Home » Modeling » QVT-OML » AST Creation of QVT-O [SOLVED](Problem in XMI Serialization)
icon5.gif  AST Creation of QVT-O [SOLVED] [message #898861] Sat, 28 July 2012 07:20 Go to next message
similar to the approach discussed here ( http://dev.eclipse.org/mhonarc/lists/m2m-dev/msg00265.html ) I want to create an AST of my QVT-O scripts and to store it as an XMI file. I am already able to create the XMI file, however, when trying to open certain elements of the file, I get exceptions of the form "java.net.UnknownHostException: m2m.upb.de".
Have you any idea why this happens? (see the attached project)
Thank you and best regards
Sebastian
Files attached:
- Directly runnable eclipse project including launch configuration
-> see lsenet.de/QVTo2AST-Test.zip
[Updated on: Mon, 30 July 2012 04:51] by Moderator
Re: AST Creation of QVT-O [message #898869 is a reply to message #898861] Sat, 28 July 2012 10:10 Go to previous messageGo to next message
Oops no attachment. Post a link to e.g. DropBox if the newsgroup is
unhelpful.
Ed Willink
On 28/07/2012 12:20, Sebastian Lehrig wrote:
> Hello,
> Sebastian
> Files attached: -------------
Re: AST Creation of QVT-O [message #898871 is a reply to message #898869] Sat, 28 July 2012 11:27 Go to previous messageGo to next message
I _did_ post the attachement. you have to go this URL: lsenet.de/QVTo2AST-Test.zip
(The forum does not allow me to add external links or real attachements, that's why there is no hyperlink/ h t t p for the above URL)
Re: AST Creation of QVT-O [message #898887 is a reply to message #898871] Sat, 28 July 2012 15:44 Go to previous messageGo to next message
Downloaded successfully.
Use org.apache.commons.io so it fails to compile. But only for final
operation so I commented it out.
Using the launch configuration no problem is apparent.
Since you never posted your exception trace, I cannot comment further.
Ed Willink
> URL)
Re: AST Creation of QVT-O [message #898889 is a reply to message #898887] Sat, 28 July 2012 16:09 Go to previous messageGo to next message
Try, for instance, to validate the output file "uml2rdbms.qvto.xmi" (respectively "uml2rdbms.qvtox" if you commented out the last command). For me, it gives a lot of exceptions (note that I had to escape www and http with white spaces due to forum restrictions), e.g.:
at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:195)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:432)
at java.net.Socket.connect(Socket.java:529)
at java.net.Socket.connect(Socket.java:478)
at sun.net.NetworkClient.doConnect(NetworkClient.java:163)
at sun.net.w ww.h ttp.h ttpClient.openServer(h ttpClient.java:388)
at sun.net.w ww.h ttp.h ttpClient.openServer(h ttpClient.java:523)
at sun.net.w ww.h ttp.h ttpClient.<init>(h ttpClient.java:227)
at sun.net.w ww.h ttp.h ttpClient.New(h ttpClient.java:300)
at sun.net.w ww.h ttp.h ttpClient.New(h ttpClient.java:317)
at sun.net.w ww.protocol.h ttp.h ttpURLConnection.getNewh ttpClient(h ttpURLConnection.java:970)
at sun.net.w ww.protocol.h ttp.h ttpURLConnection.plainConnect(h ttpURLConnection.java:911)
at sun.net.w ww.protocol.h ttp.h ttpURLConnection.connect(h ttpURLConnection.java:836)
at sun.net.w ww.protocol.h ttp.h ttpURLConnection.getInputStream(h ttpURLConnection.java:1172)
at org.eclipse.emf.ecore.resource.impl.URIHandlerImpl.createInputStream(URIHandlerImpl.java:178)
at org.eclipse.emf.ecore.resource.impl.ExtensibleURIConverterImpl.createInputStream(ExtensibleURIConverterImpl.java:350)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1262)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:255)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:270)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:397)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getEObject(ResourceSetImpl.java:216)
at org.eclipse.emf.ecore.util.EcoreUtil.resolve(EcoreUtil.java:203)
