Home » Archived » XML Schema Definition (XSD) » org.eclipse.xsd.XSDSchema
org.eclipse.xsd.XSDSchema [message #895762] Sun, 15 July 2012 16:10 Go to next message
I have a xsd file:
<?xml version="1.0"?>
<xs:schema xmlns:xs="htp://www.w3.org/2001/XMLSchema">
<xs:element name="note">
<xs:complexType>
<xs:sequence>
<xs:element name="to" type="xs:string"/>
<xs:element name="from" type="xs:string"/>
<xs:element name="heading" type="xs:string"/>
<xs:element name="body" type="xs:string"/>
</xs:sequence>
</xs:complexType>
</xs:element>
</xs:schema>
and parse it by org.eclipse.xsd.util.XSDParser to org.eclipse.xsd.XSDSchema and question is how find element to,from,heading and body inside XSDSchema? The only element that i found is note.
any advice which can help?
Re: org.eclipse.xsd.XSDSchema [message #895796 is a reply to message #895762] Mon, 16 July 2012 01:26 Go to previous messageGo to next message
XSDElementDeclaration has getAnonymousTypeDefinition for this particular
case (a contained anonymous type), or, more generally,
getTypeDefinitition for the type of the element, regardless of whether
it's contained or referenced by name. Looking at how
XSDProtypicalSchema builds instances is likely to help you understand
how to traverse them. A generic way to walk everything is
Resource.getAllContents().
On 15/07/2012 10:11 PM, Slawek L wrote:
> I have a xsd file:
> <xs:complexType>
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> </xs:element>
> </xs:schema>
> found is note.
Re: org.eclipse.xsd.XSDSchema [message #896479 is a reply to message #895796] Wed, 18 July 2012 09:50 Go to previous messageGo to next message
Hi, I have a simple code from XSDPrototypicalSchema and its clear :
XSDSchema xsdSchema=XSDSchema.class.newInstance();
    XSDComplexTypeDefinition usAddress = xsdFactory.createXSDComplexTypeDefinition();
    usAddress.setName("USAddress");
    XSDModelGroup usAddressSequence = xsdFactory.createXSDModelGroup();
    usAddressSequence.setCompositor(XSDCompositor.SEQUENCE_LITERAL);
    XSDParticle usAddressParticle = xsdFactory.createXSDParticle();
    usAddressParticle.setContent(usAddressSequence);
    XSDElementDeclaration street = xsdFactory.createXSDElementDeclaration();
    street.setName("street");
    street.setTypeDefinition(xsdSchema.getSchemaForSchema().resolveSimpleTypeDefinition("string"));
    XSDParticle streeParticle = xsdFactory.createXSDParticle();
    streeParticle.setContent(street);
    usAddressSequence.getContents().add(streeParticle);
    XSDElementDeclaration city = xsdFactory.createXSDElementDeclaration();
    city.setName("city");
    city.setTypeDefinition(xsdSchema.getSchemaForSchema().resolveSimpleTypeDefinition("string"));
    XSDParticle cityParticle = xsdFactory.createXSDParticle();
    cityParticle.setContent(city);
    usAddressSequence.getContents().add(cityParticle);
    usAddress.setContent(usAddressParticle);
    XSDAttributeDeclaration country = xsdFactory.createXSDAttributeDeclaration();
    country.setName("country");
    country.setTypeDefinition(xsdSchema.getSchemaForSchema().resolveSimpleTypeDefinition("NMTOKEN"));
    XSDAttributeUse countryAttributeUse = xsdFactory.createXSDAttributeUse();
    countryAttributeUse.setContent(country);
    countryAttributeUse.setConstraint(XSDConstraint.FIXED_LITERAL);
    countryAttributeUse.setLexicalValue("US");
    usAddress.getAttributeContents().add(countryAttributeUse);
    xsdSchema.getContents().add(usAddress);
input will be:
<xsd:complexType name="USAddress">
             <xsd:sequence>
                 <xsd:element name="name" type="xsd:string"/>
                 <xsd:element name="street" type="xsd:string"/>
                 <xsd:element name="city" type="xsd:string"/>
                 <xsd:element name="state" type="xsd:string"/>
                 <xsd:element name="zip" type="xsd:string"/>
             </xsd:sequence>
             <xsd:attribute fixed="US" name="country" type="xsd:NMTOKEN"/>
         </xsd:complexType>
but how from xsdSchema object get this simple structur? Almost all objects has inside Contents (EList) where can be everything(XSDComplexTypeDefinition, XSDParticial, XSDSequence ...). Could you provide more details about "generic way to walk everything", XSDSchema has a method eResource() but it gives null.
Re: org.eclipse.xsd.XSDSchema [message #896491 is a reply to message #896479] Wed, 18 July 2012 10:03 Go to previous messageGo to next message
Comments below.
