Tab placement always remove most used window [message #900285] |
Mon, 06 August 2012 07:14  |
Whenever I open a new file or even just switch to an open file which doesn't fit in the tabs Eclipse always removes the tab I was coming from. This means that the least used tabs (apart from the active) tab are always visible. This is very annoying behavior as I tend to switch between several tabs. Now I have to keep selecting it from a list or else close all files I don't want displayed until all open files fit into the tab bar. I don't know if I can control this behavior but I haven't been able to find anything this issue with a quick search. Anyone else seen this behavior?
FUDForum. Page generated in 0.05582 seconds
