Home » Archived » Riena » ArrayIndexOutOfBoundsException after connection was interrupted
ArrayIndexOutOfBoundsException after connection was interrupted [message #899004] Mon, 30 July 2012 02:39 Go to next message
Hello
I'm using Riena to establish client server communication.
In certain cases, for example when the client machine goes into sleep mode. I get the following exception after the client tries to communicate with the server:
I would like to notify the user that the communication has been interrupted and that he has to restart the client.
Is there a nicer exception in a newer version or should I compose a feature request. I can't catch ArrayIndexOutOfBoundsException because it could be thrown from elsewhere as well.
Thanks for any help!
Flavio
java.lang.ArrayIndexOutOfBoundsException: -1
at java.util.ArrayList.remove(ArrayList.java:390) ~[na:1.6.0_33]
at com.caucho.hessian.io.HessianDebugState.popStack(HessianDebugState.java:103) ~[na:na]
at com.caucho.hessian.io.HessianDebugState$CallState.next(HessianDebugState.java:1540) ~[na:na]
at com.caucho.hessian.io.HessianDebugState.next(HessianDebugState.java:93) ~[na:na]
at com.caucho.hessian.io.HessianDebugInputStream.read(HessianDebugInputStream.java:106) ~[na:na]
at java.io.InputStream.read(InputStream.java:160) ~[na:1.6.0_33]
at com.caucho.hessian.io.Hessian2Input.readBuffer(Hessian2Input.java:2644) ~[na:na]
at com.caucho.hessian.io.Hessian2Input.read(Hessian2Input.java:2624) ~[na:na]
at com.caucho.hessian.io.Hessian2Input.startReply(Hessian2Input.java:386) ~[na:na]
at com.caucho.hessian.client.HessianProxy.invoke(HessianProxy.java:218) ~[na:na]
at $Proxy120.findById(Unknown Source) ~[na:na]
Re: ArrayIndexOutOfBoundsException after connection was interrupted [message #899006 is a reply to message #899004] Mon, 30 July 2012 03:03 Go to previous messageGo to next message
I never experienced that error. I am also a little confused that Hessian is using HessianDebugInputStream. Did you do anything about setting a LogLevel in Hessian. Anyway I would never expect you to catch an ArrayIndexOutOfBoundsException and I dont think its thrown to indicate a lost connection.
Maybe you can describe how to reproduce this error. Can please do so in a bugzilla bug report. (Bug not Enhancement) and I look into it.
Re: ArrayIndexOutOfBoundsException after connection was interrupted [message #899209 is a reply to message #899006] Tue, 31 July 2012 01:55 Go to previous messageGo to next message
Hi Christian
Thanks for your prompt reply!
I did indeed have the logging level on the server side "org.eclipse.riena.internal.communication.publisher.hessian" set to debug.
I will remove it and keep an eye on the problem.
It's a bit difficult to reproduce the exception, it happens sometimes when a connected client goes into sleep mode. After waking up the connection seems broken and such exceptions occur.
I tried to get the exception yesterday, but didn't work (having the log level set of course). I think the client needs to be in sleep mode for quite a while.
If I found out anything I will post it here.
greets Flavio
Re: ArrayIndexOutOfBoundsException after connection was interrupted [message #902816 is a reply to message #899209] Mon, 20 August 2012 11:06 Go to previous message
Am 31.07.12 07:55, schrieb Flavio Donze:
> Hi Christian
> to debug.
> greets Flavio
Or enter a bugzilla report....Replies on the newsgroup are easily lost....
christian
Previous Topic:Riena 5.0 and JDK
Next Topic:Riena + Declarative Services
Current Time: Wed Jul 23 11:26:22 EDT 2025
Powered by FUDForum. Page generated in 0.04204 seconds
