Home » Archived » BIRT » RCP Designer 4.2: Script tab is blank
RCP Designer 4.2: Script tab is blank [message #898089] Wed, 25 July 2012 14:49 Go to next message
I recently downloaded RCP Birt designer 4.2, and i noticed the script tab remains blank, whatever the report items selected. I do not have this problem in 3.7.2 and earliers.
And in the outline view on the left, in 4.2 if i try to directly open my existing report scripts, i get the same issue: the report view is blank, and i can't access to items events such onCreate, onRender, etc.
It happens both with reports created with a 3.7.2 RCP designer, and new reports created with RCP 4.2
Is it a known issue?
index.php/fa/10895/0/
[Updated on: Wed, 25 July 2012 14:52] by Moderator
Re: RCP Designer 4.2: Script tab is blank [message #898616 is a reply to message #898089] Thu, 26 July 2012 17:40 Go to previous messageGo to next message
In the 3.7.2 build were you using the all in one? or the RCP Designer.
I was under the impression that we disabled scripting in the RCP
designer but not the all in one.
Jason
On 7/25/2012 2:49 PM, donino donino wrote:
> Thanks
Re: RCP Designer 4.2: Script tab is blank [message #898702 is a reply to message #898616] Fri, 27 July 2012 05:20 Go to previous messageGo to next message
Hi Jason,
I used RCP designer in 3.7.2, and in earlier versions as well. I have just tried the all-in package 4.2, your are right i can access to my scripts in this one
Re: RCP Designer 4.2: Script tab is blank [message #899124 is a reply to message #898702] Mon, 30 July 2012 11:36 Go to previous message
Thanks for the reply. I do not often use the RCP version but I do
remember when we first created that package that we were planning on
disabling the script tab as this version is suppose to be simplified.
Jason
On 7/27/2012 5:20 AM, donino donino wrote:
> Hi Jason,
> scripts in this one
Previous Topic:Handling the BIRT Report large amount of Data
Next Topic:can't load birt-viewer on hosting,frameset was not recognized
Current Time: Wed Jul 23 03:13:28 EDT 2025
Powered by FUDForum. Page generated in 0.10204 seconds
