Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [texo] Not possible to determine id eattribute for eClass ...
[texo] Not possible to determine id eattribute for eClass ... [message #898559] Thu, 26 July 2012 11:27 Go to next message
I am trying to execute a named query using HTTP PUT as described at [1], but getting this error message:
Not possible to determine id eattribute for eClass org.eclipse.emf.ecore.impl.EClassImpl@2799bfd1 (name: QueryType) (instanceClassName: null) (abstract: false, interface: false)
The data sent is:
  "_eclass": "request|QueryType",
  "query": "select t from MyType t where t.id = 1",
  "parameters": []
What do I miss?
Links:
[1] http://wiki.eclipse.org/Texo/JSON_REST_Web_Services#.28Named.29_Query_in_posted_json_with_parameters
Re: [texo] Not possible to determine id eattribute for eClass ... [message #898577 is a reply to message #898559] Thu, 26 July 2012 11:59 Go to previous messageGo to next message
Hi Erdal,
Strange that it tries to get the id of the QueryType which is not a jpa enabled thing.
Can you post the complete stacktrace?
gr. Martin
> The data sent is:
> "parameters": []
> What do I miss?
> Links:
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [texo] Not possible to determine id eattribute for eClass ... [message #898578 is a reply to message #898577] Thu, 26 July 2012 12:04 Go to previous messageGo to next message
Here is the stack trace:
java.lang.IllegalStateException: Not possible to determine id eattribute for eClass org.eclipse.emf.ecore.impl.EClassImpl@6cd835cd (name: QueryType) (instanceClassName: null) (abstract: false, interface: false)
	at org.eclipse.emf.texo.provider.IdProvider.getCreateIdEAttribute(IdProvider.java:205)
	at org.eclipse.emf.texo.provider.IdProvider.getId(IdProvider.java:81)
	at org.eclipse.emf.texo.store.ObjectStore.isNew(ObjectStore.java:191)
	at org.eclipse.emf.texo.server.service.UpdateInsertModelOperation.internalExecute(UpdateInsertModelOperation.java:90)
	at org.eclipse.emf.texo.server.service.ModelOperation.execute(ModelOperation.java:48)
	at org.eclipse.emf.texo.server.web.WebServiceHandler.doPost(WebServiceHandler.java:107)
	at org.eclipse.emf.texo.server.web.WebServiceServlet.doPost(WebServiceServlet.java:65)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:641)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:722)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:304)
	at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210)
	at org.eclipse.emf.texo.server.store.CurrentEntityManagerRequestFilter.doFilter(CurrentEntityManagerRequestFilter.java:65)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243)
	at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:240)
	at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:164)
	at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:462)
	at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:164)
	at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:100)
	at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:562)
	at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118)
	at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:395)
	at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:250)
	at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:188)
	at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:166)
	at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:302)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
Just had a look at QueryType: it is a jpa entity, but it is missing an id attribute... Though, it should not try to persist/insert the request as you say.
Martin taal wrote on Thu, 26 July 2012 11:59
Hi Erdal,
gr. Martin
Re: [texo] Not possible to determine id eattribute for eClass ... [message #898602 is a reply to message #898578] Thu, 26 July 2012 16:35 Go to previous messageGo to next message
Hi Erdal,
This seems to be a bug, I solved it and published a new build which you can try.
gr. Martin
> false)
> at
>> Hi Erdal,
>> gr. Martin
The Netherlands
Re: [texo] Not possible to determine id eattribute for eClass ... [message #898693 is a reply to message #898602] Fri, 27 July 2012 04:40 Go to previous message
Yes, the latest build works!
Previous Topic:[Texo] Abstract schema type is unknown
Next Topic:[texo] git repo unavailable
Current Time: Sun Jul 27 11:43:38 EDT 2025
Powered by FUDForum. Page generated in 0.04282 seconds
