How to call an EOperation in atl program? [message #899963] |
Fri, 03 August 2012 04:59  |
I defined an hexToInt(string) EOperation in the ecore diagram(within the Module class). Then I call that operation in an ATL rule.
lazy rule rule_getModule{
from
b:source!ModuleItem
to
d:target!Module(
s7ModuleReference <- b.ModuleReference,
isSelectedWithinStep7<-b.IsSelected
do{
d.deviceID<-d.hexToInt(b.getIdentNumber());
I did debug the atl program. It seems to me that ATL VM cannot find the hexToInt() operation.
This gives an error at hexToInt() operation call,
org.eclipse.m2m.atl.engine.emfvm.VMException: Operation not found: OUT!<unnamed>.hexToInt(java.lang.String)
at rule_getModule#40(TPF2PSSu2.atl[85:15-85:45])
I set source.ecore, target.ecore, input.xml and output.xml at run configuration.
Can someone help me to fix this error?
Thanks in advance.
K
Re: How to call an EOperation in atl program? [message #900575 is a reply to message #900511] |
Tue, 07 August 2012 11:37   |
Thanks.
My problem is, yes I defined EOperation (hexToInt(String)) signature at target.ecore diagram, however the EOperation is implemented at the code base, which is generated from the target.genmodel.
How to call this hexToInt() in my ATL module? This is my problem.
Can I use run configuration settings to call this operation? I do not think so, because run configuration is not linked with generated code. (is there any way to make that link?)
As the other option,
I created an ATL plugin, and trying to run as a java application.
Properties file:
# Metamodels paths or nsUris
TPF2PSSu2.metamodels.source = file:/C:/..../source.ecore
TPF2PSSu2.metamodels.target = file:/C:/.../target.ecore
loading models:
* Load the input and input/output models, initialize output models.
* @generated
public void loadModels(String inModelPath) throws ATLCoreException {
ModelFactory factory = new EMFModelFactory();
IInjector injector = new EMFInjector();
IReferenceModel sourceMetamodel = factory.newReferenceModel();
injector.inject(sourceMetamodel, getMetamodelUri("source"));
IReferenceModel targetMetamodel = factory.newReferenceModel();
injector.inject(targetMetamodel, getMetamodelUri("target"));
this.inModel = factory.newModel(sourceMetamodel);
injector.inject(inModel, inModelPath);
this.outModel = factory.newModel(targetMetamodel);
I still get the error:
at rule_getModule#40(TPF2PSSu2.atl[87:15-87:45])
Yes, I can understand, this launcher is not yet connected with the generated code.
Is there any approach to load the target meta model from the generated code?
It looks to me some modification is needed at
I really appriciate any help to solve this problem.
Kosala
[Updated on: Tue, 07 August 2012 11:41] by Moderator
Re: How to call an EOperation in atl program? [message #900669 is a reply to message #900575] |
Wed, 08 August 2012 02:23   |
Kosala,
Comments below.
On 07/08/2012 5:37 PM, Kosala Yapa wrote:
> Thanks.
> but my problem is, yes I defined EOperation at target.ecore, but the
> EOperation (hexToInt(String)) defined at the code base, which is
So you have a generated model and it compiles okay?
> How call this hexToInt() in my ATL module? This is my problem.
This is an ATL question. I don't know the answer.
I think this is an ATL question as well.
> Properties file:
> loading models:
> * @generated
> target model generated code.
In a launcher for an Eclipse application you can specify which bundles
should be part of the application.
> code?
Best you ask on the ATL newsgroup questions that are specific to ATL.
> Thanks
> Kosala
Re: How to call an EOperation in atl program? [message #900703 is a reply to message #900669] |
Wed, 08 August 2012 04:37  |
Thanks for all. I got it working.
Hope this info is useful.
I defined EOperations in the target model and load them using its URI.
code example:
public void loadModels(String inputModelPath) throws ATLCoreException{
ResourceSet resourceSet = getResourceSet();
EMFModelFactory factory = new EMFModelFactory();
//inject path of the source meta model to IReferenceModel instance
injector.inject(sourceMetamodel, this.getSourceMetamodelPath());
//inject path of the target meta model from URI to IReferenceModel instance
injector.inject(targetMetamodel, getPackage_eNS_URI());
//create new model instance and inject source model
injector.inject(inModel, inputModelPath);
//create new model instance for target model
In order to load the target model, I am using "getPackage_eNS_URI()", which gives the URI of the target model. I defined Eoperations in the target model.
Kosala
Kosala
[Updated on: Thu, 09 August 2012 04:49] by Moderator
FUDForum. Page generated in 0.06962 seconds
