Home » General (non-technical) » Eclipse Foundation » download to have support at least for old ver. 1.2 java version JDK(can add jdk eg 1.2(old) if no support)
download to have support at least for old ver. 1.2 java version JDK [message #898580] Thu, 26 July 2012 12:51 Go to next message
what latest eclipse version can download to have support at least for old ver. 1.2 java version JDK? can same time have support for JDK 7? can add jdk eg 1.2(old) if no support?
Re: download to have support at least for old ver. 1.2 java version JDK [message #898658 is a reply to message #898580] Fri, 27 July 2012 02:19 Go to previous messageGo to next message
What exactly do you mean by "support"? The latest version (JUno) can
generate class files that are compatible with 1.2.
Dani
Re: download to have support at least for old ver. 1.2 java version JDK [message #898673 is a reply to message #898658] Fri, 27 July 2012 03:01 Go to previous messageGo to next message
I MEAN IF I HAVE A JAVA SE/EE PROJECT, eclipse can compile/run/appear output...
Are you sure? where can found this jdk min info? I think is 1.3 jdk the min...for Juno or indigo... where find it...?
[Updated on: Fri, 27 July 2012 03:12] by Moderator
Re: download to have support at least for old ver. 1.2 java version JDK [message #898676 is a reply to message #898673] Fri, 27 July 2012 03:21 Go to previous messageGo to next message
> output...
> the min...
You need to uncheck 'Use default compliance' on the compiler page and on
the 'Installed JREs' you can install your 1.2 (or whatever) JRE. Note
though that for starting the latest Eclipse IDE you will need JRE 1.6 or
higher.
Dani
Re: download to have support at least for old ver. 1.2 java version JDK [message #898677 is a reply to message #898673] Fri, 27 July 2012 03:25 Go to previous messageGo to next message
anyway what eclipse ide the min, run by default(without additions) 1.2 jdk/jre and up? to this can installed jdk/jre 7?
[Updated on: Fri, 27 July 2012 03:25] by Moderator
Re: download to have support at least for old ver. 1.2 java version JDK [message #898695 is a reply to message #898677] Fri, 27 July 2012 04:54 Go to previous messageGo to next message
Leonidas,
It looks to me that the latest Eclipse, which itself needs 1.6 to run,
allows you to install any JRE via Window->Preferences->Java->Installed
JREs. I suppose you'll want to make that 1.2 JRE your default. In the
Window->Preferences->Java->Compiler you can uncheck "Use default
compliance settings and pick 1.2 for "Generated .class files
compatibility" and "1.3" for "Source compatibility"; I suppose there
were source language changes between 1.2 and 1.3. That should do the
trick I think. Don't confuse the JRE the IDE needs to install, with the
JRE you want to target when developing Java code in that IDE.
On 27/07/2012 9:25 AM, Leonidas Savvides wrote:
> anyway what eclipse ide the min, run by default 1.2 jdk/jre and up? to
Re: download to have support at least for old ver. 1.2 java version JDK [message #898733 is a reply to message #898695] Fri, 27 July 2012 07:40 Go to previous messageGo to next message
jdk do compilation and jre run the Java App?
Where look for supported jdk/jre by ide<> also to choose what constantly run? if install 1.2 (run when choose only default 1.6) it will seem?
[Updated on: Fri, 27 July 2012 07:40] by Moderator
Re: download to have support at least for old ver. 1.2 java version JDK [message #898748 is a reply to message #898733] Fri, 27 July 2012 08:38 Go to previous message
Leonidas,
Comments below.
On 27/07/2012 1:40 PM, Leonidas Savvides wrote:
> jdk do compilation
JDT has its own built-in incremental compiler. It does the compilation
and uses the preferences I pointed out.
The JRE used to run the application depends on the JRE you have
configured/installed for use the the IDE, again using the preference I
pointed out.
> Where look for supported jdk/jre?
All are supported.
I can't make sense of this question. Have you tried to follow any of
the instructions you've been given?
Previous Topic:Can't install Spring from Eclipse Marketplace
Next Topic:Voting feature in Eclipse Bugzilla
Current Time: Wed Sep 24 14:01:34 EDT 2025
Powered by FUDForum. Page generated in 0.05218 seconds
