Home » Modeling » Graphiti » Pallete icons don't show up
Pallete icons don't show up [message #899269] Tue, 31 July 2012 05:38 Go to next message
Hi everyone.
I'm trying to implement a graphiti editor.
I provided a ImageProvider, my icons are in project root, I overrided getCreateImageId() and getCreateLargeImageId, but the icons don't show up in pallete. It appears a small red squares instead.
Anyone know why?
I have this:
 <extension
      point="org.eclipse.graphiti.ui.imageProviders">
   <imageProvider
         class="mainPackage.MyEditorDiagramImageProvider"
         id="mainPackage.MyEditorImageProvider">
   </imageProvider>
protected void addAvailableImages() {
	addImageFilePath(IMG_CLASSA, "icons/16/a.png");
	addImageFilePath(IMG_CLASSB, "icons/16/b.gif");
And I refer to IMG_CLASSA, and IMG_CLASSB in getCreateImageId().
But I don't know they are not show.
Thanks in advance
Re: Pallete icons don't show up [message #899281 is a reply to message #899269] Tue, 31 July 2012 06:38 Go to previous messageGo to next message
Does the the path "icons/16/" really exist in your project root?
Did you include the icons folder in the build.properties?
BR,
Matthias
Re: Pallete icons don't show up [message #899285 is a reply to message #899269] Tue, 31 July 2012 06:48 Go to previous messageGo to next message
Perhaps you only declared your image provider but not the usage if it?
In this case you must add these lines to your plugin.xml:
<extension
	point="org.eclipse.graphiti.ui.diagramTypeProviders">
	<diagramTypeProvider
		class=""
                <diagramType
			id="">
		</diagramType>
		<imageProvider
		</imageProvider>
	</diagramTypeProvider>
</extension>
BR,
Matthias
Re: Pallete icons don't show up [message #899296 is a reply to message #899285] Tue, 31 July 2012 07:52 Go to previous message
It was exactly that.
Somehow, I skipped those lines when I was reading the tutorial.
Thank you very much.
Rui
Previous Topic:Check if there is any PE at a given location in a Diagram?
Next Topic:Move Shepe
Current Time: Wed Jul 23 17:37:37 EDT 2025
Powered by FUDForum. Page generated in 0.15520 seconds
