Home » Modeling » TMF (Xtext) » NPE during serializing(NPE in PreferenceStoreWhitespaceInformationProvider.getLineSeparatorPreference(PreferenceStoreWhitespaceInformationProvider.java:56) when calling Serializer.serialize(Serializer.java:51))
icon4.gif  NPE during serializing [message #890410] Fri, 22 June 2012 04:52 Go to next message
Good day,
I have a plugin that containes 3 Xtext grammars and lets the user enter text in an EmbeddedEditor. The problem that occures on some machines now, is that for two of the three grammars, serialization of the entered text will result in a NullPointerException.
The stacktrace is the following:
!ENTRY org.eclipselabs.recommenders.codesearch.rcp 4 0 2012-06-22 09:44:31.831
!MESSAGE Error while searching. Query was: * * (java.lang.String, java.util.List)
!STACK 0
at org.eclipse.xtext.ui.editor.formatting.PreferenceStoreWhitespaceInformationProvider.getLineSeparatorPreference(PreferenceStoreWhitespaceInformationProvider.java:56)
at org.eclipse.xtext.ui.editor.formatting.PreferenceStoreWhitespaceInformationProvider.getLineSeparatorInformation(PreferenceStoreWhitespaceInformationProvider.java:46)
at org.eclipse.xtext.formatting.impl.AbstractDeclarativeFormatter.getLineSeparatorInfo(AbstractDeclarativeFormatter.java:114)
at org.eclipse.xtext.formatting.impl.AbstractDeclarativeFormatter.createFormattingConfig(AbstractDeclarativeFormatter.java:81)
at org.eclipse.xtext.formatting.impl.AbstractDeclarativeFormatter.getConfig(AbstractDeclarativeFormatter.java:92)
at org.eclipse.xtext.formatting.impl.AbstractDeclarativeFormatter.createFormatterStream(AbstractDeclarativeFormatter.java:75)
at org.eclipse.xtext.serializer.impl.Serializer.serialize(Serializer.java:103)
at org.eclipse.xtext.serializer.impl.Serializer.serialize(Serializer.java:122)
at org.eclipse.xtext.serializer.impl.Serializer.serialize(Serializer.java:51)
at org.eclipse.recommenders.codesearch.rcp.searcher.AbstractQLSearcher.serializeLuceneQuery(AbstractQLSearcher.java:40)
at org.eclipse.recommenders.codesearch.rcp.searcher.MethodPatternQLSearcher.search(MethodPatternQLSearcher.java:50)
at org.eclipse.recommenders.internal.codesearch.rcp.views.MethodPatternQLEditorWrapper.search(MethodPatternQLEditorWrapper.java:95)
at org.eclipse.recommenders.internal.codesearch.rcp.views.SearchQueryView$8.runInWorkspace(SearchQueryView.java:390)
at org.eclipse.core.internal.resources.InternalWorkspaceJob.run(InternalWorkspaceJob.java:38)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
The weird thing is that it doesn't happen on every machine so I guess, but please correct me if I'm wrong, the problem is dependant on the installed Xtext version but it's the exact same update site that my plug-in is installed from that is what confuses me.
I found this bug: bugs.eclipse.org/bugs/show_bug.cgi?id=380406 and it contains the same stacktrace and says that the problem might be grammars that have multiple entry points. The first, always working grammar, is an expression syntax which I guess has multiple entry points but again, this is the one working 100% of the time. The other two, non working, grammars have multiple entry points too. If that would solve the problem, is there a way I can define a rule as the sole entry point for a grammar?
Are there any other things I could check?
Thanks in advance,
Tobias
Re: NPE during serializing [message #890436 is a reply to message #890410] Fri, 22 June 2012 05:49 Go to previous messageGo to next message
FYI: My runtime has Xtext installed in version 2.2.1
The runtime where the problem occurs has Xtext installed in version 2.3
Re: NPE during serializing [message #892737 is a reply to message #890436] Fri, 29 June 2012 08:16 Go to previous messageGo to next message
Is there something obvious that I'm missing or did I give too little information?
