Home » Archived » Buckminster » Building a p2 site for patched features/plugins
Building a p2 site for patched features/plugins [message #898901] |
Sat, 28 July 2012 22:40  |
I'm having problems building a p2 update site with patched features/plugins.
I need to build a p2 update site for Indigo with EMF 2.7 patched per:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=372608
I have cloned the 2.7 branch of EMF:
http://git.eclipse.org/gitroot/emf/org.eclipse.emf.git/
Question 1:
Is there an easy way to have buckminster materialize EMF 2.7 (from GIT) and apply the changes corresponding to a particular bugzilla fix (e.g., 372608 in this case) ?
For now, I applied the patch manually.
Now I have a modified branch of EMF 2.7.
I followed the instructions from the BuckyBook for building a p2 site; i.e., I created an org.eclipse.emf.p2 feature where I included the org.eclipse.emf.ecore feature.
When I build this, buckminster creates new versions of:
org.eclipse.emf.ecore.change
org.eclipse.emf.ecore.xmi
but it fetches from my eclipse installation the *source* plugins:
org.eclipse.emf.ecore.source
org.eclipse.emf.ecore.change.source
org.eclipse.emf.ecore.xmi.source
So in the end, the org.eclipse.emf.ecore.source will not correspond to the org.eclipse.emf.ecore as built, i.e., 2.7 + 372608
Question 2:
How should I build a p2 site such that buckminster will generate the source plugins/features from the workspace instead of materializing them from the eclipse installation?
- Nicolas.
Re: Building a p2 site for patched features/plugins [message #898947 is a reply to message #898901] |
Sun, 29 July 2012 03:29   |
Hi Nicolas
To build a modified branch, you build the modified branch, and every
single plugin from your GIT is then from the branch.
You might find the configuration for
https://hudson.eclipse.org/hudson/job/buckminster-mmt-qvto-branch-tests/
helpful since it allows a particular branch to be specified.
Ed Willink
> features/plugins.
> Question 1:
> Question 2:
> - Nicolas.
Re: Building a p2 site for patched features/plugins [message #898957 is a reply to message #898949] |
Sun, 29 July 2012 06:39   |
<html>
<head>
<meta content="text/html; charset=UTF-8" http-equiv="Content-Type">
</head>
<div class="moz-cite-prefix">Hi Nicolas<br>
<br>
It all happens via the BRANCH_NAME parameter. Below are some
screen shots of what you could see in Configure<br>
<br>
<img src="http://www.eclipse.org/forums/index.php?t=getfile&id=10933" alt=""><br>
<br>
<br>
<img src="http://www.eclipse.org/forums/index.php?t=getfile&id=10934" alt=""><br>
<br>
<img src="http://www.eclipse.org/forums/index.php?t=getfile&id=10935" alt=""><br>
<br>
<br>
<img src="http://www.eclipse.org/forums/index.php?t=getfile&id=10936" alt=""><br>
<br>
On 29/07/2012 09:27, Nicolas Rouquette wrote:<br>
</div>
<blockquote cite="mid:jv2s5u$d56$1@xxxxxxxxe.org" type="cite">Thanks
Ed but for those of us who do not have logins to Eclipse' Hudson,
we can't tell how this is done.
<br>
<br>
The problem is really basic.
<br>
<br>
Suppose I've built the org.demo.demofeature and
org.demo.demoplugin according to the instructions in ch. 13 of the
BuckyBook.
<br>
We get a p2 site that looks like this:
<br>
<br>
features/org.demo.demofeature_v1
<br>
features/org.demo.demofeature.source_v1
<br>
plugins/org.demo.demoplugin_v1
<br>
plugins/org.demo.demoplugin.source_v1
<br>
<br>
Suppose we install the above in our eclipse environment and
subsequently make changes to the source code.
