Home » Eclipse Projects » Remote Application Platform (RAP) » Decorate TreeItem(is it possible to decorate TreeItem?)
Decorate TreeItem [message #898261] |
Thu, 26 July 2012 01:32  |
I wanted to use ControlDecoration and ControlDecorator to my TreeItem, but its not possible, because TreeItem is a widget while the decorator accept in its constructor a Control type.
Are there any other objects I can use to decorate my TreeItem?
I have a tree with some elements (each element has an image + name), which may have several statuses (like "Up/Down/etc'").
and i want to put an extra image on the image i have.
for example if my element status is "Down", I would want to add a small image of Red X at the top left of my TreeItem's Image+label.
exactly like the behavior of the control decorator:
ControlDecoration decoration = new ControlDecoration( text, SWT.TOP | SWT.LEFT );
decoration.setImage( image );
any ideas or tips how to implement please?
Re: Decorate TreeItem [message #901444 is a reply to message #898327] |
Sun, 12 August 2012 08:47   |
First of all, thank you for the reply
Second of all, sorry I didnt reply untill today, just had more important tasks to handle before this.
the solution of creating the images is the last thing i'll try to do, as we have 5 images, with 3-5 states on each one. and more then one icon can be on the main image.
its many combinations bottom line.
Well, I looked at the Markup system, and tried it. It seemed like saving the space for the image, but it didnt display it. (probably I had issues with the path to the image, although i tried many combinations, even like "c:\blabla.gif").
I thought about merging the images, found a code via google, but it didnt work well. it almost did the trick, but not perfectly. the images where "merged" togather, but the colors of the second image were corrupted.. instead of red (down status icon)..
it all became gray/black. is there a different way to merge the images? below is the code that I tried.
in RWT there is no way to use GC on image anymore (image not implementing drawable).
if there was, i could try to create image from main image, and draw the other images on it. anyways its not possible due to the issue below, btw I saw a bug on it, will it be solved some day ? (https://bugs.eclipse.org/bugs/show_bug.cgi?id=318900)
Edited:
I understood the code below not working well for me because the palette. the palette im using is the one from main image, thats why it looks ok on main image but not on icon, if i use the icon palette, its the opposite of course (although not sure I really understood how this Pallete works)
*sigh*
Any ideas maybe please?
public Image getImage(Object element) {
EntityData nodeData = (EntityData) element;
Image mainImage = NODE_IMAGES.get(nodeData.getType());
Image downImg = ImageConsts.Images.DOWN_IMG;
ImageData mainImageData = mainImage.getImageData();
ImageData iconImageData = downImg.getImageData();
ImageData targetData = targetData = new ImageData(mainImageData.width, mainImageData.height,
mainImageData.depth, mainImageData.palette);
merge(mainImageData, iconImageData, targetData, mainImageData.width-8, mainImageData.height-8);
Image returnedImage = new Image(InsitePlugin.getDisplay(), targetData);
return returnedImage;
private static void merge(ImageData sourceData1, ImageData sourceData2,
ImageData targetData, int startX, int startY) {
// Merge the 1st Image
merge(sourceData1, targetData, sourceData1.x, sourceData1.x);
// Merge the 2nd Image
merge(sourceData2, targetData, startX, startY);
private static void merge(ImageData sourceData, ImageData targetData, int startX, int startY) {
int i;
i = sourceData.x;
for (; i < sourceData.width; i++) {
int j = sourceData.y;
for (; j < sourceData.height; j++) {
targetData.setPixel(startX + i, startY + j, sourceData.getPixel(i, j));
not working well, the colors not stay as the original image.
[Updated on: Sun, 12 August 2012 09:15] by Moderator
Re: Decorate TreeItem [message #901526 is a reply to message #901444] |
Mon, 13 August 2012 04:51   |
Hi.
Am 12.08.2012 14:47, schrieb Nir Zinger:
You need to register the images first. For 1.5 there is no one ideal way
to do that yet. However, it's basically the same as when you register
images for use with a custom widget, which is mentioned here:
http://www.eclipse.org/rap/developers-guide/devguide.php?topic=rwt/custom-widget.html#browserResources
I hope that helps.
Greetings,
Tim
Tim Buschtöns
Twitter: @EclipseRAP
Current Time: Sat Jul 26 07:53:41 EDT 2025
Powered by FUDForum. Page generated in 0.05037 seconds