> input will be:
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
xsdSchema.getContents() contains it so you can iterate over that list.
Yes.
EObject.eContents() generically returns all the contained EObjects.
EObject.eAllContents() is an iterator that (like
Resource.getAllContents(), will walk the entire containment tree.
Re: org.eclipse.xsd.XSDSchema [message #897954 is a reply to message #896491] Wed, 25 July 2012 09:51 Go to previous messageGo to next message
How do I from XSDSchema receive org.eclipse.emf.common.util.URI? (org.eclipse.xsd.util.XSDPrototypicalSchema method printSchema(String xsdSchemaURI))
Re: org.eclipse.xsd.XSDSchema [message #898007 is a reply to message #897954] Wed, 25 July 2012 11:22 Go to previous messageGo to next message
<html>
<head>
<meta content="text/html; charset=UTF-8" http-equiv="Content-Type">
</head>
You can use things like an <a class="moz-txt-link-freetext" href="http://">http://</a>... URI pointing to a schema on
the web, or a <a class="moz-txt-link-freetext" href="file://">file://</a> URI pointing to something on your local file
system.  URI.createFileURI(URI.<span class="me1">createFileURI</span><span
class="br0">(&lt;java.util.File&gt;</span>.<span class="me1">getAbsolutePath</span><span
class="br0">(</span><span class="br0">)</span><span class="br0">)
is a good way to produce a URI for the file system.  If you're
wanting something in the workspace, be sure to read the EMF FAQ:<br>
</span><body>
<li class="toclevel-2"><a
href="http://wiki.eclipse.org/index.php/EMF-FAQ#How_do_I_map_between_an_EMF_Resource_and_an_Eclipse_IFile.3F"><span
class="tocnumber">2.44</span> <span class="toctext">How do
I map between an EMF Resource and an Eclipse IFile?</span></a></li>
</body>
<br>
<div class="moz-cite-prefix">On 25/07/2012 3:51 PM, Slawek L wrote:<br>
</div>
<blockquote cite="mid:juotkm$sua$1@xxxxxxxxe.org" type="cite">How
<br>
</blockquote>
<br>
</body>
</html>
Re: org.eclipse.xsd.XSDSchema [message #898442 is a reply to message #898007] Thu, 26 July 2012 07:50 Go to previous messageGo to next message
Thanks Ed for help, now it's more understandable, but still I have some questions...
for example:
<xs:complexType name="company">
    <xs:sequence minOccurs="1" maxOccurs="1">
      <xs:element  name="name" type="xs:string"/>
      <xs:element  name="street" type="xs:string"/>
      <xs:element  name="postCode" type="xs:string"/>
      <xs:element  name="city" type="xs:string"/>
    </xs:sequence>
</xs:complexType>
It is
org.eclipse.xsd.XSDComplexTypeDefinition
object, and how do I check how many tags are inside?
best regards
[Updated on: Thu, 26 July 2012 07:51] by Moderator
Re: org.eclipse.xsd.XSDSchema [message #898451 is a reply to message #898442] Thu, 26 July 2012 08:02 Go to previous messageGo to next message
What do you mean by "tags"?
> some questions...
> for example:
> </xs:sequence>
> </xs:complexType>
> It is org.eclipse.xsd.XSDComplexTypeDefinition object, and how do I
> best regards
Re: org.eclipse.xsd.XSDSchema [message #898454 is a reply to message #898451] Thu, 26 July 2012 08:11 Go to previous messageGo to next message
Sorry, I wasn't precise, in schema code we see that complexType "company" contains 4 elements: name, street, postCode, city. How do I check it in java and how do I check that city is a last element in company complexType.
[Updated on: Thu, 26 July 2012 08:13] by Moderator
Re: org.eclipse.xsd.XSDSchema [message #898462 is a reply to message #898454] Thu, 26 July 2012 08:20 Go to previous messageGo to next message
Probably you want to consider the logical content type because it will
take inheritance into account:
Open Declaration
<eclipse-open:%E2%98%82=org.eclipse.xsd/src%3Corg.eclipse.xsd%7BXSDComplexTypeDefinition.java%E2%98%83XSDComplexTypeDefinition%7EgetContentType>XSDComplexTypeContent
<eclipse-javadoc:%E2%98%82=org.eclipse.xsd/src%3Corg.eclipse.xsd%7BXSDComplexTypeDefinition.java%E2%98%83XSDComplexTypeDefinition%7EgetContentType%E2%98%82XSDComplexTypeContent>
<eclipse-javadoc:%E2%98%82=org.eclipse.xsd/src%3Corg.eclipse.xsd%7BXSDComplexTypeDefinition.java%E2%98%83XSDComplexTypeDefinition>.getContentType()
Returns the value of the '/*Content Type*/' reference.
This represents the value of the content type
<http://www.w3.org/TR/xmlschema-1/#content_type> infoset property.