<br>
Now, we want to build again but we don't get:
<br>
<br>
<br>
features/org.demo.demofeature_v2
<br>
features/org.demo.demofeature.source_v2
<br>
plugins/org.demo.demoplugin_v2
<br>
plugins/org.demo.demoplugin.source_v2
<br>
<br>
Instead, I get:
<br>
<br>
<br>
<br>
<br>
<br>
<br>
That is, buckminster has resolved *.source to the target platform
instead of generating them from the source feature/plugin.
<br>
<br>
Since there is no *.cspec/*.mspec/*.rmap in this example, it is
not clear at all how we can force buckminster to ignore the target
platform for resolving *.source.
<br>
<br>
- Nicolas.
<br>
</blockquote>
<br>
</body>
</html>
Attachment: dffdfifj.png
(Size: 29.84KB, Downloaded 241 times)
Attachment: cjfjgadi.png
(Size: 26.47KB, Downloaded 269 times)
Attachment: gbeaifde.png
(Size: 21.84KB, Downloaded 284 times)
Attachment: hicddaea.png
(Size: 56.26KB, Downloaded 300 times)
Re: Building a p2 site for patched features/plugins [message #899141 is a reply to message #898957] |
Mon, 30 July 2012 12:18   |
The problem is really about the relative priority of generating source plugins vs. resolving source plugins (e.g., from the target platform or other p2 sites).
Here is an example demonstrating the problem:
1) Follow the instructions in the BuckyBook: Chapter 13 Building a P2 site.
For the buckminster.properties, instead of:
# Where all the output should go
buckminster.output.root=${user.home}/demosite
# Where the temp files should go
buckminster.temp.root=${user.home}/tmp/demosite.tmp
# How .qualifier in versions should be replaced
qualifier.replacement.*=generator:lastRevision
use the following:
qualifier.replacement.*=generator:buildTimestamp
generator.buildTimestamp.format='v'yyyyMMdd'_'HHmm
cbi.include.source=true
The first build produces the following buckminster log:
[start org.demo.demoplugin:osgi.bundle$1.0.0.qualifier#eclipse.build]
[end org.demo.demoplugin:osgi.bundle$1.0.0.qualifier#eclipse.build]
[start org.demo.demoplugin:osgi.bundle$1.0.0.qualifier#manifest]
[end org.demo.demoplugin:osgi.bundle$1.0.0.qualifier#manifest]
[start org.demo.demoplugin:osgi.bundle$1.0.0.qualifier#bundle.jar]
[end org.demo.demoplugin:osgi.bundle$1.0.0.qualifier#bundle.jar]
[start org.demo.demofeature:eclipse.feature$1.0.0.qualifier#manifest]
[end org.demo.demofeature:eclipse.feature$1.0.0.qualifier#manifest]
[start org.demo.demofeature:eclipse.feature$1.0.0.qualifier#feature.jar]
[end org.demo.demofeature:eclipse.feature$1.0.0.qualifier#feature.jar]
[start org.demo.demoplugin:osgi.bundle$1.0.0.qualifier#source.manifest]
[end org.demo.demoplugin:osgi.bundle$1.0.0.qualifier#source.manifest]
[start org.demo.demoplugin:osgi.bundle$1.0.0.qualifier#source.bundle.jar]
[end org.demo.demoplugin:osgi.bundle$1.0.0.qualifier#source.bundle.jar]
[start org.demo.demofeature:eclipse.feature$1.0.0.qualifier#source.manifest]
[end org.demo.demofeature:eclipse.feature$1.0.0.qualifier#source.manifest]
[start org.demo.demofeature:eclipse.feature$1.0.0.qualifier#source.feature.jar]
[end org.demo.demofeature:eclipse.feature$1.0.0.qualifier#source.feature.jar]
[start org.demo.demosite:eclipse.feature$1.0.0.qualifier#copy.subfeatures]
[end org.demo.demosite:eclipse.feature$1.0.0.qualifier#copy.subfeatures]
[start org.demo.demosite:eclipse.feature$1.0.0.qualifier#copy.plugins]
[end org.demo.demosite:eclipse.feature$1.0.0.qualifier#copy.plugins]
[start org.demo.demosite:eclipse.feature$1.0.0.qualifier#manifest]
[end org.demo.demosite:eclipse.feature$1.0.0.qualifier#manifest]
[start org.demo.demosite:eclipse.feature$1.0.0.qualifier#site.p2]
[end org.demo.demosite:eclipse.feature$1.0.0.qualifier#site.p2]
This produces a site.p2 with the following:
artifacts.jar
content.jar
features/org.demo.demofeature.source_1.0.0.v20120730_1458.jar
features/org.demo.demofeature_1.0.0.v20120730_1458.jar
plugins/org.demo.demoplugin.source_1.0.0.v20120730_1458.jar
plugins/org.demo.demoplugin_1.0.0.v20120730_1458.jar
Next, I add the generated site.p2 to Eclipse and install org.demo.demofeature_1.0.0.v20120730_1458
Next, I made a simple change to the org.demo.demoplugin source code.
