Home » Modeling » EMF » Slim Model Instance Backup
Slim Model Instance Backup [message #900567] Tue, 07 August 2012 10:48 Go to next message
Hi there,
I want to work with EMF model instances in memory mainly, i.e. I don't
need files to load the model from; I get most data from external messages.
Only in case the computer or JVM crashes, I need to restore the EMF
model where it was left before the crash.
Hence, I need a slim mechanism to synchronize all changes of the model
into a persistency solution (file, database...) which I can read in
again when starting up the application.
An EMF-framework to databases seems to be overkill, isn't it?
However, the plain XML persistency seems to be not very performant if
you save the ressource with every little change of the model.
Something like storing only the small deltas of the model would be good,
which would have very good write performance (done very often) and only
bad/medium read performance (done quite seldom).
Is there any suggestion/best practice?
Hauke
Re: Slim Model Instance Backup [message #900666 is a reply to message #900567] Wed, 08 August 2012 02:13 Go to previous message
Hauke,
Comments below.
On 07/08/2012 4:48 PM, Hauke Fuhrmann wrote:
> Hi there,
> messages.
BinaryResourceImpl produces a very compact representation that's
generally an order of magnitude faster to read and write.
> good, which would have very good write performance (done very often)
> and only bad/medium read performance (done quite seldom).
A ChangeRecorder which is able to produce a ChangeDescription which can
be serialized could serve that purpose. Perhaps looking at the JUnit
tests for that will give you the idea how to use it.
> Cheers,
> Hauke
Previous Topic:How to create Bookmark in skeleton JET
Next Topic:[CDO 4.1]Security Manager Problem
Current Time: Wed Jul 23 07:40:46 EDT 2025
Powered by FUDForum. Page generated in 0.16049 seconds
