Home » Modeling » EMF » [xcore/OCL] Error in auto generated code
[xcore/OCL] Error in auto generated code [message #898488] Thu, 26 July 2012 09:22 Go to next message
Example:
class Rule
Integer num
@Pivot(derivation="self.num > 3")
derived Boolean b
Problem: This gives me an error in the auto generated code. In the src-gen folder, Project.impl package, RuleImpl.java class:
public void eUnset(int featureID)
switch (featureID)
case Test2Package.RULE__NAME:
setName(NAME_EDEFAULT);
return;
case Test2Package.RULE__NUM:
setNum(NUM_EDEFAULT);
return;
case Test2Package.RULE__B:
setB(B_EDEFAULT);
return;
super.eUnset(featureID);
'setB(B_EDEFAULT);' gives an error: 'B_EDEFAULT cannot be resolved to a variable'
This is solved by creating a field in the generated class. Is there any way to solve this without manually fix things?
Thanks.
[Updated on: Thu, 26 July 2012 09:23] by Moderator
Re: [xcore/OCL] Error in auto generated code [message #898493 is a reply to message #898488] Thu, 26 July 2012 09:30 Go to previous messageGo to next message
Interesting; I had no idea that OCL could be used in this way with
Xcore; at one level it seems sensible.
At another it's rather stupid.
Xcore provides a nice Xtext editor for Java implementations of Ecore
features; use Java with Xcore.
If you want to use OCL, use the OCLinEcore Xtext editor so that you get
syntax checking on the OCL.
You're particular problem is that you need to specify that 'b' is
transient and volatile.
Ed Willink
On 26/07/2012 14:22, Wouter Schaekers wrote:
> Hi
> Example:
> class Rule
> Integer num
> @Pivot(derivation="self.num > 5")
> derived Boolean b
> @Override
> switch (featureID)
> return;
> return;
> setB(B_EDEFAULT);
> return;
> a variable'
> Thanks.
Re: [xcore/OCL] Error in auto generated code [message #898499 is a reply to message #898493] Thu, 26 July 2012 09:40 Go to previous messageGo to next message
Ed,
Comments below.
On 26/07/2012 3:30 PM, Ed Willink wrote:
> Hi
> get syntax checking on the OCL.
The "derived" keyword implies transient and volatile; there's currently
no way to specify a derived feature that isn't transient and isn't volatile.
> Regards
> Ed Willink
>> Hi
>> Example:
>> class Rule
>> Integer num
>> derived Boolean b
>> @Override
>> switch (featureID)
>> return;
>> return;
>> setB(B_EDEFAULT);
>> return;
For me this produces
public boolean eIsSet(int featureID)
switch (featureID)
case LibraryPackage.RULE__NUM:
return NUM_EDEFAULT == null ? num != null :
!NUM_EDEFAULT.equals(num);
case LibraryPackage.RULE__B:
return B_EDEFAULT == null ? b != null : !B_EDEFAULT.equals(b);
return super.eIsSet(featureID);
Are you using the Juno version of Xcore? This looks familiar, like a bug
that's already fix...
>> a variable'
>> Thanks.
Re: [xcore/OCL] Error in auto generated code [message #898506 is a reply to message #898493] Thu, 26 July 2012 09:50 Go to previous messageGo to next message
Ed Willink wrote on Thu, 26 July 2012 09:30
Interesting; I had no idea that OCL could be used in this way with Xcore.
Everything that I tried to do with OCL in Xtext can be done in Xcore (or at least the things I tried).
That's not what we want to do. We want to develop a DSL, that in the end will be parsed outside of all the Xcore/Xtext tools (So, write a parser ourselves that converts our model/constrains to C++ code.). Xcore is preferred over Xtext, because it's more abstract and less dependent on a lot of stuff. And for the same reason, we think that OCL is preferred over Java.
'derived transient volatile Boolean b' doesn't work (the same problem). It's just a minor problem. It would be nice if it can be fixed, but it's not that big a deal.
[Updated on: Thu, 26 July 2012 09:50] by Moderator
Re: [xcore/OCL] Error in auto generated code [message #898508 is a reply to message #898499] Thu, 26 July 2012 09:53 Go to previous messageGo to next message
Ed Merks wrote on Thu, 26 July 2012 09:40
switch (featureID)
Yes, I'm using Juno. The thing I posted was just a part of the code. The whole code:
@Ecore(invocationDelegates="http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot",
settingDelegates="http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot", validationDelegates="http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot")
package Test2
annotation "http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot" as Pivot
class DomainModel
contains Rule [] rules
class Rule
Integer num
derived Boolean b
[Updated on: Thu, 26 July 2012 09:54] by Moderator
Re: [xcore/OCL] Error in auto generated code [message #898519 is a reply to message #898508] Thu, 26 July 2012 10:03 Go to previous messageGo to next message
Wouter,
Yes, I can reproduce the problem with that larger block of code. Please
open a bugzilla and I'll try to get it fixed in the maintenance stream.
>> switch (featureID)
>> bug that's already fix...
> The whole code:
> package Test2
> class DomainModel
> class Rule
> Integer num
Re: [xcore/OCL] Error in auto generated code [message #898531 is a reply to message #898519] Thu, 26 July 2012 10:23 Go to previous message
Ed Merks wrote on Thu, 26 July 2012 10:03
Please open a bugzilla and I'll try to get it fixed in the maintenance stream.
-> https://bugs.eclipse.org/bugs/show_bug.cgi?id=386050
Previous Topic:Associating rcp exe with "this kind of file"
Next Topic:diagram editor for dynamic objects
Current Time: Wed Jul 23 21:35:40 EDT 2025
Powered by FUDForum. Page generated in 0.26559 seconds
