Home » Eclipse Projects » Remote Application Platform (RAP) » How to style View header?(CSS related questions)
How to style View header? [message #900085] Fri, 03 August 2012 17:26 Go to next message
I am trying to style the ViewPart Tab header. Which widget should I be theming?
http://help.eclipse.org/juno/index.jsp?topic=%2Forg.eclipse.rap.help%2Fhelp%2Fhtml%2Freference%2Ftheming%2Findex.html
I tried TabItem and CTabItem but the colors don't change. I can change the Shell-Titlebar style but it changes the title bar of all shells (include the TitleAreaDialog).
Any pointers are greatly appreciated!
Ronald
[Updated on: Fri, 03 August 2012 17:27] by Moderator
Re: How to style View header? [message #900265 is a reply to message #900085] Mon, 06 August 2012 05:13 Go to previous messageGo to next message
Hi.
> I am trying to style the View Tab header. Which widget should I be
> theming?
These are usually CTabItems, unless you are using a custom look and feel
(e.g. "buisness" or "fancy" from budle org.eclipse.rap.design.example),
in which case you need to look here:
http://help.eclipse.org/juno/topic/org.eclipse.rap.help/help/html/advanced/look-and-feel.html
To change the style of specific widget-instances, you need to use custom
variants:
Greetings,
Tim
Tim Buschtöns
Twitter: @EclipseRAP
Re: How to style View header? [message #900277 is a reply to message #900085] Mon, 06 August 2012 06:01 Go to previous messageGo to next message
Roland,
please note that Workbench has it's own theming capabilities which could
override the RAP theming. See DefaultTabFolder and PaneFolder classes.
Best,
Ivan
On 8/4/2012 12:26 AM, Ronald So wrote:
> Hello,
> theming?
> Ronald
Ivan Furnadjiev
Re: How to style View header? [message #900424 is a reply to message #900277] Mon, 06 August 2012 23:48 Go to previous messageGo to next message
Hi,Ivan
Can you provide some code?
thank a lot
Re: How to style View header? [message #900434 is a reply to message #900424] Tue, 07 August 2012 01:50 Go to previous messageGo to next message
a fast web search for "Eclipse Workbench Theme" brings me to this article:
http://stackoverflow.com/questions/628726/how-to-change-the-color-of-eclipse-rcp-view-title-bar
Best,
Ivan
On 8/7/2012 6:48 AM, ocean xue wrote:
> Hi,Ivan
> thank a lot
Ivan Furnadjiev
Re: How to style View header? [message #900607 is a reply to message #900434] Tue, 07 August 2012 14:32 Go to previous messageGo to next message
Ivan,
Thanks for the link but I am trying to keep all my settings in CSS. After trying the CTabItem style,
CTabItem {
    font: normal bold 15px Trebuchet, Arial, sans-serif;
    color: #ffffff;
    background-color: #005596;
    background-image: none;
    padding: 10px 25px;
    spacing: 0px;
    text-shadow: none;
CTabItem:selected {
    color: #005596;
    background-image: gradient(linear, left top, left bottom,
            from( #0000ff ),
            color-stop( 10%, #ffffff) ),
            to( #ffffff )
It seems like RAP honors the font, padding, spacing, and text-shadow without a problem. However, "color", "background-color", and "background-image" are not being honored.
I have attached how the UI renders when the tabs are being selected with the code above.
Ronald
Re: How to style View header? [message #900617 is a reply to message #900607] Tue, 07 August 2012 15:20 Go to previous messageGo to next message
Roland,
that's true, because these properties are overrided by the Workbench
theme - set background, background (selection) gradient by code. If you
search somewhere in the DefaultTabFolder or PaneFolder classes you will
find the places where these properties are set. In RAP, the properties
set by the code always override the same properties set by RAP theming.
HTH,
Ivan
On 8/7/2012 9:32 PM, Ronald So wrote:
> Ivan,
> CTabItem {
> color: #ffffff;
> padding: 10px 25px;
> spacing: 0px;
> text-shadow: none;
> CTabItem:selected {
> color: #005596;
> from( #0000ff ),
> to( #ffffff )
> Ronald
Ivan Furnadjiev
Re: How to style View header? [message #900619 is a reply to message #900617] Tue, 07 August 2012 15:41 Go to previous messageGo to next message
Ivan,
I understand that the code will override CSS settings, but is it a desirable behavior? With this limitation, developers are pretty much handcuffed by whatever colors that the code is using, and the color may not go along with the rest of the CSS settings we set for other components. Is there a way to relax it, or is it a big fix that there is no hope to get in 1.5.1 time frame even if a bug is logged?
Ronald
Re: How to style View header? [message #900668 is a reply to message #900619] Wed, 08 August 2012 02:21 Go to previous message
Roland,
currently there is no workaround. If a property is set by the code it
takes precedence. From my point of view this is not a bug (this is how
workbench theming works) and there is no chance for improvement in this
direction for 1.5.1. Sorry.
Best,
Ivan
On 8/7/2012 10:41 PM, Ronald So wrote:
> Ivan,
> Ronald
Ivan Furnadjiev
Previous Topic:MongoDB IDE with RAP
Next Topic:How to style Scroll bar color?
Current Time: Sun Jul 27 09:58:05 EDT 2025
Powered by FUDForum. Page generated in 0.04354 seconds
