Home » Modeling » ATL » Could not debug, because UTFDataFormatException is thrown when reaching breakpoint
Could not debug, because UTFDataFormatException is thrown when reaching breakpoint [message #898009] Wed, 25 July 2012 11:29 Go to next message
Always when I try to debug my ATL script and breakpoint is reached an UTFDataFormatException is thrown which tells me the following stack trace.
java.io.UTFDataFormatException: encoded string too long: 343862 bytes
	at java.io.DataOutputStream.writeUTF(Unknown Source)
	at org.eclipse.m2m.atl.debug.core.adwp.ADWP.writeValue(ADWP.java:142)
	at org.eclipse.m2m.atl.debug.core.adwp.ADWP.sendMessage(ADWP.java:225)
	at org.eclipse.m2m.atl.engine.emfvm.launch.debug.NetworkDebugger$3.doIt(NetworkDebugger.java:308)
	at org.eclipse.m2m.atl.engine.emfvm.launch.debug.NetworkDebugger.dialog(NetworkDebugger.java:227)
	at org.eclipse.m2m.atl.engine.emfvm.launch.debug.NetworkDebugger.step(NetworkDebugger.java:151)
	at org.eclipse.m2m.atl.engine.emfvm.lib.ExecEnv.stepTools(ExecEnv.java:1886)
	at org.eclipse.m2m.atl.engine.emfvm.ASMOperation.exec(ASMOperation.java:330)
	at org.eclipse.m2m.atl.engine.emfvm.ASMOperation.exec(ASMOperation.java:388)
	at org.eclipse.m2m.atl.engine.emfvm.ASM.run(ASM.java:208)
	at org.eclipse.m2m.atl.engine.emfvm.launch.EMFVMLauncher.internalLaunch(EMFVMLauncher.java:170)
	at org.eclipse.m2m.atl.engine.emfvm.launch.EMFVMUILauncher.launch(EMFVMUILauncher.java:43)
	at org.eclipse.m2m.atl.core.service.LauncherService.launch(LauncherService.java:136)
	at org.eclipse.m2m.atl.core.ui.launch.AtlLaunchConfigurationDelegate$1.run(AtlLaunchConfigurationDelegate.java:274)
Does anybody has an idea what could be the reason of the exception. Perhaps its my file it contains about 900 lines of code, but I think this should ATL can handle, shouldn't it?
After stopping the debug-run and starting it again the variables couldn't be analyzed.
I already filed a bug (https://bugs.eclipse.org/bugs/show_bug.cgi?id=385849), but I hope to find anybody who have also this problem. Is there anybody out there. Or has anybody an idea what could be the problem?
Re: Could not debug, because UTFDataFormatException is thrown when reaching breakpoint [message #899163 is a reply to message #898009] Mon, 30 July 2012 13:30 Go to previous messageGo to next message
> at
> at
> at
> at
> at
> at
> at
> analyzed.
Interesting issue! Your breakpoint is on a method that returns a String, which
the debugger tries to copy over a TCP socket back to Eclipse, so that you can
view it. Apparently, java.io.DataOutputStream.writeUTF() does not handle
writing Strings as long as yours. Do you really have String values of over
300kB in your model?
Dennis
Re: Could not debug, because UTFDataFormatException is thrown when reaching breakpoint [message #899966 is a reply to message #899163] Fri, 03 August 2012 05:06 Go to previous message
I don't think that there are so huge in my model, but I would check this. Could this be a result of string concatenation?
Previous Topic:problem adding an association property to ownedAttribute
Next Topic:EOperation at ATL program?
Current Time: Tue Sep 16 07:18:42 EDT 2025
Powered by FUDForum. Page generated in 0.06919 seconds
