Home » Archived » Hudson » Matrix-based security not working with Active Directory
Matrix-based security not working with Active Directory [message #897119] Sat, 21 July 2012 22:54 Go to next message
I am running Hudson 2.1.2 and 2.2.1 with Active Directory plugin installed. I tested AD authentication and it worked when authorization was set to "Logged-in users can do anything". When I switch to "Matrix-based security", all login users got all rights no matter how the matrix was set up. The same matrix setup worked when Security Realm was set to "Delegate to servlet container".
I read in some postings that previously role name needed to have "ROLE_" prefix. When I tried that, I got no access to any page after I logged in. I had to edit config.xml to make the site functional again.
Does anyone know if Hudson AD plugin work with matrix-based security at all? If it suppose to work, what did I missed? And how to debug this problem?
Re: Matrix-based security not working with Active Directory [message #897122 is a reply to message #897119] Sun, 22 July 2012 01:49 Go to previous messageGo to next message
Yes, AD should work with the matrix based security. The ROLE_ was added for LDAP groups. Could you paste the config.xml security portion here? If not you can PM me the config.xml security items.
Steve.
P.S. A simple way to test if your AD is working, create a special group called "authenticated" and give him full permission to everything. This authenticated means anyone that has logged in can do anything. This is not different than running "Logged-in users can do anything" but it will test to make sure your matrix-based security part works.
Re: Matrix-based security not working with Active Directory [message #897159 is a reply to message #897122] Sun, 22 July 2012 14:19 Go to previous messageGo to next message
I had configured Hudson to use AD authentication and added an engineering group which had only Overall: Administrator + Read privilege. Anonymous user had no privilege on anything. I was in engineering AD group which I confirmed using Outlook Address Book. Based on this configuration, I should not have privilege to any of the Slave, Job, Run, View or SCM functions. When I login, I was able to access all functions on Hudson. Is this because admin privilege implies one also have all other privileges?
Here is the config for this experiment:
<hudson>
<version>2.2.1</version>
<numExecutors>1</numExecutors>
<mode>NORMAL</mode>
<useSecurity>true</useSecurity>
<authorizationStrategy class="hudson.security.GlobalMatrixAuthorizationStrategy">
<permission>hudson.model.Hudson.Administer:engineering</permission>
<permission>hudson.model.Hudson.Read:engineering</permission>
</authorizationStrategy>
<securityRealm class="hudson.plugins.active_directory.ActiveDirectorySecurityRealm">
<bindPassword>{this is removed by me}</bindPassword>
</securityRealm>
I tried another privilege setting. In this experiment, I had no admin, slave and job/workspace privileges but was given all other privileges. When I logged in, I got an error message "Access Denied, pfung is missing the Read permission".
<hudson>
<mode>NORMAL</mode>
<permission>hudson.model.Item.Build:engineering</permission>
<permission>hudson.model.Item.Configure:engineering</permission>
<permission>hudson.model.Item.Create:engineering</permission>
<permission>hudson.model.Item.Delete:engineering</permission>
<permission>hudson.model.Item.Read:engineering</permission>
<permission>hudson.model.Run.Delete:engineering</permission>
<permission>hudson.model.Run.Update:engineering</permission>
<permission>hudson.model.View.Configure:engineering</permission>
<permission>hudson.model.View.Create:engineering</permission>
<permission>hudson.model.View.Delete:engineering</permission>
<permission>hudson.scm.SCM.Tag:engineering</permission>
<bindPassword>{this is taken out by me}</bindPassword>
</securityRealm>
It looked like Hudson was getting my group info (i.e., engineering) when I logged in. But maxtrix security was not working the way I expected.
Re: Matrix-based security not working with Active Directory [message #897316 is a reply to message #897159] Mon, 23 July 2012 10:59 Go to previous messageGo to next message
Poon Fung wrote on Sun, 22 July 2012 13:19
Yes, Administrator means you have control over everything.
<hudson>
<mode>NORMAL</mode>
</securityRealm>
I believe you need to set the overall to read. As described by the description:
The read permission is necessary for viewing almost all pages of Hudson. This permission is useful when you don't want unauthenticated users to see Hudson pages &mdash; revoke this permission from the anonymous user, then add "authenticated" pseudo-user and grant the read access.
The read permission is necessary for viewing almost all pages of hudson is the important part.
Re: Matrix-based security not working with Active Directory [message #897845 is a reply to message #897316] Wed, 25 July 2012 06:09 Go to previous message
Steve, thanks for the help. Not having Overall/Read privilege was indeed the problem. It looks like the only use of the Overall/Read privilege is to deny access to a particular group.
Previous Topic:polling
Next Topic:hudson-ci.org/debian 404 Not foundError
Current Time: Sat Jul 26 10:16:17 EDT 2025
Powered by FUDForum. Page generated in 0.05229 seconds
