Home » Eclipse Projects » Standard Widget Toolkit (SWT) » SWT an xulrunner
SWT an xulrunner [message #897322] Mon, 23 July 2012 11:17 Go to next message
How-to launch acrobat reader when i use xulrunner for SWT Browser ?
Re: SWT an xulrunner [message #899129 is a reply to message #897322] Mon, 30 July 2012 11:40 Go to previous message
Assuming you mean, how to get Acrobat reader to open in the Browser when
a .pdf is encountered, it should happen automatically. If this is not
happening then the Acrobat Reader browser plug-in is probably not being
found. You should not typically have to point at its location
explicitly, but if it is installed in an unusual location (or perhaps
you're seeing a Browser bug?), you can point at it as described in
file:///C:/workspace-32/swt/faq.php#mozillaplugins .
HTH,
Grant
On 7/23/2012 11:17 AM, Gerald Radix wrote:
Previous Topic:Java<-->JavaScript - window.external
Next Topic:Snippet 277
Current Time: Fri Jul 25 23:50:21 EDT 2025
Powered by FUDForum. Page generated in 0.04891 seconds