Re: NPE during serializing [message #892738 is a reply to message #892737] Fri, 29 June 2012 08:17 Go to previous messageGo to next message
It is now happening on our build server too while testing:
testNegativeCase(org.eclipselabs.recommenders.test.codesearch.rcp.dslQL2.VariableIdentityTest) Time elapsed: 0.36 sec <<< ERROR!
at org.eclipse.recommenders.codesearch.rcp.searcher.CodeSnippetQLSearcher.search(CodeSnippetQLSearcher.java:59)
at org.eclipselabs.recommenders.test.codesearch.rcp.dslQL2.VariableIdentityTest.testNegativeCase(VariableIdentityTest.java:56)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:616)
at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:45)
at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:15)
at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:42)
at org.junit.internal.runners.statements.InvokeMethod.evaluate(InvokeMethod.java:20)
at org.junit.runners.ParentRunner.runLeaf(ParentRunner.java:263)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:68)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:47)
at org.junit.runners.ParentRunner$3.run(ParentRunner.java:231)
at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:60)
at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:229)
at org.junit.runners.ParentRunner.access$000(ParentRunner.java:50)
at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:222)
at org.junit.runners.ParentRunner.run(ParentRunner.java:300)
at org.apache.maven.surefire.junit4.JUnit4TestSet.execute(JUnit4TestSet.java:62)
at org.apache.maven.surefire.suite.AbstractDirectoryTestSuite.executeTestSet(AbstractDirectoryTestSuite.java:140)
at org.apache.maven.surefire.suite.AbstractDirectoryTestSuite.execute(AbstractDirectoryTestSuite.java:127)
at org.apache.maven.surefire.Surefire.run(Surefire.java:177)
at org.eclipse.tycho.surefire.osgibooter.OsgiSurefireBooter.run(OsgiSurefireBooter.java:72)
at org.eclipse.tycho.surefire.osgibooter.AbstractUITestApplication$1.run(AbstractUITestApplication.java:35)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3563)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3212)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2701)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2665)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
at org.eclipse.tycho.surefire.osgibooter.UITestApplication.runApplication(UITestApplication.java:31)
at org.eclipse.tycho.surefire.osgibooter.AbstractUITestApplication.run(AbstractUITestApplication.java:114)
at org.eclipse.tycho.surefire.osgibooter.UITestApplication.start(UITestApplication.java:37)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
I would really appreciate any help.
Thanks,Tobi
Re: NPE during serializing [message #892946 is a reply to message #892737] Mon, 02 July 2012 02:26 Go to previous messageGo to next message
Looks like you try to serialize a resource that does not have a URI.
That's pretty much of an violated invariant.
Sebastian
Am 29.06.12 14:16, schrieb Tobias Böhm:
> information?
Re: NPE during serializing [message #892954 is a reply to message #892738] Mon, 02 July 2012 03:11 Go to previous messageGo to next message
1) Does your build server run Eclipse? The
PreferenceStoreWhitespaceInformationProvider should only be bound in the
UI module, i.e. for the Equinox run scenario.
2) Code recommenders seems to kick in for a resource that has no URI
set. Maybe you have to set a URI in in the resources you create in your
tests.
Am 29.06.12 14:17, schrieb Tobias Böhm:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
> at
> at
> at
> at
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at
> at
> at
> at
> Thanks,Tobi
Re: NPE during serializing [message #899346 is a reply to message #890410] Tue, 31 July 2012 10:10 Go to previous messageGo to next message
Tobias - were you able to resolve this. I am finding the same NullPointerException when serializing, but only occasionally. I'm currently working with Xtext 2.0.1.
Re: NPE during serializing [message #899352 is a reply to message #890410] Tue, 31 July 2012 10:10 Go to previous message
Previous Topic:Outline Tree Provider
Next Topic:interdependence between your Ecore and your Grammar(editor)
Current Time: Fri Jul 25 22:26:36 EDT 2025
Powered by FUDForum. Page generated in 0.26793 seconds
