Juno won't load [message #898592] |
Thu, 26 July 2012 14:14  |
If I launch Juno (Eclipse Classic 4.2, straight from unzip nothing else installed). The load process continues to the Select Workspace window. After selecting the workspace, the small progress bar appears VERY briefly under the small splash window and then the splash disappears and the process is dead.
I am on Windows 7. I have an Eclipse 3.7 install that works, no problem. Juno was working on my system, and then the above issue appeared. I have deleted the Juno folder, and re-unzipped (As well as trying re-downloading, reving my Java install etc) with no luck.
Can anyone suggest a new debug step / what to try next?
Re: Juno won't load [message #898664 is a reply to message #898592] |
Fri, 27 July 2012 02:42  |
Terry,
Maybe you're running out of memory or permgen space. You can edit the
eclipse.ini to increase those numbers.
FUDForum. Page generated in 0.07973 seconds