at org.eclipse.emf.ecore.util.EcoreUtil.resolve(EcoreUtil.java:263)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eResolveProxy(BasicEObjectImpl.java:1483)
at org.eclipse.ocl.ecore.impl.PropertyCallExpImpl.getReferredProperty(PropertyCallExpImpl.java:90)
at org.eclipse.ocl.ecore.impl.PropertyCallExpImpl.eGet(PropertyCallExpImpl.java:145)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjectImpl.java:1021)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjectImpl.java:1013)
at org.eclipse.emf.ecore.util.EContentsEList$FeatureIteratorImpl.hasNext(EContentsEList.java:409)
at org.eclipse.emf.ecore.util.EContentsEList$FeatureIteratorImpl.next(EContentsEList.java:565)
at org.eclipse.emf.ecore.util.EObjectValidator.validate_EveryReferenceIsContained(EObjectValidator.java:790)
at org.eclipse.ocl.ecore.util.EcoreValidator.validatePropertyCallExp(EcoreValidator.java:2860)
at org.eclipse.ocl.ecore.util.EcoreValidator.validate(EcoreValidator.java:308)
at org.eclipse.emf.ecore.util.EObjectValidator.validate(EObjectValidator.java:330)
at org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostician.java:165)
at org.eclipse.emf.edit.ui.action.ValidateAction$2.validate(ValidateAction.java:287)
at org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostician.java:143)
at org.eclipse.emf.ecore.util.Diagnostician.doValidateContents(Diagnostician.java:184)
at org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostician.java:168)
at org.eclipse.emf.ecore.util.Diagnostician.doValidateContents(Diagnostician.java:180)
at org.eclipse.emf.edit.ui.action.ValidateAction.validate(ValidateAction.java:258)
at org.eclipse.emf.edit.ui.action.ValidateAction$1.run(ValidateAction.java:177)
at org.eclipse.ui.actions.WorkspaceModifyDelegatingOperation.execute(WorkspaceModifyDelegatingOperation.java:69)
at org.eclipse.ui.actions.WorkspaceModifyOperation$1.run(WorkspaceModifyOperation.java:106)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2344)
at org.eclipse.ui.actions.WorkspaceModifyOperation.run(WorkspaceModifyOperation.java:118)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:121)
The "Problems" View is full of Exceptions after the validation:
Init expression type does not conform to type of variable (self). uml2rdbms.qvto.xmi /de.upb.qvto.test/files Unknown EMF Problem
Iterator variable must have same type as source element type (<not-implemented-in-string-visitor>) uml2rdbms.qvto.xmi /de.upb.qvto.test/files Unknown EMF Problem
Iterator variable must have same type as source element type (null->any(temp1 : null | true)) uml2rdbms.qvto.xmi /de.upb.qvto.test/files Unknown EMF Problem
Iterator variable must have same type as source element type (self.null->collect(temp2 : null | null)) uml2rdbms.qvto.xmi /de.upb.qvto.test/files Unknown EMF Problem
The 'checkCollectionTypeName' invariant is violated on 'Bag Type Bag(RdbmsColumn)' uml2rdbms.qvto.xmi /de.upb.qvto.test/files Unknown EMF Problem
The 'checkCollectionTypeName' invariant is violated on 'Bag Type Bag(RdbmsSchema)' uml2rdbms.qvto.xmi /de.upb.qvto.test/files Unknown EMF Problem
The 'checkCollectionTypeName' invariant is violated on 'Ordered Set Type OrderedSet(RdbmsColumn)' uml2rdbms.qvto.xmi /de.upb.qvto.test/files Unknown EMF Problem
The 'checkCollectionTypeName' invariant is violated on 'Ordered Set Type OrderedSet(RdbmsForeignKey)' uml2rdbms.qvto.xmi /de.upb.qvto.test/files Unknown EMF Problem
The 'checkCollectionTypeName' invariant is violated on 'Ordered Set Type OrderedSet(RdbmsKey)' uml2rdbms.qvto.xmi /de.upb.qvto.test/files Unknown EMF Problem
The 'checkCollectionTypeName' invariant is violated on 'Ordered Set Type OrderedSet(RdbmsTable)' uml2rdbms.qvto.xmi /de.upb.qvto.test/files Unknown EMF Problem
The 'checkCollectionTypeName' invariant is violated on 'Ordered Set Type OrderedSet(UmlAssociation)' uml2rdbms.qvto.xmi /de.upb.qvto.test/files Unknown EMF Problem
