Home » Archived » Jubula » HTML: Manually specify component id and/or XPath
HTML: Manually specify component id and/or XPath [message #896689] Thu, 19 July 2012 07:57 Go to next message
When designing testcases with Jubula's HTML feature set, it would be extremely helpful to be able to set a technical component manually by specifying
  1. it's unique HTML-id-Tag
  2. its position in DOM by XPath
For a number of components the current solution ("Click in Browser") works well for about 2/3 of the time, but fails for 1/3, which renders some HTML-testing inaccessible to Jubula.
Depending on the availability of id-Tags in (dynamic) HTML-pages, both technical component selection criteria (either XPath or id) would be of great help.
I understand that this is fully supported in Selenium, which is used internally by Jubula.
Therefore two questions:
  1. Is technical component selection based on manually entering an id and/or XPath currently possible?
  2. If not: Is this on Jubula's feature roadmap?
Re: HTML: Manually specify component id and/or XPath [message #898282 is a reply to message #896689] Thu, 26 July 2012 02:37 Go to previous messageGo to next message
you can set the ID tag in the AUT configuration. This doesn't mean that you don't need to perform the mapping, but it does mean that the unique ID will be used for component recognition.
In terms of the X-path, I don't think there's anything in there. Would setting the Xpath mean that any changes to the component hierarchy result in it not being found? That would seem quite brittle to me ....
Alex
Re: HTML: Manually specify component id and/or XPath [message #898882 is a reply to message #896689] Sat, 28 July 2012 15:19 Go to previous messageGo to next message
I saw the Jubula demo on testautomation day, Rotterdam NL.
I really like this frame work...Just drag and drop a keyword driven test! I succeeded to complete the tututorial...however when i start using it on my own SUT (HTML/AJAX Based application) i was not able to any object mapping Crying or Very Sad ...so is it possible to add objects manual, with xpath, or an id , because within plain selenium its's possible to "pass" the logon screen like:
selenium.type("id=inputUsername", "cordys");
selenium.type("id=inputPassword", "cordys123");
selenium.click("id=buttonOK");
...like the first post in this thread, will become xpath available, or can we do manual object edit/mapping
Arjan
Re: HTML: Manually specify component id and/or XPath [message #899545 is a reply to message #898882] Wed, 01 August 2012 07:21 Go to previous messageGo to next message
You should be able to perform the object mapping if the components are of types already recognized by Jubula. What kinds of components are they, and how are they defined?
Alex
Re: HTML: Manually specify component id and/or XPath [message #900143 is a reply to message #898282] Sat, 04 August 2012 12:17 Go to previous message
The AUT-ID seems to be something quite different from the HTML-id-tag. Are you really sure?
Regarding XPath: When using AJAX-frameworks like extJS etc., the page structure is stable, while the ids are not. Also, e.g. extJS does not render comboboxes as HTML-selects, but as complex div-encapsulations. Jubula's way of "click-to-map" is not reliable here, since usually the wrong HTML-element is chosen (due to the complex encapsulations produced by mentioned typical AJAX frameworks). Therefore, XPath is the most promising way to efficiently map logical to technical components here.
Jubula should definitely support both HTML-id-tags and XPath (and also CSS-path-locators).
Surely this should pose no difficult task, since Selenium already _does_ support all those means of locating elements within a given HTML page: Jubula is based on Selenium!
Previous Topic:My AUT does not start by testexec during Test Job
Next Topic:Support for current Firefox-Releases
Current Time: Fri Jul 25 23:02:00 EDT 2025
Powered by FUDForum. Page generated in 0.04535 seconds
