Home » Modeling » GMF (Graphical Modeling Framework) » Tools Palette elements directly from Java
Tools Palette elements directly from Java [message #894555] Mon, 09 July 2012 11:08 Go to next message
Hi GMF experts,
I have just started to play with GMF framework and I have few questions:
I have created a dummy plugin that has several elements in tools palette and they can be added into graphical diagram and linked together with connection element from tools palette. All this was generated by using eclipse GMF plugin.
As I see, all elements types and element types binding are listed in generated plugin.xml under:
org.eclipse.gmf.runtime.emf.type.core.elementTypes
and
org.eclipse.gmf.runtime.emf.type.core.elementTypeBindings
Additionally, modelling assistant provider is registered in org.eclipse.gmf.runtime.emf.ui.modelingAssistantProviders extension point
and view provider is registered under:
org.eclipse.gmf.runtime.diagram.core.viewProviders
My question would be:
Is it possible to add new elements directly from Java code without using data information from plugin.xml?
To be more clear:
How can I add new element type to org.eclipse.gmf.runtime.emf.type.core.elementTypes from Java?
How can I add new element type binding to org.eclipse.gmf.runtime.emf.type.core.elementTypeBindings from Java?
How can I add EditPart implementation for that new element to registered modelling assistant from Java?
How can I add semantic hint for newly created element into registered view provider from Java?
Thanks in advance.
Re: Tools Palette elements directly from Java [message #894703 is a reply to message #894555] Tue, 10 July 2012 04:15 Go to previous messageGo to next message
do you simply want to execute the code that is executed by GMF when you select a tool from the palete and click on the diagram? To do so you should have a look at CreateUnspecifiedTypeRequest
(http://publib.boulder.ibm.com/infocenter/rsmhelp/v7r0m0/index.jsp?topic=/org.eclipse.gmf.doc/reference/api/runtime/org/eclipse/gmf/runtime/diagram/ui/requests/CreateUnspecifiedTypeRequest.html)
Ralph
Re: Tools Palette elements directly from Java [message #894810 is a reply to message #894703] Tue, 10 July 2012 11:35 Go to previous messageGo to next message
Thanks, I will take a look at it.
What I'm trying to do is that I have added a new element into Tools palette by modifying generated TestPaletteFactory class. Now, when I run plugin, I can see that newly created element in Tools palette but I can't add it to diagram. The question is how can I make it work without touching plugin.xml file.
I will take a look at your suggested CreateUnspecifiedTypeRequest but in case you have additional information to the problem I have then I would be grateful to know that.
Re: Tools Palette elements directly from Java [message #894946 is a reply to message #894810] Wed, 11 July 2012 04:23 Go to previous messageGo to next message
what is your use case for manually editing generated code? Maybe there is a more efficient way to solve your problem.
Ralph
Re: Tools Palette elements directly from Java [message #895073 is a reply to message #894946] Wed, 11 July 2012 11:30 Go to previous messageGo to next message
My use case would be:
Allow users create custom elements in the diagram using wizard. So in the beginning user has a basic set of available elements but I would like to allow them creating their own custom elements. From the GUI point of view, user will be asked to specify name of the new element, icons and maybe some additional information and after that plugin will generate some jar file (still not decided) that will be added into plugin directory. After eclipse restart, user will be able to use that new element in the diagram. The place I'm analyzing now is where I should change the code in order to read that information from generated jar files and how should I add new elements into diagram on plugin startup. Of course, after that it should be possible to link predefined elements with new ones.
Re: Tools Palette elements directly from Java [message #895300 is a reply to message #895073] Thu, 12 July 2012 08:06 Go to previous messageGo to next message
if I am right you are interested in such a thing? http://code.google.com/a/eclipselabs.org/p/melanie/wiki/FirstSteps#Create_Domain-specific_Language
Ralph
Re: Tools Palette elements directly from Java [message #896091 is a reply to message #895300] Tue, 17 July 2012 04:52 Go to previous messageGo to next message
I was away for one week and only today found time to check your provided link. After checking that video I can tell that it's not what I'm looking for. I want to create a much more simple plugin.
As shown in the picture:
http:// www.javaexpress.pl /static/images/JeP_04_2009_06_GMF_6.png
There are 3 elements in the tools palette:
1) manager
2) Developer
3) Manager managed developers (connection)
So I would like to add for example "Tester" element into tools palette in runtime using some wizard. After that I will have 4 elements in the palette:
1) manager
2) Developer
4) Tester
The question is how to achieve this?
Re: Tools Palette elements directly from Java [message #896180 is a reply to message #896091] Tue, 17 July 2012 09:59 Go to previous messageGo to next message
I think the first thing to ask is how you would like to have tester represented in your meta-model? It sounds to me that you are speaking of extending the meta-model at runtime and create an editor for this. Is this right?
Ralph
Re: Tools Palette elements directly from Java [message #896902 is a reply to message #896180] Fri, 20 July 2012 07:12 Go to previous messageGo to next message
In my meta-model I will have one Base element: BaseEmployee that will have an attribute: type which will tell what type of employee is this. So basically I will re-use the same object underneath. But visually it should look like a separate element in the palette and diagram.
So from my point of view it's possible to work around without extending meta-model in the runtime and reuse existing.
Re: Tools Palette elements directly from Java [message #896904 is a reply to message #896902] Fri, 20 July 2012 07:25 Go to previous messageGo to next message
ok that is very close to what I do in my modeling environment. However I distinct between a ontological and linguistic type. From the linguistic point of view which is implemented in EMF everything is of instance of meta-class clabject everything else is done by code.
What I could remcoment you is to create a model for configuration. Out of this model you dynamically manipulate the palete.
Take a look at the manage palate method in this template which shows how to manipulate the palette by code:
http://code.google.com/a/eclipselabs.org/p/melanie/source/browse/de.uni_mannheim.informatik.swt.models.gmf/templates/aspects/xpt/editor/Editor.xpt
Additionally you would need to interpret at runtime a model describing how the view should look like. Here these two templates should be a good starting point:
updateDSLRenderingView in http://code.google.com/a/eclipselabs.org/p/melanie/source/browse/de.uni_mannheim.informatik.swt.models.gmf/templates/aspects/diagram/editparts/LinkEditPart.xpt
and
updateDSL in http://code.google.com/a/eclipselabs.org/p/melanie/source/browse/de.uni_mannheim.informatik.swt.models.gmf/templates/aspects/diagram/editparts/NodeEditPart.xpt
for interpreting a model and create a figure out of it this java class should be a good starting point
http://code.google.com/a/eclipselabs.org/p/melanie/source/browse/de.uni_mannheim.informatik.swt.mlm.visualization.service/src/de/uni_mannheim/informatik/swt/plm/visualization/service/VisualModelToFigureTransfomator.java
I hope this helps you further.
Ralph
Re: Tools Palette elements directly from Java [message #897202 is a reply to message #896904] Mon, 23 July 2012 03:01 Go to previous message
Thanks, this looks promising.
Previous Topic:Problem understanding diagram partitioning
Next Topic:diagram editor for dynamic objects
Current Time: Wed Jul 23 11:26:16 EDT 2025
Powered by FUDForum. Page generated in 0.06864 seconds