It is computed from the |content
<eclipse-javadoc:%E2%98%82=org.eclipse.xsd/src%3Corg.eclipse.xsd%7BXSDComplexTypeDefinition.java%E2%98%83XSDComplexTypeDefinition%7EgetContentType%E2%98%82%E2%98%82getContent%E2%98%82>|
and should typically not be modified directly. It will be |null|, an
|XSDSimpleTypeDefinition
<eclipse-javadoc:%E2%98%82=org.eclipse.xsd/src%3Corg.eclipse.xsd%7BXSDComplexTypeDefinition.java%E2%98%83XSDComplexTypeDefinition%7EgetContentType%E2%98%82XSDSimpleTypeDefinition>|,
or an |XSDParticle
<eclipse-javadoc:%E2%98%82=org.eclipse.xsd/src%3Corg.eclipse.xsd%7BXSDComplexTypeDefinition.java%E2%98%83XSDComplexTypeDefinition%7EgetContentType%E2%98%82XSDParticle>|.
> check it in java?
Re: org.eclipse.xsd.XSDSchema [message #899577 is a reply to message #898462] Wed, 01 August 2012 09:49 Go to previous messageGo to next message
xsd file:
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<xsd:schema xmlns:xsd="htp://www.w3.org/2001/XMLSchema">
	<xsd:annotation>
		<xsd:documentation>Description .</xsd:documentation>
	</xsd:annotation>
	<xsd:element name="application">
		<xsd:complexType>
			<xsd:sequence>
				<xsd:element name="applicant">
					<xsd:complexType>
						<xsd:sequence>
							<xsd:element name="father_name">
								<xsd:simpleType>
									<xsd:restriction base="xsd:string">
										<xsd:maxLength value="50"/>
									</xsd:restriction>
								</xsd:simpleType>
							</xsd:element>
							<xsd:element name="birthday">
								<xsd:simpleType>
									<xsd:restriction base="xsd:date"/>
								</xsd:simpleType>
							</xsd:element>
						</xsd:sequence>
					</xsd:complexType>
				</xsd:element>
				<xsd:element name="date">
					<xsd:simpleType>
					</xsd:simpleType>
				</xsd:element>
			</xsd:sequence>
		</xsd:complexType>
	</xsd:element>
</xsd:schema>
Body of method
String fileName = "c:\\ParserXSDExample\\b\\4.xsd";
		XSDSchema xsdSchema = null;
		XSDParser parser = null;
		try {
			parser = XSDParser.class.newInstance();
			parser.parse(fileName);
			xsdSchema = parser.getSchema();
		} catch (InstantiationException e) {
			e.printStackTrace();
		} catch (IllegalAccessException e) {
		int counter = 1;
		Document docu = xsdSchema.getDocument();
		TreeIterator<EObject> iterator = xsdSchema.eAllContents();
		while (iterator.hasNext()) {
			EObject object = (EObject) iterator.next();
			System.out.println(counter + "). element " + object.getClass());
			if (object instanceof XSDElementDeclaration) {
				XSDElementDeclaration xsdED=(XSDElementDeclaration) object;
				System.out.println(xsdED.getName());
			counter++;
and it produces:
application
applicant
father_name
birthday
date
And it is OK, but expected output should looks like:
application
  applicant
    father_name
    birthda
  applicant-Close
  date
application-Close
My problem is that I don't know how check that:
-element applicant is inside other element(application)(applicant has a parent)
-no more elements are inside applicant after birthda(birthday is last children)
Re: org.eclipse.xsd.XSDSchema [message #899677 is a reply to message #899577] Wed, 01 August 2012 14:41 Go to previous message
Comments below.
On 01/08/2012 3:50 PM, Slawek L wrote:
> xsd file:
> <xsd:annotation>
> </xsd:annotation>
> <xsd:complexType>
> <xsd:sequence>
> <xsd:complexType>
> <xsd:sequence>
> <xsd:simpleType>
> </xsd:restriction>
> </xsd:simpleType>
> </xsd:element>
> <xsd:simpleType>
> </xsd:simpleType>
> </xsd:element>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:element>
> <xsd:simpleType>
> </xsd:simpleType>
> </xsd:element>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:element>
> </xsd:schema>
> Body of method
> try {
There's no example that shows to do this. The examples show how to use
a resource set. Why are you doing this? It doesn't build a schema so I
don't see how it produces output like what you show.
> int counter = 1;
> object.getClass());
> object;
> counter++;
> and it produces:
> application
> applicant
> father_name
> birthday
> date
> application
> applicant
> father_name
> birthda
> applicant-Close
> date
> application-Close
> a parent)
> children)
Previous Topic:schema error
Next Topic:Adding XSD to Catalog which includes and imports XSD
Current Time: Wed Sep 17 21:41:19 EDT 2025
Powered by FUDForum. Page generated in 0.28764 seconds