The 'checkCollectionTypeName' invariant is violated on 'Ordered Set Type OrderedSet(UmlAttribute)' uml2rdbms.qvto.xmi /de.upb.qvto.test/files Unknown EMF Problem
The 'checkCollectionTypeName' invariant is violated on 'Ordered Set Type OrderedSet(UmlClass)' uml2rdbms.qvto.xmi /de.upb.qvto.test/files Unknown EMF Problem
The 'checkCollectionTypeName' invariant is violated on 'Ordered Set Type OrderedSet(UmlPackageElement)' uml2rdbms.qvto.xmi /de.upb.qvto.test/files Unknown EMF Problem
The 'checkCollectionTypeName' invariant is violated on 'Sequence Type Sequence(RdbmsColumn)' uml2rdbms.qvto.xmi /de.upb.qvto.test/files Unknown EMF Problem
The 'checkCollectionTypeName' invariant is violated on 'Sequence Type Sequence(RdbmsTable)' uml2rdbms.qvto.xmi /de.upb.qvto.test/files Unknown EMF Problem
The 'checkCollectionTypeName' invariant is violated on 'Set Type Set(RdbmsColumn)' uml2rdbms.qvto.xmi /de.upb.qvto.test/files Unknown EMF Problem
The 'checkCollectionTypeName' invariant is violated on 'Set Type Set(UmlPackage)' uml2rdbms.qvto.xmi /de.upb.qvto.test/files Unknown EMF Problem
The 'checkPropertyType' invariant is violated on 'Property Call Exp' uml2rdbms.qvto.xmi /de.upb.qvto.test/files Unknown EMF Problem
The feature 'context' of 'Contextual Property leafAttributes' contains an unresolved proxy 'org.eclipse.emf.ecore.impl.EClassImpl@6533b295{h ttp://m2m.upb.de/SimpleUML/1.0#//UmlClass}' uml2rdbms.qvto.xmi /de.upb.qvto.test/files Unknown EMF Problem
The feature 'eClassifier' of 'null' contains an unresolved proxy 'org.eclipse.emf.ecore.impl.EClassImpl@10098d8d{h ttp://m2m.upb.de/SimpleUML/1.0#//UmlPackage}' uml2rdbms.qvto.xmi /de.upb.qvto.test/files Unknown EMF Problem
The feature 'eClassifier' of 'null' contains an unresolved proxy 'org.eclipse.emf.ecore.impl.EClassImpl@10234334{h ttp://m2m.upb.de/SimpleRDBMS/1.0#//RdbmsColumn}' uml2rdbms.qvto.xmi /de.upb.qvto.test/files Unknown EMF Problem
The feature 'eClassifier' of 'null' contains an unresolved proxy 'org.eclipse.emf.ecore.impl.EClassImpl@11acbb9c{h ttp://m2m.upb.de/SimpleUML/1.0#//UmlClass}' uml2rdbms.qvto.xmi /de.upb.qvto.test/files Unknown EMF Problem
The feature 'eClassifier' of 'null' contains an unresolved proxy 'org.eclipse.emf.ecore.impl.EClassImpl@141da37b{h ttp://m2m.upb.de/SimpleRDBMS/1.0#//RdbmsTable}' uml2rdbms.qvto.xmi /de.upb.qvto.test/files Unknown EMF Problem
The feature 'eClassifier' of 'null' contains an unresolved proxy 'org.eclipse.emf.ecore.impl.EClassImpl@17dff4dd{h ttp://m2m.upb.de/SimpleRDBMS/1.0#//RdbmsTable}' uml2rdbms.qvto.xmi /de.upb.qvto.test/files Unknown EMF Problem
The feature 'eClassifier' of 'null' contains an unresolved proxy 'org.eclipse.emf.ecore.impl.EClassImpl@19032e1b{h ttp://m2m.upb.de/SimpleRDBMS/1.0#//RdbmsColumn}' uml2rdbms.qvto.xmi /de.upb.qvto.test/files Unknown EMF Problem
The feature 'eClassifier' of 'null' contains an unresolved proxy 'org.eclipse.emf.ecore.impl.EClassImpl@19907d57{h ttp://m2m.upb.de/SimpleRDBMS/1.0#//RdbmsForeignKey}' uml2rdbms.qvto.xmi /de.upb.qvto.test/files Unknown EMF Problem
The feature 'eClassifier' of 'null' contains an unresolved proxy 'org.eclipse.emf.ecore.impl.EClassImpl@19fece6b{h ttp://m2m.upb.de/SimpleUML/1.0#//UmlPackage}' uml2rdbms.qvto.xmi /de.upb.qvto.test/files Unknown EMF Problem
The feature 'eClassifier' of 'null' contains an unresolved proxy 'org.eclipse.emf.ecore.impl.EClassImpl@1a31153e{h ttp://m2m.upb.de/SimpleUML/1.0#//UmlClassifier}' uml2rdbms.qvto.xmi /de.upb.qvto.test/files Unknown EMF Problem
The feature 'eClassifier' of 'null' contains an unresolved proxy 'org.eclipse.emf.ecore.impl.EClassImpl@1c18ac6c{h ttp://m2m.upb.de/SimpleRDBMS/1.0#//RdbmsTable}' uml2rdbms.qvto.xmi /de.upb.qvto.test/files Unknown EMF Problem
