I want to run "CDOClient1" or "CDOClient2". But when I run any of these, I get the following error.
That indicates problems with your target platform/installation or your launch config. Make sure the
"org.eclipse.ui.ide.application" is properly activated.
Cheers
/Eike
http://www.esc-net.de
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> !STACK 1
> at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
Re: Problem in the installed CDO Source [message #901116 is a reply to message #900678] Thu, 09 August 2012 17:04 Go to previous messageGo to next message
Now I can run it. I added all the plugins and ran the configuration. It works fine now.
But whenever I try to create a "Dawn Diagram", I get the following error message(Screenshot attached)
  • Attachment: Untitled.png
    (Size: 222.49KB, Downloaded 193 times)
[Updated on: Thu, 09 August 2012 18:08] by Moderator
Re: Problem in the installed CDO Source [message #901129 is a reply to message #901116] Thu, 09 August 2012 18:13 Go to previous messageGo to next message
Also, in the editor, this error is shown:
at org.eclipse.emf.cdo.dawn.ui.DawnEditorInput.getView(DawnEditorInput.java:33)
at org.eclipse.emf.cdo.dawn.examples.acore.diagram.part.DawnAcoreDiagramEditor.setInput(DawnAcoreDiagramEditor.java:69)
at org.eclipse.gef.ui.parts.GraphicalEditor.init(GraphicalEditor.java:346)
at org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditor.init(DiagramEditor.java:653)
at org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.DiagramDocumentEditor.init(DiagramDocumentEditor.java:126)
at org.eclipse.ui.internal.EditorManager.createSite(EditorManager.java:828)
at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:647)
at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:465)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
at org.eclipse.ui.internal.EditorReference.getEditor(EditorReference.java:289)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2949)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2854)
at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPage.java:2846)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:2797)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2793)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2777)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2760)
at org.eclipse.emf.cdo.dawn.examples.acore.diagram.part.DawnAcoreDiagramEditorUtil.openDiagram(DawnAcoreDiagramEditorUtil.java:63)
at org.eclipse.emf.cdo.dawn.examples.acore.diagram.part.DawnAcoreCreationWizard$1.execute(DawnAcoreCreationWizard.java:70)
at org.eclipse.ui.actions.WorkspaceModifyOperation$1.run(WorkspaceModifyOperation.java:106)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2344)
at org.eclipse.ui.actions.WorkspaceModifyOperation.run(WorkspaceModifyOperation.java:118)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:464)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:372)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java:1028)
at org.eclipse.emf.cdo.dawn.examples.acore.diagram.part.DawnAcoreCreationWizard.performFinish(DawnAcoreCreationWizard.java:82)
at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDialog.java:827)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:432)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:624)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:248)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4169)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3758)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
at org.eclipse.jface.window.Window.open(Window.java:801)
at org.eclipse.ui.internal.handlers.WizardHandler$New.executeHandler(WizardHandler.java:259)
at org.eclipse.ui.internal.handlers.WizardHandler.execute(WizardHandler.java:279)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:293)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:499)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
at org.eclipse.ui.internal.handlers.HandlerService.executeCommand(HandlerService.java:169)
at org.eclipse.ui.internal.handlers.SlaveHandlerService.executeCommand(SlaveHandlerService.java:241)
at org.eclipse.ui.internal.actions.CommandAction.runWithEvent(CommandAction.java:157)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2701)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2665)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
Re: Problem in the installed CDO Source [message #901267 is a reply to message #901129] Fri, 10 August 2012 10:38 Go to previous messageGo to next message
which version of CDO/Dawn are you using?
Martin
Am 10.08.2012 00:13, schrieb UmaShankar Subramani:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
> at
> org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:124)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> at
> at
> at
Re: Problem in the installed CDO Source [message #901394 is a reply to message #901267] Sat, 11 August 2012 13:38 Go to previous messageGo to next message
I installed the source as mentioned here:
http://wiki.eclipse.org/CDO_Source_Installation
I used CDO 4.1 BaseLine
[Updated on: Sat, 11 August 2012 13:39] by Moderator
Re: Problem in the installed CDO Source [message #901430 is a reply to message #901394] Sun, 12 August 2012 02:51 Go to previous messageGo to next message
Am 11.08.2012 19:38, schrieb UmaShankar Subramani:
O.k. This means you are running Dawn 2.0 with the latest version of CDO.
Just to make sure that I understand what you are trying to do:
- You installed the CDO sources successfully
- You ran the CDO Client with the Dawn bundles
- You are playing with the Dawn GMF examples and getting the error
Right?
Could you please try to create a "normal" resource using the CDO Session
View, just to make sure your CDO installation works properly?
Martin
Re: Problem in the installed CDO Source [message #901473 is a reply to message #901430] Sun, 12 August 2012 17:04 Go to previous messageGo to next message
Hi Martin,
You are right.
I tested CDO functionality.
CDO works properly. Also "Dawn Editors" work properly. But not "Dawn Diagram Editors".
Same error:
at org.eclipse.emf.cdo.dawn.ecoretools.diagram.part.DawnEcoreDiagramEditor.setInput(DawnEcoreDiagramEditor.java:71)
at org.eclipse.emf.cdo.dawn.ecoretools.diagram.part.DawnEcoreDiagramEditorUtil.openDiagram(DawnEcoreDiagramEditorUtil.java:68)
at org.eclipse.emf.cdo.dawn.ecoretools.diagram.part.DawnEcoreCreationWizard$1.execute(DawnEcoreCreationWizard.java:81)
at org.eclipse.emf.cdo.dawn.ecoretools.diagram.part.DawnEcoreCreationWizard.performFinish(DawnEcoreCreationWizard.java:93)
[Updated on: Mon, 13 August 2012 07:58] by Moderator
Re: Problem in the installed CDO Source [message #902676 is a reply to message #901473] Sun, 19 August 2012 06:08 Go to previous messageGo to next message
The exception occurs since the resource is not set to the
DawnEditorInput. But I really cannot reproduce the problem.
1.) I installed to source into a fresh eclipse
2.) started the CDO server
3.) create a Dawn GMF diagram using the wizard
4.) Played a bit with the diagram
Is there something else you did?
Martin
Am 12.08.2012 23:04, schrieb UmaShankar Subramani:
> Hi Eike,
> You are right.
> Diagram Editors".
> Same error:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: Problem in the installed CDO Source [message #902692 is a reply to message #902676] Sun, 19 August 2012 13:09 Go to previous messageGo to next message
Hi Martin,
Thanks for your reply. I did the same as you, but I did something more. I guess there is not seperate "RunConfiguration for DAWN".
So, in the RunConfiguration, in Plug-ins tab, I selected all the plugins under "workspace" section. Then added all required plugins.
Re: Problem in the installed CDO Source [message #902907 is a reply to message #902692] Tue, 21 August 2012 01:34 Go to previous message
Am 19.08.2012 19:09, schrieb UmaShankar Subramani:
> Hi Martin,
Please do not add specific plugins on your own. Just create a new
runtime config and use it with all workspace bundles (default)
Martin
Previous Topic:Xcore is really awesome.
Next Topic:EMF Source Page
Current Time: Wed Jul 23 20:41:00 EDT 2025
Powered by FUDForum. Page generated in 0.07041 seconds
