Home » Modeling » OCL » illegal operation signature
illegal operation signature [message #898097] Wed, 25 July 2012 15:18 Go to next message
when parsing some OCL Constraints I'm faced with the following problems:
1. I have to Classes A and B defined in an UML diagram. Class A has an 0..5 association to Class B. The association at the end of class B is named "data".
The function f has the following declaration: f( x : Bag) : Set where Bag and Set stand for the OCL Collection Types.
I want to parse the following constraint:
f(A.allInstances().data)->notEmpty()
I get the following error:
illegal operation signature: (f(Bag(B))
Can anybody give me a hint what to do?
2. I changed the previous example and declared function f as follows:
f( x : Set) : Set
When parsing the constraint f(A.allInstances())->notEmpty(), the OCL Parser parses the constraint without any errors.
But if I change the constraint and use a function call like f(B.allInstances())->notEmpty() the OCL Parser raises the error:
illegal operation signature (f(Set(B))
If I leave the function call and just write: B.allInstances()->notEmpty() no error is raised.
Consequently it would mean that something is wrong with my function declaration of f. But as I said, using A.allInstances() instead of B.allInstances() works. So why doesn't it work using Class B?
Or isn't it allowed to use another class as function Parameter?
Thanks for your help!
Re: illegal operation signature [message #898117 is a reply to message #898097] Wed, 25 July 2012 16:14 Go to previous messageGo to next message
You give us no clue as to how you declared f( x : Bag) : Set so it is
difficult to comment on why your declaration doesn't work.
Ed Willink
On 25/07/2012 20:18, fv fv wrote:
> named "data".
> f( x : Set) : Set
Re: illegal operation signature [message #898373 is a reply to message #898117] Thu, 26 July 2012 05:43 Go to previous messageGo to next message
the Class Diagram with the OCL Constraints is defined in Magic Draw.
I only declared the function in the Class A as described above. I didn't think I need to define an OCL Constraint for the function, because one of the examples works as I said.
However then I also tried to define an OCL Constraint for the function in the hope that this would help:
I used the following simple code:
context A::f( ps : Bag(B)) : Set
post: result = ps.xy->asSet()
But only the following exception was thrown:
1:1:1:4 "inv:" misplaced construct(s)
Besides I'm not sure if it's a problem that I use ps: Bag(B) as parameter type and not just ps: Bag in the OCL Constraint?
Re: illegal operation signature [message #898387 is a reply to message #898373] Thu, 26 July 2012 06:10 Go to previous messageGo to next message
MagicDraw uses Dresden OCL rather than Eclipse OCL, so it is still far
from clear which parser is provoking the error; the error formatting
looks relatively familiar so it may be the Eclipse OCL LPG parser.
The suggestion that an 'inv' at 1:1:1:4 is a problem indicates that the
problem is in code that you haven't shared with us.
If I use fv.ecore (using the OCLinEcore editor)
package fv : pfx = 'platform:/resource/Activity/fv.ecore' {
class A {
operation f(ps : B[*]{!ordered,!unique}) : C[*]{!ordered,unique};
class B {
property xy : C;
class C {}
and fv.ocl (using the Complete OCL editor)
import fv : 'fv.ecore#/'
package fv
endpackage
I see no problem.
Ed Willink
On 26/07/2012 10:43, fv fv wrote:
> because one of the examples works as I said. However then I also tried
> would help:
Re: illegal operation signature [message #898397 is a reply to message #898387] Thu, 26 July 2012 06:27 Go to previous messageGo to next message
thank's for your help and sorry that I gave too little information.
What I can tell you is that I export the Project to Eclipse UML2 (v2.x) XMI File.
The thrown Error is:
org.eclipse.ocl.SyntaxException: 1:1:1:4 "inv:" misplaced construct(s)
at org.eclipse.ocl.util.OCLUtil.checkForErrors(OCLUtil.java:350)
at org.eclipse.ocl.util.OCLUtil.checkForErrors(OCLUtil.java:322)
at org.eclipse.ocl.internal.helper.HelperUtil.checkForErrors(HelperUtil.java:518)
at org.eclipse.ocl.internal.helper.HelperUtil.parseInvariant(HelperUtil.java:207)
at org.eclipse.ocl.internal.helper.OCLHelperImpl.createInvariant(OCLHelperImpl.java:216)
Hope that helps to find the mistake.