class ViewContentProvider implements IStructuredContentProvider {
public void inputChanged(Viewer v, Object oldInput, Object newInput) {
public void dispose() {
public Object[] getElements(Object parent) {
return new String[] { "Un", "Deux", "Trois", "Quatre" };
Next, I invoked the buckminster site.p2 action on org.demo.demosite again.
This time, I got the following log:
Now, the site has the following:
artifacts.jar
content.jar
features/org.demo.demofeature.source_1.0.0.v20120730_1507.jar
features/org.demo.demofeature_1.0.0.v20120730_1507.jar
Note that features/org.demo.demofeature_1.0.0.v20120730_1507.jar has the following:
<feature
id="org.demo.demofeature"
label="Demofeature"
version="1.0.0.v20120730_1507">
<description url="http://www.example.com/description">
[Enter Feature Description here.]
</description>
<copyright url="http://www.example.com/copyright">
[Enter Copyright Description here.]
</copyright>
<license url="http://www.example.com/license">
[Enter License Description here.]
</license>
<plugin
id="org.demo.demoplugin"
download-size="0"
install-size="0"
version="1.0.0.v20120730_1458"
unpack="false"/>
</feature>
So clearly, the org.demo.demoplugin has not been built.
- Nicolas.
Re: Building a p2 site for patched features/plugins [message #899763 is a reply to message #899141] |
Thu, 02 August 2012 05:09   |
Hello Nicolas,
just to be sure. You don't refer to a specific bundle version of
'org.demo.demoplugin' in you feature?
Matt
> other p2 sites).
> Quote:
> use the following:
> Quote:
> Quote:
> Quote:
>> artifacts.jar
>> content.jar
> Quote:
> Quote:
> Quote:
>> artifacts.jar
>> content.jar
> the following:
> Quote:
>> <?xml version="1.0" encoding="UTF-8"?>
>> <feature
>> label="Demofeature"
>> </description>
>> </copyright>
>> </license>
>> <plugin
>> download-size="0"
>> install-size="0"
>> unpack="false"/>
>> </feature>
> - Nicolas.
Re: Building a p2 site for patched features/plugins [message #899764 is a reply to message #899141] |
Thu, 02 August 2012 05:10  |
Hello Nicolas,
Matt
> other p2 sites).
> Quote:
> use the following:
> Quote:
> Quote:
> Quote:
>> artifacts.jar
>> content.jar
> Quote:
> Quote:
> Quote:
>> artifacts.jar
>> content.jar
> the following:
> Quote:
>> <feature
>> label="Demofeature"
>> </description>
>> </copyright>
>> </license>
>> <plugin
>> download-size="0"
>> install-size="0"
>> unpack="false"/>
>> </feature>
> - Nicolas.
Current Time: Sat Jul 26 12:51:34 EDT 2025
Powered by FUDForum. Page generated in 0.07243 seconds