The feature 'eClassifier' of 'null' contains an unresolved proxy 'org.eclipse.emf.ecore.impl.EClassImpl@1cd66f79{h ttp://m2m.upb.de/SimpleRDBMS/1.0#//RdbmsColumn}' uml2rdbms.qvto.xmi /de.upb.qvto.test/files Unknown EMF Problem
The feature 'eClassifier' of 'null' contains an unresolved proxy 'org.eclipse.emf.ecore.impl.EClassImpl@1e0376bd{h ttp://m2m.upb.de/SimpleRDBMS/1.0#//RdbmsColumn}' uml2rdbms.qvto.xmi /de.upb.qvto.test/files Unknown EMF Problem
The feature 'eClassifier' of 'null' contains an unresolved proxy 'org.eclipse.emf.ecore.impl.EClassImpl@1fc7fb71{h ttp://m2m.upb.de/SimpleRDBMS/1.0#//RdbmsColumn}' uml2rdbms.qvto.xmi /de.upb.qvto.test/files Unknown EMF Problem
The feature 'eClassifier' of 'null' contains an unresolved proxy 'org.eclipse.emf.ecore.impl.EClassImpl@201a4461{h ttp://m2m.upb.de/SimpleUML/1.0#//UmlClassifier}' uml2rdbms.qvto.xmi /de.upb.qvto.test/files Unknown EMF Problem
The feature 'eClassifier' of 'null' contains an unresolved proxy 'org.eclipse.emf.ecore.impl.EClassImpl@2068941e{h ttp://m2m.upb.de/SimpleUML/1.0#//UmlPackage}' uml2rdbms.qvto.xmi /de.upb.qvto.test/files Unknown EMF Problem
Re: AST Creation of QVT-O [message #898899 is a reply to message #898889] Sat, 28 July 2012 18:41 Go to previous messageGo to next message
Sebastian,
I think the problem here gets down to development vs runtime instances
of Eclipse. The problem seems to be that the model referenced by
http://m2m.upb.de/SimpleUML/1.0 is obviously not installed into the
Eclipse development environment. So if you try and load the XMI in it
it cannot find the referenced Ecore model in the registry (where as the
Ecore and QVTO models themselves are registered by their installe
dplugins so it finds them fine). When it cannot find the registered
package it treats it as a URL and trys to actually goto the website
http://m2m.upb.de/SimpleUML/1.0 and fails as m2m.upb.de is not a
registered domain (interestingly I'm current using airport WiFi that
resolves any invalid URL to their search provider so I get a
FileNotFoundException - i.e. a 404 error - rather than
UnknownHostException)
If you started up a new instance of Eclipse within Eclipse that had
your EPackage registered then it should validate the XMI fine as it
will be able to resolve the EPackage from the URI.
Alan
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> EMF Problem
> EMF Problem
> Unknown EMF Problem
> Unknown EMF Problem
> Unknown EMF Problem
> Unknown EMF Problem
> Unknown EMF Problem
> EMF Problem
> Problem
> an unresolved proxy
> mailto:'org.eclipse.emf.ecore.impl.EClassImpl@6533b295{h
> mailto:'org.eclipse.emf.ecore.impl.EClassImpl@10098d8d{h
> mailto:'org.eclipse.emf.ecore.impl.EClassImpl@10234334{h
> mailto:'org.eclipse.emf.ecore.impl.EClassImpl@11acbb9c{h
> mailto:'org.eclipse.emf.ecore.impl.EClassImpl@141da37b{h
> mailto:'org.eclipse.emf.ecore.impl.EClassImpl@17dff4dd{h
> mailto:'org.eclipse.emf.ecore.impl.EClassImpl@19032e1b{h
> mailto:'org.eclipse.emf.ecore.impl.EClassImpl@19907d57{h
> mailto:'org.eclipse.emf.ecore.impl.EClassImpl@19fece6b{h
> mailto:'org.eclipse.emf.ecore.impl.EClassImpl@1a31153e{h
> mailto:'org.eclipse.emf.ecore.impl.EClassImpl@1c18ac6c{h
> mailto:'org.eclipse.emf.ecore.impl.EClassImpl@1cd66f79{h
> mailto:'org.eclipse.emf.ecore.impl.EClassImpl@1e0376bd{h
> mailto:'org.eclipse.emf.ecore.impl.EClassImpl@1fc7fb71{h
> mailto:'org.eclipse.emf.ecore.impl.EClassImpl@201a4461{h
> mailto:'org.eclipse.emf.ecore.impl.EClassImpl@2068941e{h
Re: AST Creation of QVT-O [message #898974 is a reply to message #898899] Sun, 29 July 2012 16:18 Go to previous messageGo to next message
Thanks Alan, you were right; several problems came from this issue and I was able to fix them. I created genmodels for the metamodels and generated the model code. I also exported the respective ModelPackages. After this, the runtime-workspace had access to the metamodel URLs (for instance, they now appear in the metamodel explorer).
