Home » Archived » BIRT » How to override Page Autotext's initial value
How to override Page Autotext's initial value [message #900255] Mon, 06 August 2012 04:21 Go to next message
I just wanted to ask if there is a way on how to override the initial value of Page autotext (currently 1) to let's say 10. The reason behind this is I sliced up my report with 10 pages each (10 .rptdesign files with 10 pages each) and concatenated them with itext library. (please note that I have placed a static text on the Max page part) The problem with that is the page numbering that I have in page footer displays 1/100...10/100...1/100 (because of concatenated report)... 10/100... 1/100 and so on... My idea was to assign a default value on the Page Autotext on each of the rptdesign files so that it won't get reset on each report.
any help would be appreciated.
Re: How to override Page Autotext's initial value [message #900397 is a reply to message #900255] Mon, 06 August 2012 16:54 Go to previous messageGo to next message
Jomar,
If you are using the viewer or using separate run and render task with
the API you can do this with a simple page variable and script:
http://www.eclipse.org/birt/phoenix/project/notable2.5.php#jump_4
Attached is an example that uses a page variable on the master page that
starts at 10. Look at the onPageEnd script and look at the master page
header.
Jason
On 8/6/2012 4:21 AM, Jomar Romero wrote:
> Hello,
> each report.
Re: How to override Page Autotext's initial value [message #900398 is a reply to message #900255] Mon, 06 August 2012 16:54 Go to previous messageGo to next message
Jomar,
header.
Jason
> Hello,
> each report.
Re: How to override Page Autotext's initial value [message #900400 is a reply to message #900255] Mon, 06 August 2012 16:54 Go to previous messageGo to next message
Jomar,
header.
Jason
> Hello,
> each report.
Re: How to override Page Autotext's initial value [message #900401 is a reply to message #900255] Mon, 06 August 2012 16:54 Go to previous messageGo to next message
Jomar,
header.
Jason
> Hello,
> each report.
Re: How to override Page Autotext's initial value [message #900402 is a reply to message #900255] Mon, 06 August 2012 16:54 Go to previous messageGo to next message
Jomar,
header.
Jason
> Hello,
> each report.
Re: How to override Page Autotext's initial value [message #900403 is a reply to message #900255] Mon, 06 August 2012 16:54 Go to previous messageGo to next message
Jomar,
header.
Jason
> Hello,
> each report.
Re: How to override Page Autotext's initial value [message #900423 is a reply to message #900403] Mon, 06 August 2012 22:56 Go to previous messageGo to next message
Thanks Jason! will take a look at this and report back.
Re: How to override Page Autotext's initial value [message #1124261 is a reply to message #900423] Thu, 03 October 2013 06:51 Go to previous messageGo to next message
Hello, We want to present a report in which the page number is suppose to be group specific. I mean, Page n of m where n is the page number of page in a group and m is the total number of page of that group. We are using BIRT 2.5.1 and all our reports are all generated in PDF.
Has anyone solved this ? Please guide.
Thank you for your help.
Re: How to override Page Autotext's initial value [message #1142683 is a reply to message #1124261] Thu, 17 October 2013 15:58 Go to previous messageGo to next message
Take a look at this example from the BIRT Exchange devShare:
BIRT Exchange DevShare - Group Page Numbering
Re: How to override Page Autotext's initial value [message #1152782 is a reply to message #1142683] Thu, 24 October 2013 03:03 Go to previous message
Thank you Williams, but as you know, this is not working for when we directly go for PDF preview, any advice how to do that ?
Previous Topic:Creating printable TOC in PDF
Next Topic:Set a XML DataSource Programmatically
Current Time: Sun Jul 27 14:37:29 EDT 2025
Powered by FUDForum. Page generated in 0.05380 seconds
