Home » Eclipse Projects » Eclipse 4 » Selection with tools.compat wrappers
Selection with tools.compat wrappers [message #897252] |
Mon, 23 July 2012 08:21  |
I am using the compat DIViewPart implementation form the tools project
to include e4 views into a 3.x application (compat layer). I want to set
and retrieve the selection from two different views. Retrieving the
selection via @named(serviceconstats.activeselection) works fine, as
long as the selection is set by a 3.x view. If I want to set the
selection from a e4 view via @Inject ESelectionService service,
service.setSelection(), the retrieveing views does not get the selection
injected. During debugging, I also found out, the two different e4 views
get different instances of ESelectionService injected.
Any ideas?
Cheers
Jonas
Re: Selection with tools.compat wrappers [message #897569 is a reply to message #897293] |
Tue, 24 July 2012 10:21   |
I am implementing an e4 view, so i turn I want to avoid dependencies to
3.x (selection provider)
I think I pinned down the issue. The selection aggregator registers
itself at the context of a part, whenever a part is activated.
The problem ist thet the DIViewPart creates a new Context for the View
(not the same as the part itself). Therefore the selection provider of
the view will set SELECTION_OUTPUT in the context of the view, but not
in the context of the part, which is observed by the aggregator.
In other words:
service.setSelection(selection);
does not work
context.getParent().set("org.eclipse.ui.output.selection", selection);
this hack works
Is there a specific reason, why the DIViewWrapper creats a new context,
instead of using the Part Context?
Cheers
Jonas
Am 23.07.2012 15:55, schrieb Tom Schindl:
> Well useing ESelectionService is BTW a bad idea because this give you a
> dependency on e4.ui.workbench which ties you to 4.x!
> I think that's why I simply added the broker stuff but as said I can't
> remember. Publishing stuff in IEclipseContext is IHMO not solved
> appropriately I've a proposal sometime in 4.0 how this could be fixed
> but it never got implemented.
> Tom
> Am 23.07.12 15:51, schrieb Tom Schindl:
>> First of all getting different instance of ESelection-Service is
>> expected if I'm not completely mistaken (this will happen in a pure
>> e4-env as well).
>> IIRC i created a special ISelectionProviderService which acts as a
>> broker to publish the selection. It might be better to inject a fixed
>> ESelectionService but it is too long since I worked on it.
>> Tom
>> Am 23.07.12 14:21, schrieb Jonas Helming:
>>> Hi,
>>> Any ideas?
>>> Cheers
>>> Jonas
Re: Selection with tools.compat wrappers [message #897576 is a reply to message #897569] |
Tue, 24 July 2012 11:00   |
Please do not mix up the ISelectionProvider with
ISelectionProviderService which is from the tools service bundle!
The initial idea of the bridge was that you can target:
* e4
* Eclipse 4.x (the compat layer)
* Eclipse 3.x
That's why there are so called broker services.
Now to your findings: This looks like a bug, when running in Eclipse 4.x
compat layer we don't have to create a context but should simply reuse
the one provided by the compat layer, when running in 3.x we'll have to
create one though.
File a bug, and provide a patch and I'll integrate it. Finding out of
you run in 3.x or 4.x is already done somewhere in the code.
Tom
Am 24.07.12 16:21, schrieb Jonas Helming:
> In other words:
> does not work
> this hack works
> Cheers
> Jonas
>> Tom
>>> e4-env as well).
>>> Tom
>>>> Hi,
>>>> set
>>>> selection
>>>> views
>>>> Any ideas?
>>>> Cheers
>>>> Jonas
Re: Selection with tools.compat wrappers [message #897586 is a reply to message #897576] |
Tue, 24 July 2012 11:40   |
.... and because we are at it. I would advise anyone to stay aways from
the dependencies that come from e4.ui.workbench because this drags i way
too much dependency stuff.
I think we need to find a better and more light weight way to publish
the selection.
I made a suggestion on
https://bugs.eclipse.org/bugs/show_bug.cgi?id=321201 which was not
picked up.
Tom
Am 24.07.12 17:00, schrieb Tom Schindl:
> * e4
> * Eclipse 3.x
> create one though.
> Tom
>> In other words:
>> does not work
>> this hack works
>> Cheers
>> Jonas
>>> Tom
>>>> e4-env as well).
>>>> Tom
>>>>> Hi,
>>>>> set
>>>>> selection
>>>>> views
>>>>> Any ideas?
>>>>> Cheers
>>>>> Jonas
Re: Selection with tools.compat wrappers [message #899359 is a reply to message #897576] |
Tue, 31 July 2012 10:27  |
done, see https://bugs.eclipse.org/bugs/show_bug.cgi?id=386329
I did not find a Bugzilla component within e4 for the tools...
Am 24.07.2012 17:00, schrieb Tom Schindl:
> * e4
> * Eclipse 3.x
> create one though.
> Tom
>> In other words:
>> does not work
>> this hack works
>> Cheers
>> Jonas
>>> Tom
>>>> e4-env as well).
>>>> Tom
>>>>> Hi,
>>>>> set
>>>>> selection
>>>>> views
>>>>> Any ideas?
>>>>> Cheers
>>>>> Jonas
Current Time: Wed Jul 23 06:07:37 EDT 2025
Powered by FUDForum. Page generated in 0.06432 seconds
