Home » Eclipse Projects » Virgo » Virgo and Gemini JPA plan failed
Virgo and Gemini JPA plan failed [message #898320] Thu, 26 July 2012 04:12 Go to next message
When I create a plan containing Gemini-jpa (+dbacess & eclipselink) deps, Spring-data-jpa deps and after my model bundle, it fails telling me that it cannot create singleton when dependency state is closing.
When I Create a plan with just Gemini Jpa deps, and an other with spring-data-jpa ones + my model ones, then put them in the pickup folder one after the other (gemini first), it works like a charm.
I hacked the issue in starting the gemini jpa plan in the userregion and the project works fine.
Are you aware about this issue?
Is it a Virgo one (my version is 3.0.3), or a Gemini one (1.0.0.RELEASE)?
Re: Virgo and Gemini JPA plan failed [message #898585 is a reply to message #898320] Thu, 26 July 2012 13:00 Go to previous messageGo to next message
Gemini JPA documentation [1] recommends startup order, so I guess this is part of the issue you are seeing.
Please note that this ordering is required for weaving and your bundle may be refreshed as a side effect. All this may furhter contribute to/complicate the issue.
[1] http://wiki.eclipse.org/Gemini/JPA/Documentation/OtherTopics#Installing_and_Starting_Applications
[Updated on: Thu, 26 July 2012 13:01] by Moderator
Re: Virgo and Gemini JPA plan failed [message #898671 is a reply to message #898585] Fri, 27 July 2012 02:55 Go to previous message
I can't use LT weaving for this reason, with this issue, I'm using BT weaving.
Previous Topic:how to integrate spring security into virgo
Next Topic:Virgo Bundlor and Class Inheritance across Bundles
Current Time: Sun Jul 27 13:48:43 EDT 2025
Powered by FUDForum. Page generated in 0.23353 seconds
