How to configure Embeded tomcat settings programatically in Virgo [message #899204] |
Tue, 31 July 2012 00:46  |
Hi I am using Virgo Tomcat Server virgo-tomcat-server-3.5.0.M04.
I want to change some of the tomcat settings of the embedded tomcat in Virgo like Port host etc dynamically.
What is the option to do that.
I tried to serach on different forums.
I tried to create a fragment having fragment-host as com.springsource.org.apache.catalina and provided the tomcat-server.xml with the new settings but VTS does not pick up these settings.
Please let me know how can it be achieved.
Re: How to configure Embeded tomcat settings programatically in Virgo [message #899621 is a reply to message #899596] |
Wed, 01 August 2012 11:22  |
My requirement is to change the tomcat port, SSL settings etc dynamically. How can I use MBeans for that? Can you please explain it to me.
Secondly why these settings will not persisted? Can you please explain about it.
Tried to add a fragment as a fragment-host for bundle org.eclipse.gemini.web.tomcat. This fragment is containing the modified tomcat-server.xml file.
I tried to add it as part of the plan org.eclipse.virgo.web.tomcat_3.5.0.M04.plan as follows:
<artifact type="configuration" name="org.eclipse.virgo.web"/>
<artifact type="bundle" name="org.eclipse.gemini.web.core" version="[2.0, 3.0)"/>
<artifact type="bundle" name="org.eclipse.gemini.web.tomcat" version="[2.0, 3.0)"/>
<artifact type="fragment" name="tomcatcustom" version="1.0"/>
<artifact type="bundle" name="org.eclipse.virgo.web.core" version="[3.0, 4.0)"/>
<artifact type="bundle" name="org.eclipse.virgo.web.dm" version="[3.0, 4.0)"/>
<artifact type="bundle" name="org.eclipse.virgo.web.tomcat.support" version="[3.0, 4.0)"/>
As this plan is part of org.eclipse.virgo.kernel.userregion.properties as part of the initialArtifacts as follows:
initialArtifacts=repository:plan/org.eclipse.virgo.kernel.userregion.springdm, repository:plan/org.eclipse.virgo.web.tomcat
When I start Virgo server I am getting following error.
[2012-08-01 14:46:52.681] start-signalling-1 <DE0005I> Started plan 'org.eclipse.virgo.kernel.userregion.springdm' version '3.0.0'.
[2012-08-01 14:46:52.978] system-artifacts <DE0000I> Installing plan 'org.eclipse.virgo.web.tomcat' version '3.0.0'.
[2012-08-01 14:46:53.024] system-artifacts <DE0000I> Installing configuration 'org.eclipse.virgo.web' version '0.0.0'.
[2012-08-01 14:46:53.478] system-artifacts <DE0000I> Installing bundle 'org.eclipse.gemini.web.core' version '2.1.0.M03'.
[2012-08-01 14:46:54.071] system-artifacts <DE0000I> Installing bundle 'org.eclipse.gemini.web.tomcat' version '2.1.0.M03'.
[2012-08-01 14:46:54.071] system-artifacts <DE0700E> Cannot find fragment 'tomcatcustom' version range '[1.0.0, oo)' in repository 'ext-usr'.
[2012-08-01 14:46:54.149] system-artifacts <DE0002E> Installation of plan 'org.eclipse.virgo.web.tomcat' version '3.0.0' failed. org.eclipse.virgo.kernel.deployer.core.DeploymentException: Deployment of plan 'org.eclipse.virgo.web.tomcat' version '3.0.0' in scope 'null'
at org.eclipse.virgo.kernel.deployer.core.internal.PlanResolver.operate(PlanResolver.java:116)
at org.eclipse.virgo.kernel.deployer.core.internal.PlanResolver.access$0(PlanResolver.java:92)
at org.eclipse.virgo.kernel.deployer.core.internal.PlanResolver$1.visit(PlanResolver.java:86)
at org.eclipse.virgo.util.common.ThreadSafeGraphNode.visitInternal(ThreadSafeGraphNode.java:193)
at org.eclipse.virgo.util.common.ThreadSafeGraphNode.visit(ThreadSafeGraphNode.java:184)
at org.eclipse.virgo.kernel.deployer.core.internal.PlanResolver.transform(PlanResolver.java:82)
at org.eclipse.virgo.kernel.install.pipeline.stage.transform.internal.TransformationStage.doProcessGraph(TransformationStage.java:54)
at org.eclipse.virgo.kernel.install.pipeline.stage.AbstractPipelineStage.process(AbstractPipelineStage.java:41)
at org.eclipse.virgo.kernel.install.pipeline.internal.StandardPipeline.doProcessGraph(StandardPipeline.java:62)
at org.eclipse.virgo.kernel.install.pipeline.internal.CompensatingPipeline.doProcessGraph(CompensatingPipeline.java:73)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.driveInstallPipeline(PipelinedApplicationDeployer.java:360)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.doInstall(PipelinedApplicationDeployer.java:184)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.install(PipelinedApplicationDeployer.java:139)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.deploy(PipelinedApplicationDeployer.java:252)
at org.eclipse.virgo.kernel.userregion.internal.InitialArtifactDeployer$ArtifactDeployingRunnable.deployArtifacts(InitialArtifactDeployer.java:156)
at org.eclipse.virgo.kernel.userregion.internal.InitialArtifactDeployer$ArtifactDeployingRunnable.run(InitialArtifactDeployer.java:146)
at java.lang.Thread.run(Thread.java:619)
Caused by: org.eclipse.virgo.kernel.deployer.core.DeploymentException: fragment 'tomcatcustom' in version range '[1.0.0, oo)' not found
at org.eclipse.virgo.kernel.deployer.core.internal.PlanResolver.obtainInstallArtifactGraph(PlanResolver.java:165)
at org.eclipse.virgo.kernel.deployer.core.internal.PlanResolver.operate(PlanResolver.java:101)
... 19 common frames omitted
[2012-08-01 14:46:54.196] system-artifacts <DE0003E> Install failed for configuration 'org.eclipse.virgo.web' version '0.0.0'.
[2012-08-01 14:46:54.196] system-artifacts <DE0003E> Install failed for bundle 'org.eclipse.gemini.web.core' version '2.1.0.M03'.
[2012-08-01 14:46:54.212] system-artifacts <DE0003E> Install failed for bundle 'org.eclipse.gemini.web.tomcat' version '2.1.0.M03'.
[2012-08-01 14:46:54.337] system-artifacts <DE0003E> Install failed for plan 'org.eclipse.virgo.web.tomcat' version '3.0.0'.
[2012-08-01 14:46:54.353] system-artifacts <UR0002E> User region failed while deploying initial artifacts. Shutting down.
[2012-08-01 14:46:54.462] System Bundle Shutdown <KE0010I> Shutdown initiated.
Please let me know. Thanks in advance!!
FUDForum. Page generated in 0.10733 seconds