Re: illegal operation signature [message #898417 is a reply to message #898397] Thu, 26 July 2012 06:55 Go to previous messageGo to next message
No and suddenly you mention UML2 too. I'll leave you to find bugs in
your code that you keep to yourself. I'm not telepathic.
Ed Willink
On 26/07/2012 11:27, fv fv wrote:
> (v2.x) XMI File.
> at
> at
> at
Re: illegal operation signature [message #900300 is a reply to message #898417] Mon, 06 August 2012 08:08 Go to previous messageGo to next message
by now I've asked an answerable colleague and she allowed me to post some more code.
I also asked in the official Magic Draw forum if the export could be wrong or if it doesn't support such Constraints but didn't get an answer up to now.
Could you please tell me where to look for the error? The hole exception error is:
	at swt.mel.OCLParser.parseOCLConstraint(OCLParser.java:88)
	at swt.mel.MELClass.parseOCLConstraints(MELClass.java:637)
	at swt.mel.MELModel.parseOCLConstraints(MELModel.java:415)
	at swt.mel.MELModel.<init>(MELModel.java:137)
	at swt.mel.MELModel.setContext(MELModel.java:85)
	at swt.Parser.setContext(Parser.java:60)
	at org.eclipse.internal.xtend.xtend.ast.JavaExtensionStatement.evaluateInternal(JavaExtensionStatement.java:78)
	at org.eclipse.internal.xtend.xtend.ast.AbstractExtension.evaluate(AbstractExtension.java:166)
	at org.eclipse.internal.xtend.expression.ast.OperationCall.evaluate(OperationCall.java:335)
	at org.eclipse.internal.xtend.expression.ast.OperationCall.evaluateInternal(OperationCall.java:104)
	at org.eclipse.internal.xtend.expression.ast.Expression.evaluate(Expression.java:50)
	at org.eclipse.internal.xpand2.ast.ExpressionStatement.evaluateInternal(ExpressionStatement.java:45)
	at org.eclipse.internal.xpand2.ast.Statement.evaluate(Statement.java:41)
	at org.eclipse.internal.xpand2.ast.AbstractDefinition.evaluate(AbstractDefinition.java:180)
	at org.eclipse.internal.xpand2.ast.ExpandStatement.invokeDefinition(ExpandStatement.java:246)
	at org.eclipse.internal.xpand2.ast.ExpandStatement.evaluateInternal(ExpandStatement.java:226)
	at org.eclipse.xpand2.Generator.invokeInternal2(Generator.java:333)
	at org.eclipse.xtend.expression.AbstractExpressionsUsingWorkflowComponent.invokeInternal(AbstractExpressionsUsingWorkflowComponent.java:239)
	at org.eclipse.emf.mwe.core.lib.AbstractWorkflowComponent.invoke(AbstractWorkflowComponent.java:126)
	at org.eclipse.emf.mwe.core.container.CompositeComponent.internalInvoke(CompositeComponent.java:104)
	at org.eclipse.emf.mwe.core.container.CompositeComponent.invoke(CompositeComponent.java:89)
	at org.eclipse.emf.mwe.core.WorkflowEngine.executeWorkflow(WorkflowEngine.java:174)
	at org.eclipse.emf.mwe.core.WorkflowEngine.run(WorkflowEngine.java:53)
	at org.eclipse.emf.mwe.core.WorkflowRunner.doRun(WorkflowRunner.java:174)
	at org.eclipse.emf.mwe.core.WorkflowRunner.main(WorkflowRunner.java:69)
	at org.eclipse.ocl.uml.internal.UMLReflectionImpl.getSpecification(UMLReflectionImpl.java:492)
	at org.eclipse.ocl.uml.internal.UMLReflectionImpl.getSpecification(UMLReflectionImpl.java:1)
	at swt.mel.OCLParser.parseOCLConstraint(OCLParser.java:94)
The Exception is thrown at the following lines (within the parseOCLConstraint function):
		try {
			constraint = (Constraint)oclhelper.createInvariant(mod);
		}catch(ParserException e) {
			e.printStackTrace();
		ExpressionInOCL spec = oclhelper.getEnvironment().getUMLReflection().getSpecification(constraint);
		OCLExpression result = spec.getBodyExpression();
The corresponding lines in the .uml file are:
 <ownedRule xmi:id="_17_0_1_2_e1f0316_1344253005984_55554_1771" name="unbenannt3" constrainedElement="_15_1_3b40187_1221467783890_224088_211">
          <specification xmi:type="uml:OpaqueExpression" xmi:id="_17_0_1_2_e1f0316_1344253005984_400542_1772" name="">
            <language>English</language>
            <body>context A::f(ps : Bag(B)) : Set&#xA;post: result = ps.xy->asSet()</body>
          </specification>
        </ownedRule>
Thanks a lot!
