Home » Modeling » EMF » [CDO] Exception Handling on Commit
[CDO] Exception Handling on Commit [message #900378] Mon, 06 August 2012 13:52 Go to next message
Hello
I am setting up a rcp application based on CDO/Hibernate. I am currently working on fallback exception handling strategies on a commit. I have noticed that the CommitException does not include a cause (getCause() returns null). I assume that this is quite reasonable in many cases, since one does not have to worry about having obscure exceptions on the classpath that arrise from somewhere within the jdbc implementation.
On the other hand, I would like to create some default error messages based on exceptions that arrise from constraint violations (org.hibernate.exception.ConstraintViolationException). I could parse the message from the CommitException, which holds the exception stack trace, but I was wondering if there es a more elegant solution to this.
I have tried to set up an ExceptionHandler in the CDONet4jSessionConfiguration before the CDOSession is opened, but the handleException method doesn't get called. (I verified, that it is correctly set in the CDOSession with getExceptionHandler().)
So question #1 is: Should the ExceptionHandler be notified of commit exceptions? If not, when will this ExceptionHandler be used?
Question #2: Is it possible to hook into the server for exception handling? Maybe use custom exceptions with appropriate error messages for common constraint violations.
Thanks for the support!
Greetings
Christoph
Re: [CDO] Exception Handling on Commit [message #900428 is a reply to message #900378] Tue, 07 August 2012 01:26 Go to previous messageGo to next message
Am 06.08.2012 19:52, schrieb Christoph Keimel:
> Hello
That seems to be an "exception", not the general rule. How exactly does this exception look like, where is it being thrown?
I guess you're referring to the fact that some exception classes themselves are not on the classpatch of a client
application, only on the classpatch of the server deployment. Because the server can not know what classes are available
on the client (except those in net4j, net4j.util and cdo.common) all stacktraces are also transferred in String form to
the client. See RemoteExceptionRequest and RemoteExceptionIndication for details.
Didn't you say that, in your case, there is no cause/stacktrace available?
No. CommitExceptions are special in that they are created on the client side from the rollbackMessage that is received
from the server in case of "failed" commits. In other words, non-transport commit problems are handled on
application-(protocol-)level.
This handler is mostly used to intercept transport-level exceptions. The RecoveringCDOSessionImpl is an example:
private class RecoveringExceptionHandler implements ExceptionHandler
public void handleException(CDOSession session, int attempt, Exception exception) throws Exception
if (exception instanceof TransportException)
recover();
Not yet, I think.
What problems would you define as "common"? Perhaps you can start with some examples?
Cheers
/Eike
http://www.esc-net.de
Re: [CDO] Exception Handling on Commit [message #900508 is a reply to message #900378] Tue, 07 August 2012 06:41 Go to previous messageGo to next message
I am most happy to abide ... thanks for taking the time to help.
Consider this model element (xcore):
class MyElement {
	unique String name
	String description
Which gets these persistence annotations (for Hibernate):
<eclass name="MyElement">
	<eattribute name="name">
		<column nullable="false" unique="true"/>
	</eattribute>
</eclass>
The resulting database definition now has a table "myelement" with a column "name". The column "name" has a "not null" constraint as well as a "unique" constraint.
On the client I execute the following test (where IEmTracRepoService is a simple client interface to handle the setup of the CDOSession):
public void testNotNullConstraintViolation(IEmTracRepoService repo) {
	// TODO Exception Handling bei Constraint-Violations
	CDOTransaction transaction = repo.openTransaction();
	try {
		CDOResource resource = transaction.getOrCreateResource(repo.getResourceName());
		MyElement element = EmTracFactory.eINSTANCE.createMyElement();
		resource.getContents().add(element);
		element.setDescription("Test Element without a Name");
		transaction.commit();
	} catch (CommitException e) {
		logger.error("CommitException", e);
	} finally {
		transaction.close();
This throws a CommitException as expected, because the name has not been set. This is the stack trace which is logged (shortened):
12:16:41.090 ERROR d.e.e.a.h.TestNotNullConstraintViolation - CommitException
org.eclipse.emf.cdo.util.CommitException: Rollback in HibernateStore: org.hibernate.exception.ConstraintViolationException: Column 'name' cannot be null
	at org.hibernate.exception.internal.SQLExceptionTypeDelegate.convert(SQLExceptionTypeDelegate.java:75)
Caused by: com.mysql.jdbc.exceptions.jdbc4.MySQLIntegrityConstraintViolationException: Column 'name' cannot be null
	at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
I would like to be able to get the originating message of the exeption, which is "Column 'name' cannot be null" in this specific case. "e.getMessage()" returns the full stack trace as a String. Since "e.getCause()" returns null it is not possible to walk the exception hierarchie.
