Search Query Error [message #898527] |
Thu, 26 July 2012 10:16  |
How can i create a (search & like) using "Eclipse Link- 2.4.0"
Is there any option to solve this, If not this may be a bub of "Eclipse Persistence Services - 2.4.0".
Used
try {
Query q = em.createQuery("SELECT t FROM Teacher AS t WHERE t.name like:name");
q.setParameter("name", "Am%");
System.out.println("Size:"+q.getResultList().size());
} catch (Exception e) {
e.printStackTrace();
java.lang.IllegalArgumentException: An exception occurred while creating a query in EntityManager:
Exception Description: Syntax error parsing [SELECT t FROM Teacher AS t WHERE t.name like:name].
[33, 49] The expression is not a valid conditional expression.
at org.eclipse.persistence.internal.jpa.EntityManagerImpl.createQuery(EntityManagerImpl.java:1512)
at test.Test.main(Test.java:38)
Caused by: Exception [EclipseLink-0] (Eclipse Persistence Services - 2.4.0.v20120608-r11652): org.eclipse.persistence.exceptions.JPQLException
at org.eclipse.persistence.internal.jpa.jpql.HermesParser.buildException(HermesParser.java:150)
at org.eclipse.persistence.internal.jpa.jpql.HermesParser.validate(HermesParser.java:325)
at org.eclipse.persistence.internal.jpa.jpql.HermesParser.populateQueryImp(HermesParser.java:270)
at org.eclipse.persistence.internal.jpa.jpql.HermesParser.buildQuery(HermesParser.java:157)
at org.eclipse.persistence.internal.jpa.EJBQueryImpl.buildEJBQLDatabaseQuery(EJBQueryImpl.java:138)
at org.eclipse.persistence.internal.jpa.EJBQueryImpl.buildEJBQLDatabaseQuery(EJBQueryImpl.java:112)
at org.eclipse.persistence.internal.jpa.EJBQueryImpl.<init>(EJBQueryImpl.java:98)
at org.eclipse.persistence.internal.jpa.EJBQueryImpl.<init>(EJBQueryImpl.java:82)
at org.eclipse.persistence.internal.jpa.EntityManagerImpl.createQuery(EntityManagerImpl.java:1510)
... 1 more
IS THERE ANY OPTION PLEASE
Note: When i use "Eclipse Link- 2.3.2" It works perfectly
[Updated on: Thu, 26 July 2012 10:23] by Moderator
FUDForum. Page generated in 0.04056 seconds