Re: illegal operation signature [message #900307 is a reply to message #900300] Mon, 06 August 2012 08:45 Go to previous messageGo to next message
Please provide a Zipped project, with simple instructions to enable me
to reproduce the problem.
Ed Willink
On 06/08/2012 13:08, fv fv wrote:
> some more code.
> answer up to now.
> exception error is:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> try {
> name="unbenannt3"
> </specification>
> </ownedRule>
> Thanks a lot!
Re: illegal operation signature [message #902783 is a reply to message #900307] Mon, 20 August 2012 08:40 Go to previous messageGo to next message
thank's for your proposal!
I'm creating a workspace with three projects (the one I'm focusing on uses the other two projects). You would also need XPand and Operational QVT.
Sorry that I'm not able to make it smaller, I'm trying to handle it as small as possible.
If could you please send me a private message with your e-mail address I'll send you the workspace and some more precise instructions.
Re: illegal operation signature [message #908070 is a reply to message #902783] Tue, 04 September 2012 12:42 Go to previous messageGo to next message
I suppose my reply has escaped your attention. Therefore I just wanted to ask if your proposal is still valid?
Re: illegal operation signature [message #908167 is a reply to message #908070] Tue, 04 September 2012 17:30 Go to previous messageGo to next message
On 04/09/2012 17:42, fv fv wrote:
> Regards
Dropbox provides a very convenient transfer mechanism.
Ed Willink
Re: illegal operation signature [message #911345 is a reply to message #908167] Tue, 11 September 2012 08:27 Go to previous messageGo to next message
I took your advice and created a Dropbox account which contains the eclipse workspace.
If you could please accord me your e-mail address, I will share the folder with you? So you can also modify the files.
Thank's and best regards
Re: illegal operation signature [message #911489 is a reply to message #911345] Tue, 11 September 2012 14:09 Go to previous messageGo to next message
hi
Try ed _at_ willink _dot_ me _dot_ uk
Ed Willink
On 11/09/2012 13:27, fv fv wrote:
> eclipse workspace.
Re: illegal operation signature [message #912319 is a reply to message #911489] Thu, 13 September 2012 06:44 Go to previous messageGo to next message
I send you an invitation, now. In the main folder you find a pdf called instructions which explains the first steps.
Thank's!
Re: illegal operation signature [message #912503 is a reply to message #912319] Thu, 13 September 2012 13:12 Go to previous messageGo to next message
You didn't identify your Eclipse versions...
But on Juno it's hopeless.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=389542 raised to allow
legacy UML fgiles to be opened again.
On Indigo you use a context entrry that doesn't exist. I've never seen
"convert PIM to ASM".
Examining the XMI, it is clear that your OCL is a mess.
Some is sensible: e.g.
<body>value > 0</body>
But some is meaningless however you look at it
<body>else</body>
and some is a misguided use of Complete OCL rather than Essential OCL
<body>context Terminal::f(x: Boolean) : Boolean&#xA;post: result = x</body>
It is not surprising that an Essential OCL expression parser is unhappy.
Ed Willink
On 13/09/2012 11:44, fv fv wrote:
> Thank's!
Re: illegal operation signature [message #912826 is a reply to message #912503] Fri, 14 September 2012 04:59 Go to previous message
Correction: even your sensible OCL is bad:
is presumably an 'OCL' rather than 'English' language body. Tooling
might therefore reject it outright, or just use the tooling-specific
built-in default.
Ed Willink
On 13/09/2012 18:12, Ed Willink wrote:
> Hi
> seen "convert PIM to ASM".
> <body>else</body>
> x</body>
> Regards
> Ed Willink
>> Hi,
>> Thank's!
Previous Topic:[Announce] Eclipse OCL 4.0.1 (Juno SR1) RC2 is now available
Next Topic:Juno: Parsing OCL in Guards
Current Time: Sun Jul 27 06:41:01 EDT 2025
Powered by FUDForum. Page generated in 0.05573 seconds