If the client handles everything well, this situation will not happen, because everything has been checked before the commit is sent. But sometimes constraints get added later, or the check is simply forgotten and then the rdb constraints kick in. This is why I am talking about a "fall back exception handling". It would be nice to still be able to produce good error messages for the user.
It would be nice, if I could get the MySQLIntegrityConstraintViolationException as an object, because this also holds additional information (vender code, etc.)
Greetings
Christoph
Re: [CDO] Exception Handling on Commit [message #900572 is a reply to message #900508] Tue, 07 August 2012 11:07 Go to previous messageGo to next message
Am 07.08.2012 12:41, schrieb Christoph Keimel:
> class MyElement {
> unique String name
What does "unique" mean here? I thought it's just meaningful for many-valued features.
> String description
> </eattribute>
> </eclass>
> of the CDOSession):
> try {
> } finally {
> (shortened):
Ah, you are willing to put the exception class(es) on the client's classpath! Then you should have no problems because
the org.eclipse.net4j bundle declares Eclipse-"BuddyPolicy: registered" exactly for this use case. Just put
"Eclipse-RegisterBuddy: org.eclipse.net4j" into the manifest of the bundle that contributes your exception classe(s).
Some more infos about buddy classloading:
http://rajakannappan.blogspot.de/2010/03/eclipse-classloading-and-buddy-policy.html
Cheers
/Eike
Re: [CDO] Exception Handling on Commit [message #900608 is a reply to message #900572] Tue, 07 August 2012 14:37 Go to previous messageGo to next message
[quote title=Eike Stepper wrote on Tue, 07 August 2012 17:07]
> > class MyElement {
> > unique String name
> features.
That is true. I was testing to see if it had an effect on the persistence binding. The attribute "unique" is ignored here.
> Ah, you are willing to put the exception class(es) on the client's classpath! Then > you should have no problems because
> the org.eclipse.net4j bundle declares Eclipse-"BuddyPolicy: registered" exactly for > this use case. Just put
Sounds perfect Smile. I added "Eclipse-RegisterBuddy: org.eclipse.net4j" to both the org.hibernate plug-in and the com.mysql.jdbc plug-in (my own copies, so I can edit the MANIFEST.MF). This does not have any effect on the CommitException. The cause is still null. (I verified that the correct plug-ins are available.)
I was debugging into the code and I couldn't find the position where the original exception would be instantiated. The CommitException gets thrown in CDOSingleTransactionStrategyImpl because the rollbackMessage in CommitTransactionResult is not null. Could you please give me a pointer on where to start looking?
Or am I looking in the wrong place all together? Is there more information in the transaction or in the session? I tried
transaction.getSession().getCommitInfoManager().getCommitInfo(transaction.getLastCommitTime())
but this returns null too ... probably because the commit never completed.
Or is this an issue with the Hibernate-Store?
Re: [CDO] Exception Handling on Commit [message #900661 is a reply to message #900608] Wed, 08 August 2012 01:23 Go to previous messageGo to next message
Am 07.08.2012 20:38, schrieb Christoph Keimel:
>> because the org.eclipse.net4j bundle declares Eclipse-"BuddyPolicy: registered" exactly for this use case. Just put
> Sounds perfect :). I added "Eclipse-RegisterBuddy: org.eclipse.net4j" to both the org.hibernate plug-in and the
That's what I originally meant when I said "CommitExceptions are special in that they are created on the client side
from the rollbackMessage that is received from the server in case of "failed" commits. In other words, non-transport
commit problems are handled on application-(protocol-)level."
Please set breakpoints on all constructors of the exception class in question and start stepping (out) from there to see
where in CDO they're caught/handled. You don't require the source code of Hibernate for that.
See above ;-)
Set the breakpoints. You'll end up in
org.eclipse.emf.cdo.internal.server.TransactionCommitContext.handleException(Throwable).
> tried transaction.getSession().getCommitInfoManager().getCommitInfo(transaction.getLastCommitTime())
transaction.getLastCommitTime() is probably already zero.
Yes.
No, I think this works as designed.
Cheers
/Eike
Re: [CDO] Exception Handling on Commit [message #900683 is a reply to message #900661] Wed, 08 August 2012 03:27 Go to previous messageGo to next message
Hi Eike,
What I don't understand is how to get the originating exception on the client-side. Or to put it in code:
	try {
		... do something to the model ...
