Home » Modeling » GMF (Graphical Modeling Framework) » Strange problem
Strange problem [message #550578] Fri, 30 July 2010 17:29 Go to next message
I have a strange problem :
When I drag and drop an element from a different jar and click save,
The Save failed the first time with the following error:
Save Failed
Cannot modify resource set without a write transaction
then when I redo the second time it works.
looks like the resource is locked or busy doing some operations how to get around of this problem ?
In fact when I save my icremental builder is executing another long task
how can I fix that so that the saving run in a different thread
java.lang.IllegalStateException: Cannot modify resource set without a write transaction
at org.eclipse.emf.transaction.impl.TransactionChangeRecorder.a ssertWriting(TransactionChangeRecorder.java:348)
at org.eclipse.emf.transaction.impl.TransactionChangeRecorder.a ppendNotification(TransactionChangeRecorder.java:302)
at org.eclipse.emf.transaction.impl.TransactionChangeRecorder.p rocessObjectNotification(TransactionChangeRecorder.java:284)
at org.eclipse.emf.transaction.impl.TransactionChangeRecorder.n otifyChanged(TransactionChangeRecorder.java:240)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify (BasicNotifierImpl.java:280)
at org.eclipse.emf.ecore.util.EcoreEList.dispatchNotification(E coreEList.java:255)
at org.eclipse.emf.common.notify.impl.NotifyingListImpl.addUniq ue(NotifyingListImpl.java:300)
at org.eclipse.emf.common.util.AbstractEList.add(AbstractEList. java:307)
at org.eclipse.emf.common.util.BasicEMap.put(BasicEMap.java:591 )
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.endSave(XMLSaveIm pl.java:292)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.save(XMLSaveImpl. java:270)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doSave(XMLRes ourceImpl.java:206)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(Resour ceImpl.java:1406)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.saveOnlyIfC hangedWithMemoryBuffer(ResourceImpl.java:1127)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(Resour ceImpl.java:980)
at org.eclipse.stp.sca.diagram.part.ScaDocumentProvider.doSaveD ocument(ScaDocumentProvider.java:723)
at org.eclipse.gmf.runtime.diagram.ui.resources.editor.document .AbstractDocumentProvider$1SaveOperation.execute(AbstractDoc umentProvider.java:596)
at org.eclipse.gmf.runtime.diagram.ui.resources.editor.document .AbstractDocumentProvider$DocumentProviderOperation.run(Abst ractDocumentProvider.java:66)
at org.eclipse.gmf.runtime.diagram.ui.resources.editor.document .AbstractDocumentProvider.executeOperation(AbstractDocumentP rovider.java:530)
at org.eclipse.gmf.runtime.diagram.ui.resources.editor.document .AbstractDocumentProvider.saveDocument(AbstractDocumentProvi der.java:579)
at org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.Di agramDocumentEditor.performSave(DiagramDocumentEditor.java:8 60)
at org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.Di agramDocumentEditor.doSave(DiagramDocumentEditor.java:680)
at org.eclipse.ui.internal.SaveableHelper$2.run(SaveableHelper. java:151)
at org.eclipse.ui.internal.SaveableHelper$5.run(SaveableHelper. java:274)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:464)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:372)
at org.eclipse.jface.window.ApplicationWindow$1.run(Application Window.java:759)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
at org.eclipse.jface.window.ApplicationWindow.run(ApplicationWi ndow.java:756)
at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow. java:2579)
at org.eclipse.ui.internal.SaveableHelper.runProgressMonitorOpe ration(SaveableHelper.java:282)
at org.eclipse.ui.internal.SaveableHelper.runProgressMonitorOpe ration(SaveableHelper.java:261)
at org.eclipse.ui.internal.SaveableHelper.savePart(SaveableHelp er.java:156)
at org.eclipse.ui.internal.EditorManager.savePart(EditorManager .java:1357)
at org.eclipse.ui.internal.WorkbenchPage.savePart(WorkbenchPage .java:3328)
at org.eclipse.ui.internal.WorkbenchPage.saveEditor(WorkbenchPa ge.java:3341)
at org.eclipse.ui.internal.SaveAction.run(SaveAction.java:76)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
at org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$6.handleEven t(ActionContributionItem.java:452)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3910)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3503)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
Re: Strange problem [message #550639 is a reply to message #550578] Tue, 03 August 2010 20:13 Go to previous messageGo to next message
I've seen this issue come up before. Saving ends up recording the
prefixes used during save in the document root's XMLNS prefix map. The
transaction framework isn't expecting that. I'm not sure how it got
resolved the last time someone asked.
