Home » Eclipse Projects » Mylyn » How to get change events through Mylyn programatically?
How to get change events through Mylyn programatically? [message #899799] Thu, 02 August 2012 07:52 Go to next message
For my project I want to access the data from as many bug- and work-item repositories as possible (for development in Eclipse). Therefore I use the Mylyn plugin because it already provides a framework for efficient use of multiple sources.
If I found out right, the tasks are saved under
.metadata\.mylyn\tasks.xml.zip\tasklist.xml
and
.metadata\.mylyn\tasks\<folder>\<id>.zip\data.xml
. But I don't know how to access the data and get changes...
  • Is there a possibility to receive a notification if a task changes (e.g. if a work item status changes from CONFIRMED to SOLVED)?
  • Is it somehow possible to subscribe to the Mylyn event which shows a little notification if something changes? Or is there something like an eventlogger or resource change listener?
Thank you!
Re: How to get change events through Mylyn programatically? [message #900311 is a reply to message #899799] Mon, 06 August 2012 08:57 Go to previous messageGo to next message
the answer to the question can be found on stack overflow:
http://stackoverflow.com/questions/11774054/how-to-get-change-events-
through-mylyn-programatically
Further discussion is on the mylyn-integrators mailing list:
http://dev.eclipse.org/mhonarc/lists/mylyn-integrators/msg00988.html
Steffen
> multiple sources.
> .metadata\.mylyn\tasks.xml.zip\tasklist.xml and
> .metadata\.mylyn\tasks\<folder>\<id>.zip\data.xml. But I don't know how to
> if a work item status changes from CONFIRMED to SOLVED)? Is it somehow
> Thank you!
Steffen Pingel
Principal Software Engineer, Eclipse Mylyn Tasks Lead
http://tasktop.com
Re: How to get change events through Mylyn programatically? [message #900667 is a reply to message #900311] Wed, 08 August 2012 02:23 Go to previous message
hi Steffen
Thank you! I now can hope for some great tips and hints Smile
best regards,
André
Previous Topic:"Http error: Conflict" during validating bugzilla repository settings
Next Topic:Mylyn(Incubator) Generic Web Repository Connector
Current Time: Tue Jul 22 02:15:38 EDT 2025
Powered by FUDForum. Page generated in 0.30176 seconds