	} catch (CommitException commitException) {
		// This will be an instance of org.hibernate.exception.ConstraintViolationException
		// in case of a constraint violation
		Exception cause = getOriginatingException(commitException, transaction);
	} finally {
private Exception getOriginatingException(CommitException commitException, CDOTransaction transaction) {
How to implement getOriginatingException ... ?
From your previous answers I was expecting some kind of Class.forName(...) in org.eclipse.net4j when net4j tries to recreate the exception from the signal result (or something like that). Otherwise why should net4j require buddy registering of the bundle that contributes the exception classes?
Greetings
Christoph
Re: [CDO] Exception Handling on Commit [message #900834 is a reply to message #900683] Wed, 08 August 2012 12:35 Go to previous messageGo to next message
Am 08.08.2012 09:27, schrieb Christoph Keimel:
> Hi Eike,
You can't at the moment.
> try {
> } finally {
The commit network protocol and some API would have to be changed accordingly. I pointed you to the code in the server
that the exception is passed to to handle it. from there you could come up with a patch to transport it to the client
and make it available much like RemoteExceptionRequest/Indication.
That is for signals but the commit signal family.
Cheers
/Eike
Re: [CDO] Exception Handling on Commit [message #900882 is a reply to message #900834] Wed, 08 August 2012 15:39 Go to previous messageGo to next message
Thanks. Now I'm on track.
Re: [CDO] Exception Handling on Commit [message #902412 is a reply to message #900834] Fri, 17 August 2012 10:02 Go to previous messageGo to next message
Hi Eike,
I did some work on the subject. My approach is to add the exception causing the rollback to the CommitTransactionResult. This way, there is no big change in the API. The client will ignore the exception, if it runs into a ClassNotFoundException. Otherwise it will be passed to the CommitException as cause.
Please have a look at the patch attached and tell me what you think.
(This is a git patch on the master branch commit 5f615d8ac9ddc4b22e6be492be5f43b6d3621f09 from Wed Aug 15 16:22:50 2012 +0200).
This seems to work fine, but I am running into a problem concerning the class loading. If I add the bundles contributing the exception as a dependency to org.eclipse.net4j.util, everything works as planned. This is of course not a good idea. I also tried to register the plug-ins with "Eclipse-RegisterBuddy: org.eclipse.net4j.util", but this doesn't change the effect.
I still get this exception:
java.lang.ClassNotFoundException: org.hibernate.exception.ConstraintViolationException
	at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:501) ~[org.eclipse.osgi_3.8.0.v20120529-1548.jar:na]
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421) ~[org.eclipse.osgi_3.8.0.v20120529-1548.jar:na]
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412) ~[org.eclipse.osgi_3.8.0.v20120529-1548.jar:na]
	at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107) ~[org.eclipse.osgi_3.8.0.v20120529-1548.jar:na]
	at java.lang.ClassLoader.loadClass(ClassLoader.java:247) ~[na:1.6.0_29]
	at java.lang.Class.forName0(Native Method) ~[na:1.6.0_29]
	at java.lang.Class.forName(Class.java:247) ~[na:1.6.0_29]
	at java.io.ObjectInputStream.resolveClass(ObjectInputStream.java:603) ~[na:1.6.0_29]
	at org.eclipse.net4j.util.io.ExtendedIOUtil$3.resolveClass(ExtendedIOUtil.java:154) ~[org.eclipse.net4j.util/:na]
	at java.io.ObjectInputStream.readNonProxyDesc(ObjectInputStream.java:1574) ~[na:1.6.0_29]
	at java.io.ObjectInputStream.readClassDesc(ObjectInputStream.java:1495) ~[na:1.6.0_29]
	at java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStream.java:1731) ~[na:1.6.0_29]
	at java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1328) ~[na:1.6.0_29]
	at java.io.ObjectInputStream.readObject(ObjectInputStream.java:350) ~[na:1.6.0_29]
	at org.eclipse.net4j.util.io.ExtendedIOUtil.readObject(ExtendedIOUtil.java:161) [org.eclipse.net4j.util/:na]
	at org.eclipse.net4j.util.io.ExtendedIOUtil.readObject(ExtendedIOUtil.java:110) [org.eclipse.net4j.util/:na]
	at org.eclipse.net4j.util.io.ExtendedDataInputStream.readObject(ExtendedDataInputStream.java:41) [org.eclipse.net4j.util/:na]
