Home » Eclipse Projects » Equinox » OSGi & DS questions
OSGi & DS questions [message #88770] Mon, 28 May 2007 10:11 Go to next message
Originally posted by: tonyhsu.tw.ibm.com
Hi I have couple questions about OSGi and DS. Could someone help to
clarify? Thanks.
Question about QSGi
I try to figure out how OSGi provides the framework for registering a
service and consuming it dynamically. In OSGi presentation, it mentions
CLDC is possible if class loaders are added in a device specific way. If
it's not a problem, how to implement a simple framework which can register
a simple (or light) service and consume it? Could someone provide
guidances?
Question about Declarative Services
from this article
http://www.eclipsezone.com/articles/extensions-vs-services/
<article>To support lazy registration, Declarative Services has the notion of
“delayed” services. When the SCR registers a delayed service, it creates a
proxy object to act as a placeholder, and registers that in the service
registry. From the point of view of a consumer, the service is now available
for use, however the bundle containing the real service implementation has not
been started yet. Then when a consumer tries to actually use the service, the
SCR detects this, and asks the OSGi runtime to fully load and activate the
bundle. It then subtitutes the proxy for the real service.</article>
According to the article, Declarative Service supports lazy registration,
but I look into the code org.eclipse.equinox.ds, it seems when someone
calls newInstance in ComponentFactory (i.e. ComponentFactoryImpl), it will
call to cd.getBundleContext().registerService to registry the service
eventually. It looks like when the service is registered, it has found the
real service and loaded it. How does it achieve the lazy registration? Or
I misunderstand the code?
Tony
Re: OSGi & DS questions [message #89973 is a reply to message #88770] Thu, 07 June 2007 12:10 Go to previous message
Originally posted by: viy.net.gmail.com
> from this article
Big thanks for the link to article. It was very helpful for me.
> notion of �delayed� services. When the SCR registers a delayed service,
> it creates a proxy object to act as a placeholder, and registers that in
> the service registry. From the point of view of a consumer, the service
> is now available for use, however the bundle containing the real service
> implementation has not been started yet. Then when a consumer tries to
> actually use the service, the SCR detects this, and asks the OSGi
> runtime to fully load and activate the bundle. It then subtitutes the
> registration, but I look into the code org.eclipse.equinox.ds, it seems
> when someone calls newInstance in ComponentFactory (i.e.
> ComponentFactoryImpl), it will call to
> the real service and loaded it. How does it achieve the lazy
> registration? Or I misunderstand the code?
As I understand from the article "delayed" (lazy) services isn't
completely implemented yet. See quote:
<quote>
Unfortunately this is not quite the case yet. The “delayed” services
feature requires some small tweaks to the basic Equinox runtime, and
these tweaks have not been implemented yet in the released version 3.2.
They do not appear at all yet (at the time of writing) in the other open
source OSGi runtimes, Apache Felix and Knopflerfish. They do appear in
the latest milestone releases of Equinox 3.3, but you may feel it is
risky to use a milestone release in a production application.</quote>
Previous Topic:Problem with configurator bundle discovery
Next Topic:Specify bundles to install in 3.3RC3
Current Time: Fri Jul 18 17:39:38 EDT 2025
Powered by FUDForum. Page generated in 0.06419 seconds
