Home » Modeling » TMF (Xtext) » Updating resource description takes forever(Problems with xtext/emf)
icon9.gif  Updating resource description takes forever [message #897783] Wed, 25 July 2012 05:00 Go to next message
currently I have a problem with my Xtext project. I use a genmodel created by myself from several ecore models. When I build my workspace the operation:
"Updating resource description for xhtml.ecore" takes forever. I cannot cancel it. I need to kill eclipse.
The problem lies in the xhtml.ecore file created by emf. It has ~12.000 lines.
I think the problem lies in the class
I found bugs that had similar problems Bug Eclipse 372527, code google com/p/protobuf-dt/issues/detail?id=206
I work with:
Eclipse SDK
Version: 4.2.0
Build id: I20120608-1400
Xtext SDK 2.3.0.v201206120633
I will attach the project. I hope you can help me.
Thanks in advance.
Svenja
Re: Updating resource description takes forever [message #898077 is a reply to message #897783] Wed, 25 July 2012 14:09 Go to previous messageGo to next message
guess this is the http://www.w3.org/1999/xhtml/datatypes/ http://www.w3.org/1999/xhtml etc problem.
w3 doesnt like java programs polling their dtd and makes this very very slow.
~Christian
Re: Updating resource description takes forever [message #898079 is a reply to message #898077] Wed, 25 July 2012 14:17 Go to previous messageGo to next message
Here the corresponding stack trace
Thread [Worker-4] (Suspended)
owns: BufferedInputStream (id=674)
owns: HttpURLConnection (id=675)
owns: ClusteringBuilderState (id=68)
SocketInputStream.socketRead0(FileDescriptor, byte[], int, int, int) line: not available [native method]
SocketInputStream.read(byte[], int, int, int) line: not available
SocketInputStream.read(byte[], int, int) line: not available
BufferedInputStream.fill() line: not available
BufferedInputStream.read1(byte[], int, int) line: not available
BufferedInputStream.read(byte[], int, int) line: not available
HttpClient.parseHTTPHeader(MessageHeader, ProgressSource, HttpURLConnection) line: not available
HttpClient.parseHTTP(MessageHeader, ProgressSource, HttpURLConnection) line: not available
HttpURLConnection.getInputStream() line: not available
URIHandlerImpl.createInputStream(URI, Map<?,?>) line: 172
XtextResourceSet$1(ExtensibleURIConverterImpl).createInputStream(URI, Map<?,?>) line: 354
SAXXMIHandler(XMLHandler).resolveEntity(String, String) line: 804
EntityResolverWrapper.resolveEntity(XMLResourceIdentifier) line: not available
XMLEntityManager.resolveEntityAsPerStax(XMLResourceIdentifier) line: not available
XMLEntityManager.startEntity(String, boolean) line: not available
XMLDTDScannerImpl.startPE(String, boolean) line: not available
XMLDTDScannerImpl.skipSeparator(boolean, boolean) line: not available
XMLDTDScannerImpl.scanDecls(boolean) line: not available
XMLDTDScannerImpl.scanDTDExternalSubset(boolean) line: not available
XMLDocumentScannerImpl$DTDDriver.dispatch(boolean) line: not available
XMLDocumentScannerImpl$DTDDriver.next() line: not available [local variables unavailable]
XMLDocumentScannerImpl$PrologDriver.next() line: not available
XMLDocumentScannerImpl.next() line: not available
XMLDocumentScannerImpl(XMLDocumentFragmentScannerImpl).scanDocument(boolean) line: not available
XIncludeAwareParserConfiguration(XML11Configuration).parse(boolean) line: not available
XIncludeAwareParserConfiguration(XML11Configuration).parse(XMLInputSource) line: not available
SAXParserImpl$JAXPSAXParser(XMLParser).parse(XMLInputSource) line: not available
SAXParserImpl$JAXPSAXParser(AbstractSAXParser).parse(InputSource) line: not available
SAXParserImpl$JAXPSAXParser.parse(InputSource) line: not available
SAXParserImpl.parse(InputSource, DefaultHandler) line: not available
XMILoadImpl(XMLLoadImpl).load(XMLResource, InputStream, Map<?,?>) line: 175
XMIResourceImpl(XMLResourceImpl).doLoad(InputStream, Map<?,?>) line: 240
