Home » Modeling » TMF (Xtext) » Ecore model generation - merge custom and generated java code
Ecore model generation - merge custom and generated java code [message #899040] Mon, 30 July 2012 06:16 Go to next message
Usins xtext 2.3, I would like to modify the generated java code for my grammar. I know I can use a PostProcessor to modify the model but I would prefer to use the merge feature of EMF described here www.informit.com/articles/article.aspx?p=1323360&seqNum=4 using @generated markers. I would customize the generated code and Xtext/EMF would merge grammar modifications in the java code.
If I remove the directory cleaner from my mwe2 file, the generated java classes are not modified when I change my xtext file and launch the workflow.
Do you know if this merge feature is supported by xtext and if so how can I achieve it ?
Denis
Re: Ecore model generation - merge custom and generated java code [message #899148 is a reply to message #899040] Mon, 30 July 2012 12:42 Go to previous message
hi,
what kind of changes to you want to make?
what about switching to a manally maintained metamodel.
if you want not todo the changes inline there is
generation gap support with org.eclipse.emf.mwe2.ecore.EcoreGenerator
~Christian
Previous Topic:Xtext Classpath-Based global scoping
Next Topic:Outline Tree Provider
Current Time: Sun Jul 20 20:30:21 EDT 2025
Powered by FUDForum. Page generated in 0.03030 seconds
