Home » Modeling » EMF » How to create Bookmark in skeleton JET
How to create Bookmark in skeleton JET [message #900486] Tue, 07 August 2012 05:33 Go to next message
Hi Experts,
I have created skeleton where I have a lot of fields. Let's assume I have field
String CLASSNAME = "my_name";
I would like to change the name of this variable in my .jettxt file. How can I do it?
It should be like:
???? CLASSNAME="NEWCLASSNAME" ?????
Thank you in advance
[Updated on: Tue, 07 August 2012 05:47] by Moderator
Re: How to create Bookmark in skeleton [message #900510 is a reply to message #900486] Tue, 07 August 2012 06:40 Go to previous messageGo to next message
Aleksander,
I'm not sure what you're asking. It's it about JET syntax for
substitutions? E.g., <%=some-Java expression-that-yields-the-substitution%>
On 07/08/2012 11:33 AM, ALeksander Sadecki wrote:
> Hi Experts,
> have field
> How can I do it?
> It should be like: ???? CLASSNAME="NEWCLASSNAME" ?????
Re: How to create Bookmark in skeleton [message #900513 is a reply to message #900510] Tue, 07 August 2012 06:49 Go to previous messageGo to next message
Thank you for your response. I think that the easiest way to explain it will be copy code here.
My skeleton:
@Path("/ProposalREST")
public class CLASS {
  	String MyText = "text";
	@POST
	@Path("/POST")
	@Consumes(MediaType.APPLICATION_JSON)
	public Response postProposal(Proposal x) {
		return Response.status(201).entity("").build();
	@GET
	@Path("/GET")
	@Produces(MediaType.APPLICATION_JSON)
	public Proposal getProposal(Proposal x) {
		return null;
	@DELETE
	@Path("/DELETE")
	public Response deleteProposal(Proposal x) {
	@PUT
	@Path("/PUT")
	public Response putProposal(Proposal x) {
	public String dummy() {
And my jettxt file:
 jet package="REST"
 imports="import javax.ws.rs.Path javax.ws.rs.GET javax.ws.rs.Produces javax.ws.rs.core.MediaType
 javax.ws.rs.POST javax.ws.rs.core.Response javax.ws.rs.DELETE javax.ws.rs.PUT javax.ws.rs.Consumes"
 class="Proposal"
 skeleton="rest.skeleton"
In skeleton I have got MyText variable. I want to substitute name of this variable in jettxt file.
Do you know what I mean?
[Updated on: Tue, 07 August 2012 06:49] by Moderator
Re: How to create Bookmark in skeleton [message #900517 is a reply to message #900513] Tue, 07 August 2012 07:15 Go to previous messageGo to next message
Aleksander,
If I understand correctly, there's no way to change the skeleton from
the template.
On 07/08/2012 12:49 PM, ALeksander Sadecki wrote:
> My skeleton:
> @POST
> @Path("/POST")
> @GET
> @Path("/GET")
> return null;
> @DELETE
> @Path("/DELETE") @Consumes(MediaType.APPLICATION_JSON)
> @PUT
> @Path("/PUT")
> And my jettxt file:
> jet package="REST"
> class="Proposal"
> Quote:
>> Options:
>> Post Notification
>> Notify me when someone replies to this message.
Re: How to create Bookmark in skeleton [message #900526 is a reply to message #900517] Tue, 07 August 2012 07:49 Go to previous messageGo to next message
But for example I have CLASS in skeleton and in my jettxt file I have
class="Proposal"
and after build it is changed. So probably it is possible...
Maybe from another side, I would like to create JET project which generate for me code like this:
import javax.ws.rs.Consumes;
import javax.ws.rs.DELETE;
import javax.ws.rs.GET;
import javax.ws.rs.POST;
import javax.ws.rs.PUT;
import javax.ws.rs.Path;
import javax.ws.rs.Produces;
import javax.ws.rs.core.MediaType;
import javax.ws.rs.core.Response;
@Path("/YourClassRest")
	public class YourClassRest {
	@POST
	@Path("/POST")
	public Response postYourClass(YourClass x) {
	@GET
	@Path("/GET")
	public YourClass getYourClass(YourClass x) {
		return null;
	@PUT
	@Path("/PUT")
	public Response putYourClass(YourClass x) {
	@DELETE
	@Path("/DELETE")
	public void deleteYourClass(YourClass x) {
And I can give the name of YourClass. How can I do it?
Re: How to create Bookmark in skeleton [message #900531 is a reply to message #900526] Tue, 07 August 2012 08:12 Go to previous messageGo to next message
Aleksander,
Comments below.
> class="Proposal" and after build it is changed. So probably it is
> possible...
If you modify the framework in some way then in theory pretty much
anything is possible.
> @POST
> @Path("/POST")
> @GET
> @Path("/GET")
> return null;
> @PUT
> @Path("/PUT")
> @DELETE
> @Path("/DELETE") public void deleteYourClass(YourClass x) {
Maybe you should have a look at the templates in
org.eclipse.emf.codegen.ecore/templates. Of course within a template
you can do any kinds of substitutions.
Re: How to create Bookmark in skeleton [message #900532 is a reply to message #900531] Tue, 07 August 2012 08:21 Go to previous messageGo to next message
Ok, thanks. So, I do not have to use template. I can do it in another way but I have no idea how. Is it possible to generate a method for Java Class without skeletons?
Re: How to create Bookmark in skeleton [message #900664 is a reply to message #900532] Wed, 08 August 2012 02:08 Go to previous message
Aleksander,
You need templates. Did you have a look at EMF templates? Did you read
the tutorial?
Previous Topic:[CDO/Hibernate] NPE: at org.hibernate.hql.internal.ast.HqlSqlWalker.createFromJoinElement(HqlSqlWalk
Next Topic:Slim Model Instance Backup
Current Time: Sat Jul 26 11:25:36 EDT 2025
Powered by FUDForum. Page generated in 0.09433 seconds