XMIResourceImpl(ResourceImpl).load(InputStream, Map<?,?>) line: 1505
SAXXMIHandler(XMLHandler).getPackageForURI(String) line: 2536
SAXXMIHandler(XMLHandler).getFactoryForPrefix(String) line: 2416
SAXXMIHandler(XMLHandler).createObjectByType(String, String, boolean) line: 1293
SAXXMIHandler(XMLHandler).createTopObject(String, String) line: 1462
SAXXMIHandler(XMLHandler).processElement(String, String, String) line: 1013
SAXXMIHandler(XMIHandler).processElement(String, String, String) line: 77
SAXXMIHandler(XMLHandler).startElement(String, String, String) line: 995
SAXXMIHandler(XMLHandler).startElement(String, String, String, Attributes) line: 706
SAXXMIHandler(XMIHandler).startElement(String, String, String, Attributes) line: 163
SAXParserImpl$JAXPSAXParser(AbstractSAXParser).startElement(QName, XMLAttributes, Augmentations) line: not available
XMLDTDValidator.startElement(QName, XMLAttributes, Augmentations) line: not available
XMLDocumentScannerImpl(XMLDocumentFragmentScannerImpl).scanStartElement() line: not available
XMLDocumentScannerImpl$ContentDriver.scanRootElementHook() line: not available
XMLDocumentScannerImpl$ContentDriver(XMLDocumentFragmentScannerImpl$FragmentContentDriver).next() line: not available
XMIResourceImpl(ResourceImpl).load(Map<?,?>) line: 1284
XtextResourceSet(ResourceSetImpl).demandLoad(Resource) line: 259
XtextResourceSet(ResourceSetImpl).demandLoadHelper(Resource) line: 274
XtextResourceSet.getResource(URI, boolean) line: 159
XtextResourceSet(ResourceSetImpl).getEObject(URI, boolean) line: 220
EcoreUtil.resolve(EObject, ResourceSet) line: 197
EcoreUtil.resolve(EObject, EObject) line: 257
EAttributeImpl(BasicEObjectImpl).eResolveProxy(InternalEObject) line: 1473
EAttributeImpl(ETypedElementImpl).getEType() line: 315
EAttributeImpl.eGet(int, boolean, boolean) line: 240
EAttributeImpl(BasicEObjectImpl).eGet(EStructuralFeature, boolean, boolean) line: 1011
EAttributeImpl(BasicEObjectImpl).eGet(EStructuralFeature, boolean) line: 1003
ENamedElementImpl$2$1(EContentsEList$FeatureIteratorImpl<E>).hasNext() line: 403
EcoreUtil2.resolveCrossReferences(EObject, CancelIndicator) line: 512
EcoreUtil2.resolveAll(Resource, CancelIndicator) line: 483
EcoreUtil2.resolveLazyCrossReferences(Resource, CancelIndicator) line: 496
ClusteringBuilderState.doUpdate(BuildData, ResourceDescriptionsData, IProgressMonitor) line: 204
ClusteringBuilderState(AbstractBuilderState).update(BuildData, IProgressMonitor) line: 105
XtextBuilder.doBuild(ToBeBuilt, IProgressMonitor, IXtextBuilderParticipant$BuildType) line: 159
XtextBuilder.fullBuild(IProgressMonitor, boolean) line: 188
XtextBuilder.build(int, Map, IProgressMonitor) line: 85
BuildManager$2.run() line: 728
SafeRunner.run(ISafeRunnable) line: 42
BuildManager.basicBuild(int, IncrementalProjectBuilder, Map<String,String>, MultiStatus, IProgressMonitor) line: 199
BuildManager.basicBuild(IBuildConfiguration, int, IBuildContext, ICommand[], MultiStatus, IProgressMonitor) line: 239
BuildManager$1.run() line: 292
BuildManager.basicBuild(IBuildConfiguration, int, IBuildContext, MultiStatus, IProgressMonitor) line: 295
BuildManager.basicBuildLoop(IBuildConfiguration[], IBuildConfiguration[], int, MultiStatus, IProgressMonitor) line: 351
BuildManager.build(IBuildConfiguration[], IBuildConfiguration[], int, IProgressMonitor) line: 374
AutoBuildJob.doBuild(IProgressMonitor) line: 143
AutoBuildJob.run(IProgressMonitor) line: 241
Worker.run() line: 54
Re: Updating resource description takes forever [message #898107 is a reply to message #898077] Wed, 25 July 2012 15:41 Go to previous messageGo to next message
Hi Christian,
this looks like this issue here:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=385718
A possible solution would be to ensure that the plugin registry contains
entries for those URIs, e.g. by registering a generated EPackage or
something.
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Am 25.07.12 20:09, schrieb Christian Dietrich:
> slow.
