Home » Archived » Voicetools » vxml not generated properly using OpenVxml 4.0
vxml not generated properly using OpenVxml 4.0 [message #899160] Mon, 30 July 2012 13:18 Go to next message
I am new to OpenVxml. I have installed OpenVxml 4.0 on my machine and developed a simple call flow begin-->Play Prompt--> return. when I deploy the war,and try to view the vxml in the browser, this is what I see
vxml version="2.1"><form id="EndMessageForm" scope="document"><block name="EndMessageBlock"><exit/></block></form></vxml>
I tried different call-flows but everytime I am seeing the above pasted vxml in browser. Can anybody please tell me what could have gone wrong. I have tried deploying the war on tomcat as well as jboss, but getting the same result
Thanks and regards,
Amal
[Updated on: Mon, 30 July 2012 13:19] by Moderator
Re: vxml not generated properly using OpenVxml 4.0 [message #899244 is a reply to message #899160] Tue, 31 July 2012 04:26 Go to previous messageGo to next message
Hi Amal,
What URL are you using to access the application? For reference, the URL should be:
<server>:<port>/<war name>/<project name>/<entry point>
So if you had a project called 'MyDemo' with the default entry point of 'Begin' and you exported it to 'Example.war', the URL would be:
www.yourserver.com:8080/Example/MyDemo/Begin
...with the appropriate host and port ofc.
[Updated on: Tue, 31 July 2012 04:27] by Moderator
Re: vxml not generated properly using OpenVxml 4.0 [message #899537 is a reply to message #899244] Wed, 01 August 2012 06:56 Go to previous messageGo to next message
Hello Kevin,
Thanks a ton. This was really helpful. I was not giving the entry point properly. Now everything works fine.
best regards,
Amal
Re: vxml not generated properly using OpenVxml 4.0 [message #1032100 is a reply to message #899244] Tue, 02 April 2013 11:10 Go to previous messageGo to next message
I have used the same blocks Begin-->PlayPrompt-->Return
I have also used the localhost:8080/New/New/Begin.. correctly as mentioned by you..
but i dont see the prompt is playing
The first and second xmls are attached.
Could anyone pls help out...
PLEASE help me out... Many thanks in advance..
  • Attachment: second.xml
    (Size: 0.31KB, Downloaded 337 times)
  • Attachment: first.xml
    (Size: 1.03KB, Downloaded 407 times)
Re: vxml not generated properly using OpenVxml 4.0 [message #1033658 is a reply to message #1032100] Thu, 04 April 2013 09:38 Go to previous message
Arunprashath S wrote on Tue, 02 April 2013 11:10
Randy/Kevin kindly pls help,,,, Really in need of your help badly.. Please help me out
Previous Topic:'fetchtimeout' and other W3C 2.1 properties
Next Topic:Generating Vxml2.0 using OpenVxml4.0
Current Time: Wed Jul 23 17:40:25 EDT 2025
Powered by FUDForum. Page generated in 0.03510 seconds
