Home » Eclipse Projects » GEF » EditPart resize on children setVisible
EditPart resize on children setVisible [message #897259] Mon, 23 July 2012 08:40 Go to next message
I have a editpart with multiple children. When i hide children using setVisible method the editpart does not resize. I want it to decrease size when children are hidden and increase size when chidren are visible.
I have tried repaint and revalidate method but it does not change size.
Any idea?
Re: EditPart resize on children setVisible [message #897317 is a reply to message #897259] Mon, 23 July 2012 11:02 Go to previous messageGo to next message
Hi, could you post some code here?
Changing the size is about the validation and setVisible on a Figure kicks the validation process for you.
So basically there are two options
  1. You have a layout manager on the parent and you're doing something wrong with its constraints
  2. You don't have any layout manager on the parent and you have to set the bounds manually
[Updated on: Mon, 23 July 2012 11:03] by Moderator
Re: EditPart resize on children setVisible [message #897499 is a reply to message #897317] Tue, 24 July 2012 06:07 Go to previous messageGo to next message
Here is code snippt from figure's constructor
ToolbarLayout layout = new ToolbarLayout();
layout.setSpacing(2);
setLayoutManager(layout);
labelName.setForegroundColor(ColorConstants.darkGray);
labelName.setFont(new Font(PlatformUI.getWorkbench
className.setForegroundColor(ColorConstants.darkGray);
className.setFont(new Font(PlatformUI.getWorkbench
add(labelName, ToolbarLayout.ALIGN_CENTER);
add(className, ToolbarLayout.ALIGN_CENTER);
setBorder(new LineBorder(1));
setOpaque(true);
Re: EditPart resize on children setVisible [message #897523 is a reply to message #897499] Tue, 24 July 2012 08:02 Go to previous messageGo to next message
What is this figure? It's the parent figure?
How do you get the visible state and where and how do you set it?
Re: EditPart resize on children setVisible [message #897526 is a reply to message #897523] Tue, 24 July 2012 08:11 Go to previous messageGo to next message
This was parent figure.
Child figure which is being hidden is
FlowLayout layout = new FlowLayout();
layout.setMinorAlignment(FlowLayout.ALIGN_LEFTTOP);
layout.setHorizontal(false);
I have a hashtable which contains the references to all editparts and have one method in editpart to show/hide contains following statement.
getFigure().setVisible(visible);
thanks for assistance
Re: EditPart resize on children setVisible [message #897567 is a reply to message #897526] Tue, 24 July 2012 10:10 Go to previous message
And the figure being invisible is getting invisible, but the parent has the same size, so there is a "hole", right?
Well, I think the parent figure's layout manager (ToolBarLayout) asks the child figure's layout manager (FlowLayout) for the child figure's preferred size.
And since it doesn't take the visible state into account, it returns the same size as if the figure was visible.
Could you remove/add the figure from the parent figure instead of setting it invisible?
Previous Topic:Zest2 release date?
Next Topic:Replace GEF Designer Editor with Browser
Current Time: Wed Jul 23 12:14:22 EDT 2025
Powered by FUDForum. Page generated in 0.29632 seconds