> Save Failed
> write transaction
> coreEList.java:255)
> java:307)
> pl.java:292)
> java:270)
> ourceImpl.java:206)
> ceImpl.java:1406)
> ceImpl.java:980)
> rovider.java:530)
> der.java:579)
> java:151)
> java:274)
> va:372)
> Window.java:759)
> .java:70)
> ndow.java:756)
> java:2579)
> er.java:156)
> .java:1357)
> .java:3328)
> ge.java:3341)
> va:3910)
> :3503)
> a:2405)
> (Realm.java:332)
> bench.java:493)
> ava:149)
> tarter.java:368)
> tarter.java:179)
> ssorImpl.java:39)
> at java.lang.reflect.Method.invoke(Method.java:597)
Re: Strange problem [message #550901 is a reply to message #550639] Wed, 04 August 2010 11:21 Go to previous messageGo to next message
It seems the problem was resolved using ICommandProxy;
SetRequest reqSet = new SetRequest(editPart.getEditingDomain(),
SuperNode, XXX, name);
SetValueCommand operation = new SetValueCommand(reqSet);
editPart.getDiagramEditDomain().getDiagramCommandStack().exe cute(
new ICommandProxy(operation));
But My problem is I want to do two operations :
- set the name
- add another subnode
So I created two operations and followed the above code:
for operation1 and operation2 like this:
SetRequest reqSet1 = new SetRequest(editPart.getEditingDomain(),
SetValueCommand operation1 = new SetValueCommand(reqSet1);
new ICommandProxy(operation1));
SetRequest reqSet2 = new SetRequest(editPart.getEditingDomain(),
SetValueCommand operation2 = new SetValueCommand(reqSet2);
new ICommandProxy(operation2));
At this time I got the exception.
So bottom line it works for one operation but not for two.
Any hints, help ? Thanks
Re: Strange problem [message #550920 is a reply to message #550901] Wed, 04 August 2010 11:50 Go to previous messageGo to next message
The stack trace you show involves doing a save. How does that fit in
with what you're describing here?
> cute(
> - set the name
> cute(
> cute(
Re: Strange problem [message #550928 is a reply to message #550920] Wed, 04 August 2010 12:05 Go to previous messageGo to next message
Sorry for the confusion:
- The above code will be executed when I drag and drop an element to the editor.
- I got the exception when I save the changes.
- if I change the above code from two operations to one operation the exception is gone.
Re: Strange problem [message #551181 is a reply to message #550928] Thu, 05 August 2010 09:55 Go to previous messageGo to next message
None of that changes my original answer. I can't comment on why
prefixes would need to be saved in one case whereas in the other, that's
not necessary.
> the editor.
> exception is gone.
Re: Strange problem [message #900073 is a reply to message #550578] Fri, 03 August 2012 15:43 Go to previous message
I just encountered this problem. Here is the solution I came up with: do not propagate the notifications from the xmlns prefix map feature in my DocumentRootImpl like so:
     * <!-- begin-user-doc -->
     * <!-- end-user-doc -->
     * @generated NOT
    @SuppressWarnings("serial")
    public EMap<String, String> getXMLNSPrefixMap() {
        if (xMLNSPrefixMap == null) {
            xMLNSPrefixMap = new EcoreEMap<String, String>(EcorePackage.Literals.ESTRING_TO_STRING_MAP_ENTRY,
                    EStringToStringMapEntryImpl.class, null) {
                    initializeDelegateEList();
                protected void initializeDelegateEList() {
                    delegateEList = new DelegateEObjectContainmentEList<Entry<String, String>>(entryClass,
                            DocumentRootImpl.this, SwitchyardPackage.DOCUMENT_ROOT__XMLNS_PREFIX_MAP) {
                        protected void dispatchNotification(Notification notification) {
                            // don't forward the notification
        return xMLNSPrefixMap;
Previous Topic:Save As Image File JPEG and BMP formats thowing Heap Space errors
Next Topic:Single editor for multiple editor files
Current Time: Wed Sep 17 23:57:55 EDT 2025
Powered by FUDForum. Page generated in 0.04390 seconds
