[CDO] Usage of property 'supportingAudits' in server config [message #899062] |
Mon, 30 July 2012 08:13  |
Hello and good day,
I am new to CDO but have nevertheless been working with it for some weeks now. Right now I'm using DBStore as CDO store variant. I have come across the property 'supportingAudits' and would like to see it in action, but I couldn't find any examples to get into it faster. Could someone please provide a short HowTo so I can try it out in our application? E. g. what do I have to give an Object so it gets audited? I have the prop in cdo-server-db.xml set, but of course I need a little bit more.
Further, until now I am not sure about its functionality (supportingAudits), besides providing finer grained revisioning for the Objects. e. g. modify an obj. 5x -> get five versions of the object in the database. Is this right?
Much thanks in advance,
Uri
Re: [CDO] Usage of property 'supportingAudits' in server config [message #899116 is a reply to message #899062] |
Mon, 30 July 2012 11:04   |
Am 30.07.2012 14:13, schrieb Uri JOC:
> Hello and good day,
Welcome ;-)
I don't have the time to write a how-to about auditing but it's not that difficult. You set the supportingAudits
property to true on a *new* repository. Then, whenever your client commits changes the old revisions are not overwritten
but kept in the DB. Note, that CDOTransaction.commit() returns a CDOCommitInfo which, in turn, provides you with the
exact commit timestamp (the commit ID). You can use this timestamp (or any other timestamp between repository creation
and now) with CDOView.setTimeStamp() to look at the object graph as it was at that time.
Auditing is a repository-wide setting and can not be different for particular objects.
Yes, that sounds right.
Cheers
/Eike
http://www.esc-net.de
FUDForum. Page generated in 0.06047 seconds