	at org.eclipse.net4j.util.io.ExtendedDataInput$Delegating.readObject(ExtendedDataInput.java:115) [org.eclipse.net4j.util/:na]
	at org.eclipse.emf.cdo.internal.net4j.protocol.CommitTransactionRequest.confirmingCheckError(CommitTransactionRequest.java:297) [org.eclipse.emf.cdo.net4j/:na]
	at org.eclipse.emf.cdo.internal.net4j.protocol.CommitTransactionRequest.confirming(CommitTransactionRequest.java:270) [org.eclipse.emf.cdo.net4j/:na]
	at org.eclipse.emf.cdo.internal.net4j.protocol.CommitTransactionRequest.confirming(CommitTransactionRequest.java:1) [org.eclipse.emf.cdo.net4j/:na]
	at org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientRequestWithMonitoring.confirming(CDOClientRequestWithMonitoring.java:117) [org.eclipse.emf.cdo.net4j/:na]
	at org.eclipse.net4j.signal.RequestWithMonitoring.confirming(RequestWithMonitoring.java:171) [org.eclipse.net4j/:na]
	at org.eclipse.net4j.signal.RequestWithConfirmation.doExtendedInput(RequestWithConfirmation.java:125) [org.eclipse.net4j/:na]
	at org.eclipse.net4j.signal.Signal.doInput(Signal.java:328) [org.eclipse.net4j/:na]
	at org.eclipse.net4j.signal.RequestWithConfirmation.doExecute(RequestWithConfirmation.java:105) [org.eclipse.net4j/:na]
	at org.eclipse.net4j.signal.RequestWithMonitoring.doExecute(RequestWithMonitoring.java:235) [org.eclipse.net4j/:na]
	at org.eclipse.net4j.signal.SignalActor.execute(SignalActor.java:53) [org.eclipse.net4j/:na]
	at org.eclipse.net4j.signal.Signal.runSync(Signal.java:253) [org.eclipse.net4j/:na]
	at org.eclipse.net4j.signal.SignalProtocol.startSignal(SignalProtocol.java:440) [org.eclipse.net4j/:na]
	at org.eclipse.net4j.signal.RequestWithConfirmation.doSend(RequestWithConfirmation.java:89) [org.eclipse.net4j/:na]
	at org.eclipse.net4j.signal.RequestWithConfirmation.send(RequestWithConfirmation.java:75) [org.eclipse.net4j/:na]
	at org.eclipse.net4j.signal.RequestWithMonitoring.send(RequestWithMonitoring.java:110) [org.eclipse.net4j/:na]
	at org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientProtocol.send(CDOClientProtocol.java:518) [org.eclipse.emf.cdo.net4j/:na]
	at org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientProtocol.commitTransaction(CDOClientProtocol.java:393) [org.eclipse.emf.cdo.net4j/:na]
	at org.eclipse.emf.internal.cdo.session.DelegatingSessionProtocol.commitTransaction(DelegatingSessionProtocol.java:292) [org.eclipse.emf.cdo/:na]
	at org.eclipse.emf.internal.cdo.transaction.CDOSingleTransactionStrategyImpl.commit(CDOSingleTransactionStrategyImpl.java:71) [org.eclipse.emf.cdo/:na]
	at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.commit(CDOTransactionImpl.java:1144) [org.eclipse.emf.cdo/:na]
	at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.commit(CDOTransactionImpl.java:1164) [org.eclipse.emf.cdo/:na]
	at de.emsw.emtrac.app.handlers.TestNotNullConstraintViolation.execute(TestNotNullConstraintViolation.java:83) [de.emsw.emtrac.app/:na]
I don't understand the part of the code resolving the class ... do you (or anybody else) have any idea what I could be missing?
Christoph
Re: [CDO] Exception Handling on Commit [message #902413 is a reply to message #900834] Fri, 17 August 2012 10:04 Go to previous messageGo to next message
Hi Eike,
Please have a look at the patch attached and tell me what you think. (This is a git patch on the master branch commit 5f615d8ac9ddc4b22e6be492be5f43b6d3621f09 from Wed Aug 15 16:22:50 2012 +0200).
Christoph
Re: [CDO] Exception Handling on Commit [message #902457 is a reply to message #902413] Fri, 17 August 2012 13:07 Go to previous messageGo to next message
Hi Christoph,
I think you're required to submit a bugzilla and attach your patch there. I'll look at it then ;-)
Cheers
/Eike
Am 17.08.2012 16:04, schrieb Christoph Keimel:
> Hi Eike,
> Christoph
Re: [CDO] Exception Handling on Commit [message #902474 is a reply to message #902457] Fri, 17 August 2012 15:39 Go to previous message
Feature request with the patch:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=387508
Previous Topic:XMI Resource to BinaryResourceImpl
Next Topic:Error CDO/Teneo/Postgres
Current Time: Sun Jul 27 07:56:29 EDT 2025
Powered by FUDForum. Page generated in 0.06405 seconds