> ~Christian
Re: Updating resource description takes forever [message #898313 is a reply to message #898107] Thu, 26 July 2012 03:56 Go to previous messageGo to next message
I changed my settings to only use generatedEPackages:
	bean = StandaloneSetup {
		scanClassPath = true
		platformUri = "${runtimeProject}/.."// The following two lines can be removed, if Xbase is not used.
		registerGenModelFile = "platform:/resource/com.yakindu.requirements.req/model/reqif10.genmodel"
		registerGeneratedEPackage= "datatypes.DatatypesPackage"
		registerGeneratedEPackage= "xhtml.XhtmlPackage"
		registerGeneratedEPackage="reqif10.Reqif10Package"
But then I get the following Exception
ERROR mf.mwe2.launch.runtime.Mwe2Launcher - Problems instantiating module com.yakindu.requirements.GenerateRequirements: java.lang.reflect.InvocationTargetException
java.lang.RuntimeException: Problems instantiating module com.yakindu.requirements.GenerateRequirements: java.lang.reflect.InvocationTargetException
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:95)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:62)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:52)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.run(Mwe2Launcher.java:74)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.main(Mwe2Launcher.java:35)
Caused by: org.eclipse.emf.common.util.WrappedException: java.lang.reflect.InvocationTargetException
at org.eclipse.emf.mwe2.language.factory.SettingProviderImpl$1$1.setValue(SettingProviderImpl.java:56)
at org.eclipse.emf.mwe2.language.factory.Mwe2ExecutionEngine.internalApplyAssignments(Mwe2ExecutionEngine.java:143)
at org.eclipse.emf.mwe2.language.factory.Mwe2ExecutionEngine.inCase(Mwe2ExecutionEngine.java:114)
at org.eclipse.xtext.util.PolymorphicDispatcher.invoke(PolymorphicDispatcher.java:291)
at org.eclipse.emf.mwe2.language.factory.Mwe2ExecutionEngine.internalSwitch(Mwe2ExecutionEngine.java:66)
at org.eclipse.emf.mwe2.language.factory.Mwe2ExecutionEngine.internalApplyAssignments(Mwe2ExecutionEngine.java:142)
at org.eclipse.emf.mwe2.language.factory.Mwe2ExecutionEngine.inCase(Mwe2ExecutionEngine.java:80)
at org.eclipse.emf.mwe2.language.factory.Mwe2ExecutionEngine.create(Mwe2ExecutionEngine.java:62)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:93)
... 4 more
Caused by: java.lang.reflect.InvocationTargetException
at org.eclipse.emf.mwe2.language.factory.SettingProviderImpl$1$1.setValue(SettingProviderImpl.java:54)
... 29 more
Caused by: java.lang.ExceptionInInitializerError
at reqif10.impl.Reqif10PackageImpl.init(Reqif10PackageImpl.java:478)
at reqif10.Reqif10Package.<clinit>(Reqif10Package.java:57)
at datatypes.impl.DatatypesPackageImpl.init(DatatypesPackageImpl.java:343)
at datatypes.DatatypesPackage.<clinit>(DatatypesPackage.java:68)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Unknown Source)
at org.eclipse.emf.mwe.internal.core.MWEPlugin.loadClass(MWEPlugin.java:75)
at org.eclipse.emf.mwe.core.resources.ResourceLoaderDefaultImpl.tryLoadClass(ResourceLoaderDefaultImpl.java:38)
at org.eclipse.emf.mwe.core.resources.AbstractResourceLoader.loadClass(AbstractResourceLoader.java:37)
at org.eclipse.emf.mwe.core.resources.ResourceLoaderDefaultImpl.loadClass(ResourceLoaderDefaultImpl.java:28)
at org.eclipse.emf.mwe.utils.StandaloneSetup.addRegisterGeneratedEPackage(StandaloneSetup.java:307)
... 34 more
Caused by: java.lang.RuntimeException: Missing serialized package: xhtml.ecore
at xhtml.impl.XhtmlPackageImpl.loadPackage(XhtmlPackageImpl.java:13639)
at xhtml.impl.XhtmlPackageImpl.init(XhtmlPackageImpl.java:542)
at xhtml.XhtmlPackage.<clinit>(XhtmlPackage.java:83)
... 45 more
Re: Updating resource description takes forever [message #898344 is a reply to message #898313] Thu, 26 July 2012 05:03 Go to previous messageGo to next message
Hi Svenja,
the EPackages are probably too large to create static initializers. EMF
generated dedicated ecore files in these cases that will be loaded at
runtime. Those seem to be missing in your projects.
Sebastian
Am 26.07.12 09:56, schrieb Svenja Wendler:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 4 more
> at
> ... 29 more
> at
> at
> at
> at
> at
> at
> ... 34 more
> xhtml.ecore
> at
> ... 45 more
Re: Updating resource description takes forever [message #898400 is a reply to message #898313] Thu, 26 July 2012 06:30 Go to previous messageGo to next message
I deleted the xhtml.ecore because it caused the above mentioned problems.
Re: Updating resource description takes forever [message #898432 is a reply to message #898400] Thu, 26 July 2012 07:34 Go to previous message
Hi, now it works. I enlarged the eclipse memory, cleaned the whole workspace.
Thanks for your suggestions.
Previous Topic:need graphical Editor howto
Next Topic:NoClassDefFoundError for org/slf4j/LoggerFactory upon Xtext generation
Current Time: Sat Jul 19 01:39:48 EDT 2025
Powered by FUDForum. Page generated in 0.03988 seconds
