[CDO/Hibernate] Defining not-nullable EReferences [message #899992] |
Fri, 03 August 2012 07:27  |
Hello
I am creating a demo with CDO/Hibernate to see if all our requirements in the generated database tables can be met. So far I am doing well except for two small issues I ran into with EReferences that should be set to "not null" in the database.
To achieve this I tried to set the annotations via xml like this:
<eclass name="Assignment">
<ereference name="project">
<join-column name="project_e_id" nullable="false"/>
</ereference>
</eclass>
The "nullable" attribute seems to be ignored.
(I'm sure the file is read correctly, because other constraints on attributes work: i.e. <column nullable="false" unique="true"/>).
Environment:
- CDO 4.1.0.v20120612
- TENEO 2.0.0.v20120709
- MySQL Server 5.5.18
Related, but different: If the name attribute is omitted in the join-column element this will lead to an exception:
[ERROR] Unable to read XML
org.hibernate.InvalidMappingException: Unable to read XML
at org.hibernate.internal.util.xml.MappingReader.readMappingDocument(MappingReader.java:106)
at org.hibernate.cfg.Configuration.add(Configuration.java:477)
Caused by: org.xml.sax.SAXParseException: Attribute "name" is required and must be specified for element type "column".
at com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.createSAXParseException(ErrorHandlerWrapper.java:195)
at com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.error(ErrorHandlerWrapper.java:131)
This is only the case for join-column elements and not for column elements. This should not be required imho.
Would you like bug reports on these issues, or am I missing something?
Greetings
Christoph
Re: [CDO/Hibernate] Defining not-nullable EReferences [message #900417 is a reply to message #899992] |
Mon, 06 August 2012 19:29   |
Hi Christophe,
Sorry for the later answer, I did a testcase and issue for this:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=386607
After the next build the name attribute is not needed anymore.
For your specific issue, set nullable="true" will help (I should have seen that right away...).
gr. Martin
On 08/03/2012 01:27 PM, Christoph Keimel wrote:
> Hello
> database.
> </ereference>
> </eclass>
> unique="true"/>).
> Environment:
> Greetings
> Christoph
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [CDO/Hibernate] Defining not-nullable EReferences [message #900637 is a reply to message #900543] |
Tue, 07 August 2012 17:30   |
Hi Christophe,
I asked Ed Merks to reply on your question.
Regarding the persistence xml, instead of setting the nullable on the join column you have to use a many-to-one tag in
this case (the many-to-one again overrides the join-column one, bit unlogical but that's the way it works now...).
Like here:
<?xml version="1.0" encoding="utf-8"?>
<persistence-mapping xmlns="http://www.eclipse.org/emft/teneo"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<epackage namespace-uri="http://www.eclipse.org/emf/teneo/samples/issues/bz386607">
<eclass name="Bar">
<ereference name="foo">
<many-to-one optional="false"/>
</ereference>
</eclass>
</epackage>
</persistence-mapping>
gr. Martin
On 08/07/2012 03:12 PM, Christoph Keimel wrote:
> Hi Martin,
> I'm using xcore to define the model. I. e.:
> class Project extends CompanyElement {
> refers Assignment[] assignements opposite project
> class Assignment {
> refers Project project opposite assignements
> refers Employee employee opposite assignements
> I also tried "refers Project[1] project", to make it mandatory, but that did not have an effect on the column definition
> (nor on the generated classes). Is there another way to define mandatory attributes/references in ecore/xcore?
> Greetings
> Christoph
The Netherlands
FUDForum. Page generated in 0.04324 seconds
