Home » Newcomers » Newcomers » Passing jvm arguments through windows shortcut
Passing jvm arguments through windows shortcut [message #898549] Thu, 26 July 2012 10:59 Go to next message
Hi all,
I want to run eclipse through a desktop shortcut on windows with the -Duser.timezone argument you can use on the command line.
My shortcut target looks like this:
C:\Alan\SDK\3.7.1\eclipse.exe -vm "c:\Program Files\Java\jdk1.6.0_22\bin\javaw.exe" -vmargs -Xmx512m -Xmx1024M -XX:PermSize=128M -XX:MaxPermSize=256M
As you can see I have increased memory space with the -X.. arguments. For whatever reason though I can't type -Duser.timezone=Europe/Dublin after the -vmargs entry. Is it not possible to do this through a shortcut? I can use this -D argument from the command line no problem.
Alan
Re: Passing jvm arguments through windows shortcut [message #898911 is a reply to message #898549] Sun, 29 July 2012 00:31 Go to previous messageGo to next message
I think you can pass, it may be limitation on how many character windows shortcut can contains. I usually have all Eclipse option on eclipse.ini
By the way what error are you getting ?
Re: Passing jvm arguments through windows shortcut [message #898914 is a reply to message #898549] Sun, 29 July 2012 00:31 Go to previous messageGo to next message
Re: Passing jvm arguments through windows shortcut [message #898917 is a reply to message #898549] Sun, 29 July 2012 00:31 Go to previous messageGo to next message
Re: Passing jvm arguments through windows shortcut [message #898919 is a reply to message #898549] Sun, 29 July 2012 00:31 Go to previous messageGo to next message
Re: Passing jvm arguments through windows shortcut [message #898922 is a reply to message #898549] Sun, 29 July 2012 00:31 Go to previous messageGo to next message
Re: Passing jvm arguments through windows shortcut [message #898925 is a reply to message #898549] Sun, 29 July 2012 00:31 Go to previous messageGo to next message
Re: Passing jvm arguments through windows shortcut [message #898928 is a reply to message #898549] Sun, 29 July 2012 00:31 Go to previous messageGo to next message
Re: Passing jvm arguments through windows shortcut [message #898931 is a reply to message #898549] Sun, 29 July 2012 00:31 Go to previous messageGo to next message
Re: Passing jvm arguments through windows shortcut [message #898934 is a reply to message #898549] Sun, 29 July 2012 00:31 Go to previous messageGo to next message
Re: Passing jvm arguments through windows shortcut [message #898937 is a reply to message #898549] Sun, 29 July 2012 00:31 Go to previous messageGo to next message
Re: Passing jvm arguments through windows shortcut [message #898940 is a reply to message #898549] Sun, 29 July 2012 00:31 Go to previous messageGo to next message
Re: Passing jvm arguments through windows shortcut [message #898942 is a reply to message #898549] Sun, 29 July 2012 00:31 Go to previous messageGo to next message
Re: Passing jvm arguments through windows shortcut [message #898952 is a reply to message #898911] Sun, 29 July 2012 05:19 Go to previous message
looks like some thing wrong, mods please delete duplicates messages. Thanks
Previous Topic:OSGi and Spring Web MVC
Next Topic:"Operation Failed" during remote ftp access
Current Time: Fri Jul 18 20:48:41 EDT 2025
Powered by FUDForum. Page generated in 0.11139 seconds