However, five exceptions remain when validating the XMI file created by my small program (see exceptions list below). I have therefore some new questions in mind:
1) As the static analysis successfully validates my qvto script, I would expect that the created XMI file is valid, too. Why is this not the case? Respectively, how to fix the remaining Exceptions?
2) The way I fixed the first issues is not optimal because it requires to create genmodels, model code, and to start a runtime-instance of eclipse. Is it possible to
a) reference the models relative to the project (e.g., "../../metamodel/UML2RDBMS/SimpleUML.ecore") within the created XMI file instead of using the NS URIs? How to tell this the "ExeXMISerializer" then?
b) fix the issues without starting a new eclipse instance?
Sebastian
The 5 remaining Exceptions:
- The opposite features 'ePackage' of 'Operational Transformation Uml2Rdb' and 'eClassifiers' of 'Operational Transformation Uml2Rdb' do not refer to each other uml2rdbms.qvto.xmi /de.upb.m2m.quality.casestudies/qvto/UML2RDBMS Unknown EMF Problem
- The referred type (UmlPackage -> UmlModelElement [SimpleUML.UmlPackage]) doesn't conform to the source collection element type (Element) uml2rdbms.qvto.xmi /de.upb.m2m.quality.casestudies/qvto/UML2RDBMS Unknown EMF Problem
- The required feature 'eFactoryInstance' of 'Operational Transformation Uml2Rdb' must be set uml2rdbms.qvto.xmi /de.upb.m2m.quality.casestudies/qvto/UML2RDBMS Unknown EMF Problem
- The required feature 'instantiatedClass' of 'Object Exp result' must be set uml2rdbms.qvto.xmi /de.upb.m2m.quality.casestudies/qvto/UML2RDBMS Unknown EMF Problem
Re: AST Creation of QVT-O [message #898976 is a reply to message #898974] Sun, 29 July 2012 17:09 Go to previous messageGo to next message
The 'correct' solution if you want to use project resources is to use
platform/resource/... URIs.
But you will need to set them up for standalone usage (use OCL's
ProjectMap) and seemingly QVTo does not support direct absolute URIs.
Raise a Bugzilla.
A tacky solution is to change the nsURIs just before the save.
umlPackage.setNsURI("SimpleUML.ecore");
rdbmsPackage.setNsURI("SimpleRDBMS.ecore");
// Save compiled transformation
try {
ExeXMISerializer.saveUnitXMI(new CompiledUnit[] {unit},
registry);
The remaining 5 errors look like 'features'. The two pairs seem benign
corrolaries of extending Ecore; unwanted constraints have been
inherited. The bad collection type may just be a bad message. Raise a
Bugzilla.
Since *.qvtox is not a published API, users use it at their own risk. It
is internal and proprietary and very unlikely to survive any evolution
of QVTo. Only use it for transient purposes.
Ed Willink
Re: AST Creation of QVT-O [message #899025 is a reply to message #898976] Mon, 30 July 2012 04:40 Go to previous messageGo to next message
Thank you Ed, your "tacky solution" did the job for me. I'm just working on a prototype, so accessing the internal APIs is okay for the time being. However, I hope the AST to XMI serialization will make it to the public APIs since it is a nice way to enable higher-order transformations.
Sebastian
Re: AST Creation of QVT-O [message #899026 is a reply to message #899025] Mon, 30 July 2012 04:54 Go to previous message
XMI serialization is an OMG specification conformance point, but
currently OCL and consequently QVT serialization is underspecified and
unrealizable.
Eclipse OCL is moving towards a credible UML-aligned prototype of
perhaps OCL 2.5. Once Eclipse OCL is OMG compliant, we can look toward
QVT compliance.
Ed Willink
> transformations.
> Regards
> Sebastian
Previous Topic:Late resolve problem
Next Topic:Different versions - same metamodel
Current Time: Thu Jul 24 19:21:13 EDT 2025
Powered by FUDForum. Page generated in 0.03727 seconds
